Advice on CPU Cooler and VGA Cooler
Discussion in 'Overclocking & Cooling' started by Tedz, May 18, 2007.
  1. Tedz New Member
    Dec 7, 2006
    14 (0.00/day)
    0
    Ames, IA
    Hey Guys,
    I am a long time reader..... I check this site 4 or 5 times and day and it is great, just a ton of information can be learned, but this is my first time posting so I thought I would introduce myself first
    Anyway I am looking into getting a new cooler and for my VGA and my CPU
    here at my specs and what she does on stock coolers
    CPU - 2.8 P4 Northwood at 3.4ghz
    MBoard - DFI Lan Party 875 Rev. B
    Memory - 2 x 512 Corsair XMS 3200 - 2.5/3/3/6 at 1:1 with CPU
    VGA - ATI x800 GTO with 16pipes unlocked - R430 Core
    everything has stock coolers and I think it is time I get a little more out of this old beast
    I was looking at the Scythe INFINITY for the CPU
    and then for the GPU maybe the ZALMAN VF900, I am not to familiar with GPU coolers but advice on both would be great... anways thanks in advance guys and nice meeting ya :toast:
  2. SK-1
    SK-1
    May 15, 2005
    3,389 (0.86/day)
    475
    In a Galaxy Far Far...you know the rest.
    WELCOME TO TPU!
    Go ahead and post your specks in your user CP.
    As far as coolers,....It sounds like you want to overclock in your post.Good deal.
    I assume you want air cooling so here are my recommendations.
    CPU,...Thermaltake V1 CPU Cooler or the 9700 Zalman http://www.rbmods.com/Articles/Thermaltake/V1_cpucooler/1.php
    GPU,...If it will fit,...Arctic Cooler Silencer.Otherwise the VF900 will be good.
    10 Year Member at TPU
  3. Tedz New Member
    Dec 7, 2006
    14 (0.00/day)
    0
    Ames, IA
    Thanks,
    Whats makes you say Thermaltake V1 or the 9700 Zalman over the Scythe?
    Also I do not think the V1 fits socket 478 which is what I have
  4. KennyT772
    KennyT772 New Member
    Dec 21, 2005
    3,584 (0.97/day)
    103
    scythe would work really nice, and the vf900 is perfect too. you picked the best there is basically.
  5. Tedz New Member
    Dec 7, 2006
    14 (0.00/day)
    0
    Ames, IA
    Thanks kenny
    also does anyone have any of there highest clock settings they have got with the x800gto with the 430 core seeing if i would be even worth it to change the stock cooling as I have heard the X800 GTO's with the 430 core do not overclock well
  6. SK-1
    SK-1
    May 15, 2005
    3,389 (0.86/day)
    475
    You will be happy with any of the 3. I have a windowed case and like the look of the 9700,plus it performs great.;)
    I did a little heat-paste mod that gained around 1.5c.Just fill the nooks and crannies around the heatpipes at the base.At that point, it is a killer cooler.What case ventilation do you have going?
    Let me know what you order.
  7. erocker
    Jul 19, 2006
    41,046 (11.76/day)
    16,143
    Have you unlocked it yet? You probablly can, just take a screenshot of ATi tool under settings tab. Just hold Ctrl and click settings, take a screenie of the fuses numbers. There is a thread dedicated to this. Anyways, as far as overclocking, it sucks, you may get a little bit out of the core and a small amount more from the memory. Unlocking it , however will give a huge noticable difference over oc'ing anyway.
  8. Tedz New Member
    Dec 7, 2006
    14 (0.00/day)
    0
    Ames, IA
    Ya i have unlocked to 16 pipes already it came like that it says it in my settings of my ati tool
    here is a screenie of it
  9. FujiwaraTakumi New Member
    Oct 10, 2006
    85 (0.02/day)
    0
    Hey Tedz. I've got an R430 X800GTO as well. I slapped a Zalman VF900 onto it. Idle temps lowered to 23-30C (depending on ambient temps) with a load of 38C. With stock cooling, I was getting 424/532 running ati tool artifact scan for an hour. I haven't tried to see what maxes I could get out my card since I switched. I'm willing to bet I can squeeze a couple more out of the core and memory. You might be able to get a bit more by bumping the voltage up a smidget as well.
  10. Tedz New Member
    Dec 7, 2006
    14 (0.00/day)
    0
    Ames, IA
    Well guys just ordered my stuff today I got a little happy adding things to the cart and got a new mouse and pad
    GPU COOLER ZALMAN|VF900 – CU RTL
    CPU COOLER SCYTHE USA|SCINF-1000 RT
    MOUSE PAD RAZER|EXACTMAT& EXACTREST
    MS RAZER|DEATHADDER GAMING RT
    I will post back with my new results hopefully it all goes well thanks for the advice all :rockout:
