All in one CPU+GPU water cooling kit
Discussion in 'General Hardware' started by ALMOSTunseen, Sep 29, 2012.
  1. Badelhas New Member
    Mar 26, 2012
    47 (0.03/day)
    1
    Braga, Portugal
    Correct. See www.overclock.net. I bought a 760GC and a 740GF but didn't installed them yet, still waiting for the vrm heatsinks.
  2. ALMOSTunseen
    ALMOSTunseen
    Sep 8, 2012
    833 (0.61/day)
    326
    Sydney, Australia
  3. Badelhas New Member
    Mar 26, 2012
    47 (0.03/day)
    1
    Braga, Portugal
  4. ALMOSTunseen
    ALMOSTunseen
    Sep 8, 2012
    833 (0.61/day)
    326
    Sydney, Australia
    Same username as here :). I never posted in there.
    I was just looking in that thread in regards to researching performance, and I noticed that that user was from Portugal, and had the same specs.
  5. Hood
    Hood
    Sep 25, 2012
    985 (0.73/day)
    334
    Where are you using the Peltier coolers? I hear they are inefficient and use a lot of power. Sounds like you want your rig really running cool - are you going for high overclocks?
  6. ALMOSTunseen
    ALMOSTunseen
    Sep 8, 2012
    833 (0.61/day)
    326
    Sydney, Australia
    The peltiers are being used as a chiller. 2 3/8 barbs on it, water goes in hot, comes out cold. The peltier plates are cooled with heatsinks. This was custom made by Zaqwsx-
    [​IMG]
    [​IMG]
    Yes, they can be inefficient and power guzzlers. It gets really hot in Australia in the summer, ambient's of 40C, meaning that radiators can sometimes not work at optimum performance. I am also going for high 24/7 overclocks, hoping for 5Ghz Stable 24/7(With turbo throttling).
  7. james888
    james888
    Jun 27, 2011
    5,479 (3.05/day)
    2,857
    You really don't need that much radiator space to get better than stock. Theres this guy an overclock.net who has a 2500k or 2600k with a gtx 670 overclocked on a single 120mm monsta radiator. He gets pretty good temps for better than stock.
    Crunching for Team TPU 25 Million points folded for TPU
  8. Hood
    Hood
    Sep 25, 2012
    985 (0.73/day)
    334
    Nice
    That thing is sweet! You should do 5 GHz easily, with coolant temps way below ambient. I like the way it's built. With decent airflow over the heatsinks, it should work great, and if it overheats it will only melt some plastic. Please let us know how it all works out and what your temps end up at.
    ALMOSTunseen says thanks.
  9. ALMOSTunseen
    ALMOSTunseen
    Sep 8, 2012
    833 (0.61/day)
    326
    Sydney, Australia
    Thanks, When I purchased the TEC chiller, it was love at first sight :p. I'll have a high RPM 140 Scythe fan on angled pull(So it get some airflow into my case), and a CM Sickle flow on push.
  10. RejZoR
    RejZoR
    Oct 2, 2004
    8,001 (1.88/day)
    2,552
    Europe/Slovenia
    Going way below ambient will cause condensation on components and thats not cool for electronics. You'll have to do extra insulation and protection of parts which you don't want to get into contact with water...
    10 Year Member at TPU
  11. ALMOSTunseen
    ALMOSTunseen
    Sep 8, 2012
    833 (0.61/day)
    326
    Sydney, Australia
    Already thought of that, this is why the wattage of the TEC's can be limited. I will be insulating if necessary though.
    More on topic-
    Been looking at some reviews, the 760GC seems to offer similar performance to antec Kuhler 620 mods on GPU's, despite the 760GC having a cpu to cool aswell.
  12. Badelhas New Member
    Mar 26, 2012
    47 (0.03/day)
    1
    Braga, Portugal
    Exactly. But what I am mostly after is a quiet computer. I tired of hearing vacuum cleaner when gaming.
  13. ALMOSTunseen
    ALMOSTunseen
    Sep 8, 2012
    833 (0.61/day)
    326
    Sydney, Australia
    Get some noctua's if the budget allows, or just get some Gentle Typhoons.
    Badelhas says thanks.
  14. Badelhas New Member
    Mar 26, 2012
    47 (0.03/day)
    1
    Braga, Portugal
    Yeah, thanks. I already have them ;-) bought one for each radiator, I hope one is enough for the 760gc, if not I'll just buy another one. I already gave :
    - asetek 760gc
    - asetek 740gf
    - 2x noctua nf-f12 PWM 120mm fan
    - arctic cooling MX 04 thermal paste (I read it might be worth replacing the one that comes applied on the asetek pumps)
    I am still waiting for ;
    - 2x arctic cooling VR004 heatsinks (since my gpu's are not reference model will have to cool Mosfet and ram)
    - 2x arctic cooling P9 PWM 92x25mm fan to blow some air to that area
    - 2x Gelid VGA to 4 pin PWM adapters (to connect the 92mm fans directly to the gpu)
    I surely hope everything works as it should, right now the top gpu gets to 96 degrees when gaming, I will report back when it's done.
    Check a review on the 760gc
    http://www.pureoverclock.com/Review-detail/pny-gtx-580-liquid-cooled-gpu-and-cpu/
  15. ALMOSTunseen
    ALMOSTunseen
    Sep 8, 2012
    833 (0.61/day)
    326
    Sydney, Australia
    I don't think you will be able to connect the fans directly to the GPU, as the asetek unit uses the GPU fan header for the pump block.
  16. Badelhas New Member
    Mar 26, 2012
    47 (0.03/day)
    1
    Braga, Portugal
  17. ALMOSTunseen
    ALMOSTunseen
    Sep 8, 2012
    833 (0.61/day)
    326
    Sydney, Australia
    That would probably be to plug into your CPU fan header, to view the current RPM of the pump.Just checked the manual, that is for you to plug in the Fan in that goes on the radiator.
  18. Badelhas New Member
    Mar 26, 2012
    47 (0.03/day)
    1
    Braga, Portugal
    I thought that also at first...but its a male connection!
  19. ALMOSTunseen
    ALMOSTunseen
    Sep 8, 2012
    833 (0.61/day)
    326
    Sydney, Australia
    Sorry if you didn't get the edited post? It's for the fan that goes on the radiator, fans have female plugs.
  20. Badelhas New Member
    Mar 26, 2012
    47 (0.03/day)
    1
    Braga, Portugal
    Where did you check the manual? Can you please post a link?
  21. ALMOSTunseen
    ALMOSTunseen
    Sep 8, 2012
    833 (0.61/day)
    326
    Sydney, Australia
  22. Badelhas New Member
    Mar 26, 2012
    47 (0.03/day)
    1
    Braga, Portugal
    Yeah, ur right! Thanks!
    I only ordered one fan for each rad to have the least possible noise but now I´m thinking that maybe I should have two on the 760gc, its a thicker rad that has to cool gpu+cpu, whats your opinon?
  23. ALMOSTunseen
    ALMOSTunseen
    Sep 8, 2012
    833 (0.61/day)
    326
    Sydney, Australia
    The power of google....... Well, Mr Mendes, I don't think that push/pull would make a considerable difference, as the radiator does not have a high FPI to my knowledge.. Although it may make some difference(Maybe a couple degrees?), and if I was you, I would be doing push/pull.
  24. Badelhas New Member
    Mar 26, 2012
    47 (0.03/day)
    1
    Braga, Portugal
    How did you know my last name?
  25. ALMOSTunseen
    ALMOSTunseen
    Sep 8, 2012
    833 (0.61/day)
    326
    Sydney, Australia
    I am very sneaky :laugh:. I did a search for push-pull on the 760gc, as I was looking for information, and a youtube comment showed up, I check the channel, and it just happened to be that user was about to watercool 2 570's. youtube user/tonebadalhoc
