1 wired + 1 wireless connection issues
52 (0.01/day)
Processor E8500
Motherboard Asus P5Q-E
Cooling Stock
Memory Corsair XMS2 Xtreme TWIN2X4096-6400C5 G 2x2GB
Video Card(s) XFX GeForce 9800GT 512MB
Storage Western Digital Caviar Blue WD5000AAKS 500GB
Case Antec Sonata III
Audio Device(s) Creative Sound Blaster Audigy SE
Power Supply EarthWatts 500W
Software Vista home premium 64-bit
I have been trying to get my computer working in a home network through a router with a wireless connection, while at the same time having internet provided through a wire.
The reason this is an issue is because the wired does not go through the router while the wireless of course does.
The issue I am having is that when both are connected my internet connection comes through the wireless and not the wired.
What I want is for the wireless to connect to the network while the wired connects to the internet.
I am using windows 8.1
Thank you,
6,270 (0.94/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
what make and model router are you using?
1,618 (0.29/day)
i THINK i might understand what you're trying to do
generally, a LAN that goes into a router that is connected to the internet will provide internet to all wired+wireless clients that connect to it (most people do it like this)
you want to have it so that if you're wireless, you cant access the internet? kind of like dd-wrt's option to block router admin logins over wireless? this would require such a feature on the router, or possibly windows to create a different network with different security settings on each wired & wireless network adapter
5,703 (1.12/day)
System Name RemixedBeast-NX
Cooling Dell Standard
Memory 24GB ECC
Mouse Logitech G700s/G502
Keyboard Logitech K740
Software Linux Mint 20
Benchmark Scores Network: APs: Cisco Meraki MR32, Ubiquiti Unifi AP-AC-LR and Lite Router/Sw:Meraki MX64 MS220-8P
52 (0.01/day)
Processor E8500
Cooling Stock
What I want is for the wired to provide the internet connection (because it is faster at 1gbit/s) while the wireless gives me access to the home network. So far I have to disable the wireless to use the internet at the full speed and re-enable it when i want access to the network.
VLAN, how? what?
5,703 (1.12/day)
Memory 24GB ECC
Well how fast is your internet? and why would you use wireless just for the home network? I doubt that you have 1Gbps INTERNET speeds. That is the LAN speed and NOT the WAN speed. is there a reason you HAVE to keep them seperate? if it's a particular application that leads to complications.
Are you using this for something like kali/backtrack or something like that? If so it's best to actually use a VM for that and have it ONLY use the WLAN or whatever.
And VLANs are virtual LANs....networks within your network. They are used to seperate groups of computers in your network from eachother...
like if you want the guests to have thier own network so they cant get into your network. Or in the business sense where they don't want the sales to access the R&D's systems.
Mussels
Freshwater Moderator
58,413 (8.18/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
i think he wants wifi for internet, wired for file transfer.
this seems weird to me, as i see no reason to do this.
52 (0.01/day)
Processor E8500
Cooling Stock
My internet is 1 gbit/s.
And it is with my wired i want to access the internet and wireless for network.
Wired connection does not go in to the router, it uses a seperate plug in the wall and as such can not get to my network through it. That is why I want my wireless to access the network. But when I have both conections on at once, my computer wants to use the wifi and as such my speed drops by a lot.
Mussels
58,413 (8.18/day)
Oystralia
basically, windows isnt designed for this. you can choose which network is to be used first, but traffic meant for the other network just wont work unless you can specify the IP address you need in the programs you're using.
52 (0.01/day)
Processor E8500
Cooling Stock
I see, that is annoying, but I guess I just got to keep on switching between them then.
Thanks for your help.
40,435 (6.58/day)
Cooling Scythe Ashura, 2Ă—BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED
intranet- crossover cable and switch/hub
5,703 (1.12/day)
Memory 24GB ECC
The easiest way for the OP to do this is for them to use VMs. I recommend VMWare Workstation or Player for windows 7 and/or Client Hyper-V for Windows 8.
Mussels
58,413 (8.18/day)
Oystralia
didnt think of that. this could be done, and one 'system' can be locked to each network. same as doing this with two physical machines.
5,703 (1.12/day)
Memory 24GB ECC
Here's a link that will help the OP if they cant get VMWare configured right:
https://communities.vmware.com/thread/414125
Here's how to do it in Client Hyper-V and this is what I use with my Server 2012 (built into Windows 8)
You would uncheck the "let the management operating system use this adapter"
1,618 (0.29/day)
is there a way to do this with different subnet masks or something ghetto like that?
also if you're wired... & it's the same network... dont you have access to the rest of the LAN? i'm not sure i understand why wireless even exists on this particular computer
6,270 (0.94/day)
New York
So I still don.t understand. You must have TWO different accounts from the Internet provider? Is one yours (wireless) and maybe one is the apartments (wired)? Or is the wired yours and maybe the wireless is public or some one else's? This sounds like there are two internet provider accounts.
155 (0.03/day)
never use wireless : its cracked in few seconds , AND IT DAMAGES BAWLS and brains
Mussels
58,413 (8.18/day)
Oystralia
FYI, i've done plenty of penetration testing and wifi network cracking in order to secure my own stuff. only WEP can be cracked fast. WPA/WPA2 can take weeks or months, and only on vulnerable routers a limited distance from them.
what you're saying is not factually correct, or even relevant to the topic.
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Manually set the IP for the wireless card and don't enter any DNS Server addresses. Since that connection won't respond to DNS requests, Windows won't use it for internet traffic.
Aquinus
Resident Wat-man
13,147 (2.94/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
Just leave out the default gateway when you set the static IP. Even if DNS can't resolve an address, you're still technically on the internet if a gateway is configured.
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
The problem with leaving off the default gateway is then the connection won't work some LAN traffic as well. Yes, he will technically still be on the internet with the wireless connection, but without DNS servers, Windows won't use the connection for internet traffic.
52 (0.01/day)
Processor E8500
Cooling Stock
No it is one account, but we have 3 different wall sockets that use it. The router is in a location were wired to it is a no go, and if I make wired possible, the walls interfere with the wifi.
Thanks for all the help, I will try the VMware thing, sounds like that will be a decent solution for plex use.
4,966 (0.91/day)
System Name i7-PC / HTPC / iMac
Processor i7 3820 / Phenom II 940
Motherboard GIGABYTE G1.ASSASSIN2 / M3A79-T Deluxe
Cooling Corsair Hydro H100i / Scythe II (HS only)
Memory G.SKILL Trident X Series 8GB (2 x 4GB) DDR3 1600mhz / 4GB DDR2 1066 (@800) Corsair Dominator
Video Card(s) GB Radeon HD 7950s 3GB / GB Radeon HD 7950s 3GB
Storage 2x 80GB Intel X-25, 2x600gb SATA, 1x1tb 5400RPM storage /1x600GB, 3x500GB,1x160,1x120 SATA
Display(s) 1x 27" Yamakasi / Vizio 42" HDTV
Case Lian Li Lancool PC-K58 / Antec 900
Audio Device(s) HT Omega Striker 7.1 / Onboard and HDMI from ATi Card
Power Supply PC Power & Cooling 750W / 610W
Software Ubuntu / Windows 8.1 Pro / OS X / PHPStorm / Gaming
what am i missing? if you want it to use wired for internet, set it to use wired first as mussels said. this means any time you open any program it will try to use the wired connection first. if it can't find what you are looking for there, it goes to the wireless. that's how i have managed multiple connections before. you do all this by changing the metric settings in the network configuration for each adapter. set wired to 1 and wireless to 99.
52 (0.01/day)
Processor E8500
Cooling Stock
How do I set this? I tried some setting in adaptes & bindings under network connections but that did not help
4,966 (0.91/day)
Is this what you edited? (right click adapter, go to ip v4 properties, click advanced button, uncheck automatic metric. change it on both, 1 on wired (internet) 999 on wireless (network). restart the computer? no difference?
