4pin CPU Power Vs 8pin CPU Power
Discussion in 'Motherboards & Memory' started by Techtu, Jul 22, 2010.
  1. Techtu
    Techtu
    Mar 6, 2010
    2,143 (1.07/day)
    499
    In the night garden
    Guy's I've googled a little and can't find much on it so I decided to ask here :D
    I'm currently looking at 2 very very similar boards the ASUS M4A87TD, EVO and USB3 model's
    Now there is very very little between them as I can see, but one has a 4pin CPU power header whilst the other has an 8pin header. What's the major difference in this? will it affect overclocking and so on?
  2. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.38/day)
    573
    New York
    The 8 pin is newer technology and in my opinion better.
    I would say better at clocking in general too.
  3. slyfox2151
    slyfox2151
    Jan 14, 2009
    2,621 (1.08/day)
    526
    Brisbane, Australia
    the difference is more power over more wires....
    i cant see it making a difference with overclocking unless your reaching 4.5ghz with quads or running an i7 overclocked.
    my E7300 dual core hits 4.3Ghz with either the 4 pin or 8 pin, dosnt effect it.
  4. Techtu
    Techtu
    Mar 6, 2010
    2,143 (1.07/day)
    499
    In the night garden
    Well I plan on running an 1055T :D
    As for overclocking it I'll probably be happy 3ghz, so nothing fancy.... and I realised those boards I selected actually have just 4pin CPU power headers but nevermind, it's something I was curious about anyways.
  5. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    21,602 (6.05/day)
    7,498
    I believe(correct me if I'm wrong):
    4 Pin is rated for 150w to the CPU.
    8 Pin is rated for 300w to the CPU.
    Though looking at both boards, are you sure one has an 8-pin? I think I'd go with the EVO though, as it has a stronger CPU power design.
  6. Techtu
    Techtu
    Mar 6, 2010
    2,143 (1.07/day)
    499
    In the night garden
    I've not seen a CPU use more than 140w, and those what I have, have been AMD of-course :rolleyes:
  7. newtekie1
    Nov 22, 2005
    21,602 (6.05/day)
    7,498
    At stock, but once you start to overclock the power can easily go past 150w, especially if you start with a 140w CPU.
    Techtu says thanks.
  8. Techtu
    Techtu
    Mar 6, 2010
    2,143 (1.07/day)
    499
    In the night garden
    Ahhh I see, So they are only really needed for high end overclocked AMD's ... in a sense :)
  9. Asylum
    Asylum
    Jul 18, 2008
    2,862 (1.10/day)
    705
    South Carolina
    That would be a correct answer...
    You will only need the higher output on the motherboard if you plan to push it hard.
    Techtu says thanks.
Share This Page
