A10-7850K Cooling and Driver Problems
Discussion in 'General Hardware' started by Durvelle27, Jul 31, 2014.
  1. Durvelle27
    Durvelle27
    Jul 10, 2012
    2,722 (2.07/day)
    671
    Memphis, TN
    Ok i bought a new A10-7850K and Gigabyte GA-F2A88X-UP4 and i'm having nothing but problems with it.
    First problem is it runs very hot. When in BIOs it sits around 62*C and than when i boot into Windows it skyrockets past 80*C and than calms and idles around 70*C. I'm using custom loop that had 3x 240MM Radiators but now 2x 240MM as i was trying to see if temps would change but oddly enough they didn't.
    Second problem is i can't get the AMD CCC drivers to install. When ever i try to install them it hangs at detecting graphics hardware. I've tried 14.4-14.7 with no luck. Using Windows 8.1 Pro x64
    Please someone i really need help.
  2. Steevo
    Steevo
    Nov 4, 2005
    9,172 (2.44/day)
    1,722
    Sounds like a defective chip, the temps cannot be that high, and if it isn't being properly recognized by the drivers it may be damaged.
    10 Year Member at TPU 10 Million points folded for TPU
  3. Norton
    Norton WCG-TPU Team Captain
    Dec 21, 2011
    10,738 (7.08/day)
    28,959
    That board is FM2/FM2+... are you running the latest BIOS (F5 for rev.3.0 boards)?
    Also, is the voltage set too high? My Gigabyte AM3 and AM3+ boards usually put way more voltage on the chip than necessary with Auto settings.
    If these items are ok then I agree with @Steevo , you may have a bad chip.
    Crunching for Team TPU
  4. Durvelle27
    Durvelle27
    Jul 10, 2012
    2,722 (2.07/day)
    671
    Memphis, TN
    i didn't even think to check BIOs and its around 1.32V
    Edit: Ok after checking motherboard indeed not on the latest BIOs. Updating now.
  5. Durvelle27
    Durvelle27
    Jul 10, 2012
    2,722 (2.07/day)
    671
    Memphis, TN
    Ok after updating this no change. Gonna try a fresh Windows install and see if that helps.
