8800gts dvi audio problems
Discussion in 'Audio, Video & Home Theater' started by Fitseries3, Jan 31, 2012.
  1. Fitseries3
    Fitseries3 Eleet Hardware Junkie
    Oct 6, 2007
    15,509 (5.60/day)
    3,107
    Republic of Texas
    i have read plenty of threads and guides on how to get audio over dvi/hdmi on this 8800gts i have but i cant get it to work. all the guides are for windows xp and im using windows 7.
    its wired right, im sure of it.
    seems to be a software problem.
    in sound properties it says "internal atapi jack" is enabled and working but i cannot get any audio.
    i've tried a dvi to hdmi cable as well as a dvi to hdmi adapter with hdmi cable.
    any tips?
  2. Red_Machine
    Red_Machine
    Oct 1, 2010
    1,789 (1.07/day)
    396
    Marlow, ENGLAND
    nVIDIA didn't include GPU audio until the 200 series, so unless you have a special cable plugs into the card and the sound device you have (be it onboard or a card), you won't get anything.
  3. Fitseries3
    Oct 6, 2007
    15,509 (5.60/day)
    3,107
    Republic of Texas
    i've got the cable connected from the mobo to the card already. g92 and up cards have a spdif headers. this card has it and i connected it to the mobo with a cable i have.
    the problem is in the software
    [​IMG]
  4. techguy31
    May 23, 2010
    500 (0.28/day)
    38
    So did you reinstall your drivers? Are your drivers up to date?
  5. Fitseries3
    Oct 6, 2007
    15,509 (5.60/day)
    3,107
    Republic of Texas
    latest drivers available installed.
  6. techguy31
    May 23, 2010
    500 (0.28/day)
    38
    Did you try fiddling with the audio control panel?
  7. Fitseries3
    Oct 6, 2007
    15,509 (5.60/day)
    3,107
    Republic of Texas
    yep. everything says its workin but there is no sound
  8. techguy31
    May 23, 2010
    500 (0.28/day)
    38
    Are you trying to get audio from your video card to the monitor?
  9. Fitseries3
    Oct 6, 2007
    15,509 (5.60/day)
    3,107
    Republic of Texas
    to LED tv.
    i've done it before with an 8800gt.
  10. techguy31
    May 23, 2010
    500 (0.28/day)
    38
    If you have done it before then, I am kind of at lost. Because last time I checked DVI does not send audio. It only sends the video signal.
    You could try using one of those DVI to HDMI from your GPU to you LED TV and see if the audio pass-through the tv via HDMI, but I highly doubt that will because HDMI has some HDCP that DVI doesn't have.
  11. Fitseries3
    Oct 6, 2007
    15,509 (5.60/day)
    3,107
    Republic of Texas
    when you use a video card that supports it, which most do today and have for a few years now.
    the g92 cards were the first cards to support this.
    you connect the spdif out from the soundcard/onboard sound to the video cards input and it will send audio out the dvi to be used for dvi->hdmi cabling into a tv.
    in newer video cards, a built in audio chip has been added so that the sound is internally transmitted over pcie and out through the dvi and now through DP and hdmi outputs.
  12. techguy31
    May 23, 2010
    500 (0.28/day)
    38
    Well then, I guess the only thing I could finally think of is that your DVI to HDMI adapter or whatever cable you are using might be defective. Maybe try another adapter or cable?
  13. Mussels
    Mussels Moderprator Staff Member
    Oct 6, 2004
    42,931 (11.11/day)
    10,229
    if its G80, it wont work, period. if its G92, then you need an SPDIF cable from your soundcard to the video card. you then play sound via your sound cards SPDIF port.
    edit: some G92 cards dont work either, my first gen 8800GT wont work with SPDIF audio, it was a known bug at the time of launch fixed with 9800GT's
    edit 2: and you definitely need an DVI to HDMI adaptor, cant use straight DVI. not all adaptors will pass audio either, so try more than one.
    Fitseries3 says thanks.
  14. techguy31
    May 23, 2010
    500 (0.28/day)
    38
    If you aren't able to use the DVI to send audio. Why not just use the mobo's spdif or coax to send audio and let the DVI send video? That way you will still get sound.
  15. Mussels
    Oct 6, 2004
    42,931 (11.11/day)
    10,229
    because most HDTV's dont let you mix and match audio and video sources. if he wants to use his TV's speakers and HDMI video, then it must be HDMI audio as well.
  16. Fitseries3
    Oct 6, 2007
    15,509 (5.60/day)
    3,107
    Republic of Texas
    as pictured... its wired correctly. and its a g92.
    i have 2 cables... one is a DVI to hdmi cable and the other is a ATI DVI to HDMI converter with HDMI cable to the tv.
    im running onboard sound and running from the mobos SPDIF_O to the cards SPDIF_I.
    im probably just going to end up getting a better gpu so i suppose i'll play games in silence for a few more days haha
  17. Mussels
    Oct 6, 2004
    42,931 (11.11/day)
    10,229
    the DVI to HDMI cables rarely work, but the ATI branded ones definitely work on nvidia cards (the other way around is not the case)
    sounds like you may have a card like my one that i gave to my GF, where the SPDIF port is present but not functional.
    maybe try VGA with a 3.5mm cable until you get that better GPU?
  18. 1freedude
    1freedude
    Nov 16, 2007
    557 (0.20/day)
    118
    Try getting sound out of the spdif...into a receiver or a tv...
  19. 1freedude
    1freedude
    Nov 16, 2007
    557 (0.20/day)
    118
    do you have the tv hooked up to a receiver?
    I have an old ass JVC that has coax and optical with onboard decoding.
    the only hdmi input to my tv is wifey's laptop. the audio goes into receiver, from the tv through the coax. maybe the tv doesn't know how to deal with the audio stream.
    i'm gonna try something, i wll edit this post with results.
    Results:
    I hooked up lappy to tv to see if audio came out of tv's speakers, and it did (as well as receiver's).
Share This Page
