AIO water loop advice
Discussion in 'Overclocking & Cooling' started by Random Murderer, Nov 30, 2012.
  1. Random Murderer
    Random Murderer The Anti-Midas
    Dec 6, 2006
    6,730 (2.01/day)
    1,537
    I have been looking to build a custom loop for a while but don't have the time or money right now, so to hold me over and hopefully get some better temps than this Xig Aegir, I'm looking at 2x120mm AIO systems. The H100 specifically caught my eye, and then I saw the H100i which is supposedly a little better, even though the fans don't push as much air.
    Now I'm conflicted.
    Brand nor OEM matters to me, and I'll probably end up replacing the fans in the near future with high CFM, high pressure fans. Suggestions on systems and/or fans? Keep in mind I need to keep the total height of the fans+radiator under 60mm.
    Thanks in advance to all who reply!:toast:
    TL;DR: Which AIO water loop should I get?
  2. XL-R8R
    XL-R8R
    Nov 12, 2012
    344 (0.29/day)
    144
    Technical Tittery....
  3. RCoon
    Apr 19, 2012
    10,520 (7.54/day)
    7,909
    Gypsyland, UK
    Corsair H100i with quieter fans as my personal choice > better tubing than H100
    Random Murderer says thanks.
  4. sneekypeet
    Apr 12, 2006
    22,840 (6.36/day)
    7,401
    All the latest AIOs are much better. Corsair has new head units as do the Thermaltake's. Cant really go wrong with either, but the new Corsair head units do look better than all the rest;)
  5. brandonwh64
    brandonwh64 Addicted to Bacon and StarCrunches!!!
    Sep 6, 2009
    19,228 (8.18/day)
    6,681
    Chatsworth, GA
    Crunching for Team TPU
  6. Random Murderer
    Dec 6, 2006
    6,730 (2.01/day)
    1,537
    Thanks.:toast:
    Aesthetics don't bother me too much. Lowest temps possible with an AIO is my goal.
    From these responses though, it seems the extra $15 for the H100i over the H100 is worth it.
    I had considered that one, but in the past I had used the Water 2.0 Performer and absolutely hated the mounting system. I could put that hatred aside if that beefy radiator on the Extreme would fit in my limited space, but alas, it does not.
    Edit: Upon closer inspection, I could probably fit that radiator if the fans were mounted to the outside of the case. Going to wait and see what some others have to say before making up my mind.
  7. sneekypeet
    Apr 12, 2006
    22,840 (6.36/day)
    7,401
    Oh right, the new Corsair AIOs have that new magnetic mounting bar. That and simple thumbscrews works really well.
  8. Hood
    Hood
    Sep 25, 2012
    967 (0.78/day)
    324
    My H100 works great and runs quiet, so I'd say go with the H100i. The Thermaltake units haven't been around long enough to rate their reliability, and I don't trust the company anyway (too many false claims about their products). I want to try mine with 4 Delta 5000 rpm fans (on a fan controller of course) just to see how low I can get my temps (or how high my overclock!).
  9. Random Murderer
    Dec 6, 2006
    6,730 (2.01/day)
    1,537
    Thanks guys. It was made abundantly clear that the H100i is the way to go. I now have one on order, but skipped getting the fans (for now) as the 100i comes with SP120L fans. Same as the SP120 High Performance except slightly lower pressure and a bit more CFM.
    Can't wait to see how much of an improvement this will be over my now archaic Xig. Should also make the system look a bit tidier.
