24 Pin Power Cable Mod
Discussion in 'Cases, Modding & Electronics' started by MKmods, Oct 15, 2008.
  1. MKmods Case Mod Guru
    Feb 26, 2008
    5,697 (2.34/day)
    1,748
    Nevada
    24 Pin Power Cable Mod (Thanks Murderbox for the inspiration)
    Usually its a pain to do these things but I figured I would do one showing how I mod a 24 pin cable for freaksavior..
    He wants the wires sleeved in pairs about 6" from the end.
    Here is a shot of them original
    [​IMG]
    Some PS Mfgrs show a schematic of the wire order on their web sites. Ever since I figured my camera had a close up setting I like picts better
    Now before you try this remember 1 mistake and POOF
    Its very easy to mix up the wires, some PSs use multiple rails so for example on the yellow wires (12V)the wires may go to different locations on the PSs circuit board.
    Here is a chart showing the order of the wiring
    http://pinouts.ru/Power/atx_v2_pinout.shtml
    Now get a good pin remover tool, I found some good ones here
    http://www.svc.com/sleeving-tools.html
    the pins are flat and fit on either side of each pin. Sometimes the plastic plug is tighter than others so you may have to wiggle the wire a bit to let the pins slide between the connector and the plastic housing
    [​IMG]
    [​IMG]
    here is a shot showing the locking tabs on the female pin
    [​IMG]
  2. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.04/day)
    862
    Dorset, UK
    So what exactly is this mod, or have you not finished the guide yet? :confused:
  3. DOM
    DOM
    May 30, 2006
    7,552 (2.46/day)
    828
    TX, USA
    i was going to ask the samething LOL
  4. MKmods Case Mod Guru
    Feb 26, 2008
    5,697 (2.34/day)
    1,748
    Nevada
    I just started it right now. Patience Grasshopper:laugh:
    Here is a rough idea, freaksavior wants the cables in pairs though. (sweet comp though)
    [​IMG]
    freaksavior says thanks.
  5. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.04/day)
    862
    Dorset, UK
    Oh, I see now, I thought you meant 2 seconds (2s) thats why I got so confused. If it doesnt void the warranty, (will ask corsair tomorrow), then I'll defo be doing this. ATM, I have to take the braiding back, to make it so the cables go flat to go round the back of the mobo tray.
    MKmods says thanks.
  6. MKmods Case Mod Guru
    Feb 26, 2008
    5,697 (2.34/day)
    1,748
    Nevada
    Thanks Alex, I fixed that. I would be willing to bet there will be issues with a warranty.
    This is a separate cable off a Silverstone 800 modular PS. It completely removes (plugs at both ends) so if there is an issue he just orders another cable from Silverstone.
    I cut some flex into 6" pieces and slide it over the end of 2 wires
    [​IMG]
    Than a bit of 1/8" shrink tubing on the ends and heat it up using a heat gun. Careful not too much heat or the flex melts, a hairdryer also works.
    [​IMG]
    They make different wall tubing, I use the cheaper one on this. They also have a dual wall tube that is much heaver duty for areas that may need it.
    [​IMG]
    freaksavior and tigger say thanks.
  7. freaksavior
    freaksavior To infinity ... and beyond!
    Dec 11, 2006
    8,071 (2.81/day)
    908
    Umm I like the one w/ the sleeves better. Is it possible to use less tubing though so the wires are just really flexible? If not I understand
    Crunching for Team TPU
  8. MKmods Case Mod Guru
    Feb 26, 2008
    5,697 (2.34/day)
    1,748
    Nevada
    do you mean the end part? Its about 5/8" now.. Il do one 1/4" right now and post a pict.
  9. freaksavior
    Dec 11, 2006
    8,071 (2.81/day)
    908
    Thanks mark sorry if I'm being really picky
    MKmods says thanks.
  10. tigger
    tigger I'm the only one
    Mar 20, 2006
    10,183 (3.24/day)
    1,399
    Very nice,i will be doing mine soon so this will be very helpful.
    Also my loop is similar to the one in that pic,single loop with cpu/gpu.Is it better to go to the cpu or gpu first?
    My loop is pump-cpu-gpu-bip 240 rad-pump,using a t-line.Would it be better like this pump-gpu-cpu-rad-pump?
    Thanks MKmods awesome stuff as always.
    MKmods says thanks.
  11. kyle2020 Guest
    Subscribed - absolutely love your work MK, cant wait to see the end product. Thats setup in the picture looks amazing, its only when you look at, what can only be described as such art as that that you realise just how ugly certain parts of a computer really are.
  12. freaksavior
    Dec 11, 2006
    8,071 (2.81/day)
    908
    I mean the part closest to the plug. It would be cool if the shrink tubing part was in the plastic plug piece so you can barely see it. Then just sleeved
  13. MKmods Case Mod Guru
    Feb 26, 2008
    5,697 (2.34/day)
    1,748
    Nevada
    I really dont mind..this will help a lot of others not to make the same mistakes I did and show what different versions will appeal to them..
    OK now to the "Artsy Fartsy" part....(this is so freakin nice in person)
    [​IMG]
    [​IMG]
    It is 2x the work and materials but 10X the coolness :rockout:
    (Individual wrapped with tubing inside the plug)
    When I do H2o I like to go from the rad to the CPU,than the GPU than the pump and finally into the rad to be cooled. (make sure the pump has a bit of airflow as well to keep it from getting too warm)
    Thanks Tigger...
  14. freaksavior
    Dec 11, 2006
    8,071 (2.81/day)
    908
    That works for me. That looks awesome from what I can tell (I'm on my phone :( )
    MKmods says thanks.
  15. freaksavior
    Dec 11, 2006
    8,071 (2.81/day)
    908
    That looks amazing :)
    MKmods says thanks.
  16. MKmods Case Mod Guru
    Feb 26, 2008
    5,697 (2.34/day)
    1,748
    Nevada
    lol, thanks..I only have 1" left of that sleeve left.. Good thing there wernt any more mistakes...
    (Il send it out tomorrow)
  17. panchoman
    panchoman Sold my stars!
    Jul 16, 2007
    9,595 (3.61/day)
    1,200
    thats freaking sick man!
    MKmods says thanks.
  18. DOM
    DOM
    May 30, 2006
    7,552 (2.46/day)
    828
    TX, USA
    now do mine lol
    nice job :toast:
    MKmods says thanks.
  19. freaksavior
    Dec 11, 2006
    8,071 (2.81/day)
    908
    :D and its all mine :)
    Thanks mark, look forward to receiving it
    btw it is a lot more flexible this way now right?
  20. MKmods Case Mod Guru
    Feb 26, 2008
    5,697 (2.34/day)
    1,748
    Nevada
    It yep, it bends pretty easy.
  21. BrooksyX
    BrooksyX
    Jan 7, 2008
    3,947 (1.59/day)
    569
    WOW! That is amazing, it looks so clean.
    All PSUs should come like that.
    MKmods says thanks.
  22. [I.R.A]_FBi
    [I.R.A]_FBi New Member
    May 19, 2007
    7,664 (2.82/day)
    540
    c:\programs\kitteh.exe
  23. MKmods Case Mod Guru
    Feb 26, 2008
    5,697 (2.34/day)
    1,748
    Nevada
    lol, I wish it was mine...(Silverstone TJ07)
    http://murderbox.com/
    The have some really nice stuff in their gallery
    EDIT: OMG, look at this place.....HEAVEN!!!!!!!!!!!!!!!!!!!!!
    http://www.million-dollar-pc.com/
    (sweet MNPCTech has one there too)
    Big thanks Freaksavior for showing me the Murderbox comp.
  24. freaksavior
    Dec 11, 2006
    8,071 (2.81/day)
    908
    Your welcome :) just glad i got my cable done. I asked the guys from murderbox also if they did the psu cable and they said "We are sorry but that is not a service we offer"
  25. kyle2020 Guest
    Guide please! :D
    Id love to do this with my corsair, obviously test it out on my cheapo EZ-cool first but i must admit that looks amazing.
Share This Page
