6770M - Problem or not ?!
Discussion in 'GPU-Z' started by nism, Sep 7, 2011.
  1. Jstn7477
    Jstn7477
    Aug 30, 2009
    3,974 (1.63/day)
    1,633
    Sarasota, Florida, USA
    http://www.techpowerup.com/reviews/AMD/HD_6670/
    Do you have any of the 3DMark benchmarks, or any of the games tested in the review above? Otherwise, I would suggest you to download FurMark 1.9.1 or something, but I don't want you to potentially burn up your new laptop (although it is unlikely).
    I ran FurMark 1.9.1 on the 720p benchmark preset and got 528 points (8 FPS) on a Mobility Radeon HD 5650 with a 450MHz core (400 stream processors/8 ROPs) and 800 (1600 eff) 128bit DDR3. If you can roughly double my score, your card should be fine.
    [​IMG]
  2. nism New Member
    Sep 7, 2011
    12 (0.01/day)
    0
  3. Jstn7477
    Jstn7477
    Aug 30, 2009
    3,974 (1.63/day)
    1,633
    I'm jealous of your laptop. :toast:
    Anyway, the monitoring programs likely all use custom methods of retrieving the clock information, so some programs may have better or worse methods for different cards.
  4. nism New Member
    Sep 7, 2011
    12 (0.01/day)
    0
    Hah thanks mate :) I have a question. I want to update my CCC. When i DL it from the ati site, should I uninstall the old CCC and ati drivers( and how to uninstall drivers :p ) first ? Also should I uninstall the integrated video card driver or not ? I will be happy if you give me some tips :) :toast:
