Akasa Introduces Power Extreme 1200W PSU
46,362 (7.68/day)
Akasa Introduces Power Xtreme 1200W PSU
Akasa adds its entry to the range of heavy-duty power-supplies with its PowerXtreme 1200W (model: AK-P120FG-BK). This 150x160x86 mm PSU features six independent +12V rails and a rated efficiency of 80 per cent. Apart from the usual plethora of connectors PSUs of this range are expected to have, it features two 8-pin auxiliary power connectors for multi-CPU socket desktop and workstation boards. It features a total of nine 6-pin PCI-E power connectors with six of them capable of doing 8-pin with a side 2-pin expansion that's detachable. Akasa provides a cable-management kit in the package, no modularity was advertised. The power distribution diagram is provided below. The PSU is priced at £189.95 or €240 (excl. VAT).
1,034 (0.15/day)
System Name Beatle _ Juice
Processor Ryzen 5 3600 X (oc 4,2 ghz) 1.325v
Motherboard Asus Rog Strix B450 F
Cooling Noctua NH-U14S (twin fans)
Memory 16 gb 3200 Mhz Kingston Hyper X (CL15-18-18)
Video Card(s) ASUS Nvidia Cerberus Gtx 1070ti
Storage Samsung 860 EVO 250 GB / Samsung F3 1TB / Kingston A400 240 GB
Display(s) Asus 27 " MG279Q ips 140hz
Case Cooler Master ATCS. 840
Audio Device(s) On Board
Power Supply Seasonic 650W Focus
Software Windows10 Home Premium 64bit
Specs wise it looks like a nice piece of kit......
46,362 (7.68/day)
You can haz 1337 Skulltrail + 4x HD4870 rig. :)
6,560 (1.07/day)
System Name Vintage
Processor i7 - 3770K @ Stock
Cooling Scythe Zipang II
Memory 2x4GB Crucial DDR3
Video Card(s) MSI GTX970
Storage M4 124GB SSD// WD Black 640GB// WD Black 1TB//Samsung F3 1.5TB
Display(s) Samsung SM223BW 21.6"
Case Generic
Power Supply Corsair HX 520W
Software Windows 7
That sure is going to the extreme side of things. just how much do you reckon they'll sell?
4,378 (0.69/day)
Hurst, Texas
System Name The86
Motherboard ASROCKS B450 Steel Legend
Cooling AMD Stealth
Memory 2x8gb DDR4 3200 Corsair
Storage WD Black 512gb, WD Blue 1TB
Display(s) AOC 24in
Case Raidmax Alpha Prime
Power Supply 700W Thermaltake Smart
Mouse Logitech Mx510
Keyboard Razer BlackWidow 2012
Software Windows 10 Professional
as soon as i win the lotto ill go buy one lol
46,362 (7.68/day)
ShadowFold
16,918 (2.84/day)
Omaha, NE
System Name The ShadowFold Draconis (Ordering soon)
Processor AMD Phenom II X6 1055T 2.8ghz
Motherboard ASUS M4A87TD EVO AM3 AMD 870
Cooling Stock
Memory Kingston ValueRAM 4GB DDR3-1333
Video Card(s) XFX ATi Radeon HD 5850 1gb
Storage Western Digital 640gb
Display(s) Acer 21.5" 5ms Full HD 1920x1080P
Case Antec Nine-Hundred
Audio Device(s) Onboard + Creative "Fatal1ty" Headset
Power Supply Antec Earthwatts 650w
Software Windows 7 Home Premium 64bit
Benchmark Scores -❶-❸-❸-❼-
Why do they make 6+ +12v rails? I thought a single rail was better for multiple card setups..
144 (0.02/day)
Norway
System Name "That computer next to my desk"
Processor Intel Core i5 - 12600K
Motherboard Asus Prime Z690-P WIFI D4
Cooling Be Quiet Dark Rock Pro 4
Memory 16GB (2x8) Corsair Vengeance LPX PC3200
Video Card(s) Gigabyte GTX 1070
Storage Samsung 980 PRO M.2 NVMe 1TB + 2TB Seagate SSHD + 4TB External Seagate HDD
Display(s) BenQ RL2755HM 27"
Case Fractal Design Define R5 Black
Audio Device(s) On board codec
Power Supply Corsair RM650i
Mouse SteelSeries Sensei Raw
Keyboard SteelSeries Apex 350
Benchmark Scores The scouter says it's over 9000
With 28A rails it shouldn't be a problem. If you distributed the load evenly across rails, multiple rail PSUs aren't really any less competitive.
46,362 (7.68/day)
To my knowledge, there still isn't a device that requires > 28A. Usually these multi-rail behemoths distribute their connectors across these rails. Note how the first two +12V rails are 20A. These rails usually are the ones that supply 12V phases to the motherboard, and maybe the Molex/Floppy and SATA connectors. Rails 3, 4, and 5 are 28A and the PCI-E connectors care likely the ones split across this. I predict in this fashion: Of the total 9 PCI-E connectors, 6 of them are 6+2pin. Each rail holds two of these at ~ 14A each connector. The remaining 3x 6pin (6 only-pin) connectors could have two of them sharing the last 20A rail and one 6-pin with either the 1st or 2nd 20A rail. Without any gfx card, 40A is a LOT of power for the system, even with dual-Yorkfield's installed + a 6-member RAID + brutal OC.
Now back to "why no epic single rail?" ....simple, it's expensive to manufacture a single strong rail, strong rails are unstable at times. But companies like Seasonic and TOPower have perfected the art, Seasonic makes a 40A rail circuitry that's used in the Corsair HX1000W (two 40A rails). So it makes sense with these 20A rails. Those rails with zero load turn off (unverified). Also it becomes easy to distribute power with these multiple rails, imagine four PCI-E connectors sharing a 40A rail.
Morgoth
Fueled by Sapphire
4,226 (0.69/day)
Netherlands
Motherboard aorus x570 pro
Cooling air (GPU Liquid graphene) rad outside case mounted 120mm 68mm thick
Storage 300gb hdd OS backup. Crucial 500gb ssd OS. 6tb raid 1 hdd. 1.8tb pci-e nytro warp drive LSI
Display(s) AOC display 1080p
Case SilverStone SST-CS380 V2
Mouse corsair gaming mouse
Keyboard Microsoft brand
gona buy this one 2 for my new system :D
WarEagleAU
Bird of Prey
10,812 (1.66/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
thats like $400
USD
46,362 (7.68/day)
$378.89 to be close. It's raining high-end PSUs today.
