Alright so i need a little help
Discussion in 'General Hardware' started by crazyeyesreaper, Mar 10, 2011.
  1. crazyeyesreaper
    crazyeyesreaper Chief Broken Rig
    Mar 25, 2009
    8,241 (3.72/day)
    2,893
    04578
    hmm nothing new to report. guess ill have to actually use my PS3... thats a scary thought first time it will be fired up in 7months lets hope that dosent shit out on me to lol
  2. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,419 (6.57/day)
    4,495
    Youngstown, OH
    The -13v is ALMOST out of spec (-13.2v max) . Definitely psu.
  3. streetfighter 2
    streetfighter 2 New Member
    Jul 26, 2010
    1,658 (0.96/day)
    732
    Philly
    For the ATX2.2 spec the -12V tolerance is 10% (±1.2V) or 10.8V-13.2V. (source)
    The -12V carries pretty low current and it's often subject to serious fluctuations (IIRC). My -12V is currently reading -8.51V in CPUID HW Monitor :roll:. The -12V carries a low enough current that you might not even get an accurate reading using a standard digital multimeter.
    It's never a bad idea to put the +12V and +5V on a multimeter to verify the software/BIOS readings. Unfortunately that won't detect ripple, but I'm betting you don't have an oscilloscope anyhow.
    If the PSU is out of warranty I'd open it up. There's usually only 4 screws to open a PSU and if you peek around inside you might find a leaky capacitor or some charred area on the PCB, but probably not.
  4. crazyeyesreaper
    Mar 25, 2009
    8,241 (3.72/day)
    2,893
    04578
    still under warranty but theres a serious chance its not the PSU causing the problem, so really just need a 750w unit with 2 6pins and 2 8pins to test for a day.
  5. fullinfusion
    fullinfusion 1.21 Gigawatts
    Jan 11, 2008
    8,602 (3.24/day)
    2,375
    Ray! you ppl in the USA have bad power Period!!! You need to get a suppressor like what Erocker and I use. Spend a few bucks and grab a UPS power back up *AKA* Surge suppressor...
    It Keeps the line voltage at a constant no matter whats coming into your home from the line, and will give you better stable system clocks.
    Think about it! It's worth every penny plus+++
    :slap:
    If I had a spare Id gladly lend it to you bro...
    Guys, this guy is for real ppl ... Help a bro out plz :p
    Jack Doph says thanks.
  6. mlee49
    mlee49
    Dec 27, 2007
    8,501 (3.18/day)
    2,108
    Kansas City
    Well, send me your address and I'll help ya out. :)
Share This Page
