Air cooling rankings right now
Discussion in 'Overclocking & Cooling' started by DF is BUSY, Nov 20, 2013.
  1. GreiverBlade
    GreiverBlade
    May 9, 2012
    2,742 (2.59/day)
    2,083
    Ovronnaz, Wallis, Switzerland
    Thermalright HR-02 Macho Rev. A good price/perf ratio too, it compete in the 75€ segment with a price of ~45€ but the size of it can be a hinder, Raijintek Ereboss is good too but just a copycat of the macho less excentered with a slim 140 to compensate, higher RPM than the Macho to beat it with 1° difference (1600RPM Ereboss vs 1300RPM Macho), Raijintek Aidos : Cooler Master Hyper TX3 (a bit better tho unless TX3 in push pull setup) Raijintek Themis : Cooler master Hyper 212S (again a bit better unless push pull 212S)
    Alpenfön Brocken 2 also a good one with the Scythe Ashura
    Macho min/max regular gaming with a 3.5-3.9ghz Xeon E3-1275v2
  2. mastrdrver
    mastrdrver
    Feb 24, 2009
    3,227 (1.45/day)
    598
    I still like my Noctua NH-D14. When I still had my i7 920, I could put ~1.20v (with HT) through it and load up LinX. Stress it all day. With a passive NH-D14, the core temp would never go over 80C. I did this in my 932 HAF with all the factory case fans running their 12v speeds. Used to play games all day with it like that and never once had a CPU temperature problem.
    I've never had the 212, but the old OCZ Vendetta 2 and Xigmatek S1283 direct touch coolers did very well for how cheap they were. The 4 pipe Xigmatek did just a little better too (S1284F).
  3. Mr.Scott
    Mr.Scott
    Dec 25, 2012
    113 (0.14/day)
    122
    Spencerport NY
    If you think a 790X-UD4P, a 890FXA-UD5, and a Sabertooth 990 FX are badly designed, then yes.
    For twice the price, it better be.
  4. de.das.dude
    de.das.dude Pro Indian Modder
    Jun 13, 2010
    7,961 (4.54/day)
    2,142
    Mysore
    those are indeed.
    i dont expect the 790 to be desinged that good. but considering the current size of sinks and how the sabertooth adn the other one is are actually flagship products, you should expect more right?
    this is one of the many reasons i veered off from asus and onto asrock. i have a 990fx extreme 4, with vrm fan cooling, push pull on a hyper 212 evo, and even have the rams in first and 3rd slots, all fitting snugly. this isnt good design, but this is PROPER design.
  5. Kursah
    Kursah
    Oct 15, 2006
    8,183 (2.65/day)
    1,941
    Missoula, MT, USA
    I gotta agree, that in more builds I do, when it comes to cooling many folks often don't think of putting a good solution in their budget and then want to overclock. It's not easy to convince someone to pay $70 for a good air cooling solution or even AIO (though I prefer air). That's where the ACF7 and CM212+ Evo come in handy. Generally the CM is on sale more and is also a good bit more effective than the ACF7P part but both work well...and when it comes down to mild OC's both are quite capable at keeping temps within the safe boundries...especially when a case that has at least somewhat decent airflow is involved. Most builds I generally utilize cheaper rosewill cases that thankfully have decent airflow...I try to push for the designs that have the rear and top exhausts even if the top has no fans just for the sake of heat rising and having somewhere to go.
    I will say I push more for the 212+ even if it's more expensive than the AC part...but neither compares to my much more expensive Noctua U14S which I am very happy with...even with just the single 150mm fan. It's been great, especially when I swapped out my rear 120mm exhaust with a Corsiar SP120. Very effective combo on my Haswell build.
    Even other Haswell OC builds I have done have worked out quite well on both the ACF7P and CM212+ Evo...honestly both are great coolers and I'm surprised the AC part is still around after having used one as my first heatpipe tower cooling solution to cool my e6300 conroe OC build many years ago. If you need a nice and little and effective cooling solution, it's a great choice imho. The 92mm fan can get a little noisy at full speed but I am still impressed how effective this cooler really is. Both coolers stick to a solid design...and I do agree the 212's mounting solution is kind of odd and can a pain the first time...it's easy after that and not a big deal imho.
  6. Mr.Scott
    Mr.Scott
    Dec 25, 2012
    113 (0.14/day)
    122
    Spencerport NY
    LOL. Whatever.
    I see Asrock fanboy in your post, and it has nothing to do with air coolers or what I choose to do reviews on. Troll on, I'm done. ;)
  7. Rickkins
    Rickkins
    Dec 25, 2011
    34 (0.03/day)
    0
    I have the Noctua NH-D14 and I can honestly say it cools fantastic on my fx-8150.
    I swapped out my H-80i for the Noctua and I feel like a genius for doing so.
    Cold & Quiet....
  8. rtwjunkie
    rtwjunkie
    Jul 25, 2008
    2,637 (1.08/day)
    1,554
    Louisiana
    Wow...do you even know what you're saying? de.das.dude is the last person anybody on here would accuse of being a troll. He gave a very good reason why HE went to ASRock instead of ASUS. He didn't jump up and down saying everything else sucks, ASRock rules, or anything even close to that.
    Take the time to actually read what people write before you react, and your time here will be much more enjoyable. This is one of the most polite and respectful forums on the internet, and members go out of their way to help each other, so please help keep it that way. People won't always agree with you....that doesn't make them a troll.
    qubit and GreiverBlade say thanks.
  9. Jeffredo
    Jeffredo
    Nov 30, 2006
    844 (0.28/day)
    133
    I just ordered a Thermalright True Spirit 140 last night. The place I ordered from had a 15% off coupon code and for $34 its definitely the best I could get. I already have one in my other PC and its great - easy to install (motherboard out) and pretty darn good cooling capacity. Plus its very quiet.
    https://www.superbiiz.com/detail.php?name=FAN-BW140
  10. Mr.Scott
    Mr.Scott
    Dec 25, 2012
    113 (0.14/day)
    122
    Spencerport NY
    That's not what I got out of that. I got that flagship boards from reputable companies (Gigabyte and Asus) are designed improperly and only Asrock was of proper design. Maybe you need to re-read post #31, and maybe you should be minding your own business instead of crapping the thread defending your buddy, instead of offering any real content.
  11. sneekypeet
    Apr 12, 2006
    21,928 (6.69/day)
    6,471
    Okay everyone cleared the air with their opinion on that matter, can we please get back to the topic?
    Mr.Scott says thanks.
  12. DF is BUSY
    DF is BUSY
    Oct 13, 2013
    268 (0.50/day)
    50
    how do you guys feel about single rad 120mm or single rad 140mm compared to the elite air coolers?
    is elite air >>>>>>> single rads, hands down/no questions?
  13. sneekypeet
    Apr 12, 2006
    21,928 (6.69/day)
    6,471
    depends on the fans and head unit, if you are speaking of AIOs here.
  14. GreiverBlade
    GreiverBlade
    May 9, 2012
    2,742 (2.59/day)
    2,083
    elite ... hum ... if by elite you mean price (because pricey = performance! ofc ;) ) ok ok i stop the joke.
    little personal comparison HR-02 Macho Vs H70 push pull with 2 SST AP-121 1° less in idle for the Macho and 2-3° less in load for the H70, but the H70 is a 50mm thick rad so for a 120mm it is almost efficient as a 240mm Aio as the H100/100i Seidon 240 etc (same goes for the other 38mm thick H80/80i, CM Seidon 120XL and the Antec Kühler 920 ) for me the reason i went back to the HR-02 was the aesthetic.
    DF is BUSY says thanks.
  15. EarthDog
    EarthDog
    Dec 31, 2009
    4,086 (2.13/day)
    1,071
    Last i saw, no single rad could keep up with the highest end air coolers....assuming the both had the same fans of course.
  16. GreiverBlade
    GreiverBlade
    May 9, 2012
    2,742 (2.59/day)
    2,083
    single thickness indeed but double width 120mm are not bad, i would rarely recommend a single width 120/140mm over a air cooled-
    [​IMG]
    [​IMG]
    it was on a i7-980X so the "stock" cooler is a beefier one and nosy as hell, just like a H70 with default 2000rpm fan :roll: but with 2 SST AP-121 its much better
  17. adsubzero
    Dec 12, 2013
    8 (0.02/day)
    2
    I have to say, Brocken 2 is one great cooler.
    It's dead silent, I can't hear it on max rpm even when the case is open, and it's got a great performance/price ratio.
    Beats lot of other more expensive coolers while being silent. :)
    GreiverBlade says thanks.
  18. Digital1
    Digital1
    Oct 16, 2013
    7 (0.01/day)
    1
    My TT nic c5 has arrived and is installed. With my old stock cooler I was getting temps between 68-73c when playing Bioshock Infinite. I'm now getting between 36-41c. The fans that come with the cooler aren't the quietest, even on the low speed setting. Especially noticeable when you tend to leave the pc running over night. I will replace those with a couple of Noctua's NF-S12A FLX in the new year though, and sure i'll be running quiet and content. The cooler is very good imo, easy to install and no ram slots blocked. Shame they couldn't have put as much fine detail into the fans design, as they did into the cooler itself, but at least it's a small flaw that can be remedied with another dip into the PayPal account. :)
  19. marsey99
    marsey99
    Jul 18, 2007
    1,838 (0.65/day)
    410
    i have a d14 and the older silver arrow called the ifx14.
    it is better than the d14 so the new silver arrow sb-e should be able to remove more heat than it does.
    it would be my pick if i was i in the market for a new blower today.
    antec h20 920 is on par with the best air, but it is very fat and hold much more liquid than most 120 aio loops.
  20. GreiverBlade
    GreiverBlade
    May 9, 2012
    2,742 (2.59/day)
    2,083
    indeed a H20 920 or corsair H70/80/80i cooler master seidon 120XL have a real good cooling potential.
    i also have a IFX-14 :D a pretty beastly cooler
  21. EarthDog
    EarthDog
    Dec 31, 2009
    4,086 (2.13/day)
    1,071
    Well, the amount of fluid really means quite little in cooling capacity. The more liquid in a loop, assuming we are not talking going from a Liter to a pond, just means it will take longer to reach the equilibrium. So, if I had a loop that used 1L and temps after an hour reached 60C, if I had 1.5L it would take longer but the temps would remain the same. ;)
    But yeah, I already conceded the 'thick' radiators may be in the ballpark. Truth be told, it depends on what review you look it as to what the results are. ;)
  22. marsey99
    marsey99
    Jul 18, 2007
    1,838 (0.65/day)
    410
    seen it with my own eyes and know how these coolers stack up.
    along side h50/h60 and many other air coolers.
    the phantec i do not know, as i have yet to play with one of those, so it could be best but with its design i expect it to be very much akin to the d14.
  23. GreiverBlade
    GreiverBlade
    May 9, 2012
    2,742 (2.59/day)
    2,083
    it's not the quantity of liquide who play a role but the dimension of the heat exchange surface in the radiator (also the number of fans but a H60 dual SST AP 121 is way under a H70 with same setup)
    doube thick rad : Antec Kühler H2o 920/Cooler Master Seidon 120 XL/Corsair H80/H80i =38mm the H70 is a 50mm (H90 is another story since its a single thick rad but 140mm instad of 120mm)
    while they are quite noisy if you push them, once you remove the stock fan and put a set of good SP fan with around 1900RPM (Scythe S-flex G or like me Silverstone SST AP-121) they can fight in the same league of a good air cooler IE: for me my Macho and H70 don't show much differences, just a shame that i lost the AMD bracket ... my poor H70 is in a box idling while my AMD setup has a stock cooler on it ... duh ...
    H50/H60 : good at low RPM in a HTPC with a fixed RPM under 1300, as long as you don't have a "bubble noise" pump it's pretty decent and silent, i assembled a A10-5800k in a Fractal design Node 304 with a H60 (originaly with a Hyper TX3 : no comparison ... and stock : no way in hell :D obviously
    the reviews still show a H70 being above a NH-D14 but welcome to hell of noise if you keep the 2k RPM corsair fan ahahahhahaha :roll: and Megahalems over a NH-D14 hell a single tower over a dual? ok right the TR SA SB-E/SB-E extreme and IFX-14 should beat the D14, for the Phantek : it should tag along... with Silverstone Heligon HE01 (which is cheaper tho) and TR SA SB-E, but i know they offer a large panel of color still the price of that cooler is not interesting over a TR SA SB-E
    [​IMG] [​IMG] [​IMG] [​IMG]
  24. markaflias
    markaflias
    Dec 11, 2013
    43 (0.09/day)
    7
    Alicante
    Got a 212 and a noctua 9 cm and they almost do "same" temps , difference ? The price . Got a very good experience with a scythe yasya , its a bit loud but he does his job very good :D
    Noctua 14 cm is top-notch but you have to pay its price :(
    I agree with #15 , these are the best you can got out there.
  25. GreiverBlade
    GreiverBlade
    May 9, 2012
    2,742 (2.59/day)
    2,083
    i am still wondering why Noctua fans and coolers are so popular ... i mean come on ... they are on the lower half of most of the charts and perform only a few ° lower or even worse, higher than lower priced units, their fans where i live are around 10 to 15chf (12-17$) more than other brand, ok i know they have a good accessory bundle and they are mostly quiet but it's kinda weird ...
    see the NH-C14 in the chart above? or even the D14 ? top notch but have to pay the price... bah!
Share This Page
