- Dec 6, 2011
- 4,784 (1.07/day)
- Still on the East Side
Airepad LLC recently unveiled a new website for their laptop cooling pad. The Airepad laptop cooling pad is A Low-Tech Solution to a High-Tech Problem. The Airepad provides a lightweight and extremely comfortable shield between your laptop and your legs. It stores easily in your purse or carrying case and weighs only 4 ounces. The laptop cooler is TSA friendly, containing no liquids, jells, or crystals.
The Airepad Laptop cooling pad has a self-inflating air valve that allows the air to enter in to fill the Airepad. When inflated, you simply close the valve and place it on your lap. If you desire the pad to be a bit stiffer than ambient air pressure you can simply blow into the valve to make the cooling pad firmer. It provides a comfortable work platform for laptops up to 16 inches wide.
When you are finished working, the Airepad can be deflated and stored in seconds. Simply open the air-valve and fold the cooling pad into quarters or roll it up, pressing the air out of the pad. Then close the valve to keep the pad deflated.
Airepad LLC's new website allows visitors to purchase the laptop cooler at their convenience 24 hours a day, 365 days a year.
To see the Airepad in action, simply visit http://www.airepadlaptopcooler.com.
