Annoying Win7 problem, please help!
Discussion in 'General Software' started by mizzl, Dec 3, 2009.
  1. mizzl New Member
    Oct 25, 2009
    51 (0.02/day)
    0
    Dear TPU
    I have a very annoying problem with my computer. Whenever I watch a video/listen to music/play a game, my computer stutters at random moments. I.e. it freezes for a half second and then resumes. I'm sure you've heard of this problem before, but it seems really hard to find an answer on the internet so I'm asking you: please help!
    (specs: check my sig)
  2. Kenshai
    Mar 2, 2008
    1,646 (0.57/day)
    218
    Raleigh, North Carolina
    This is most likely dealing with your codecs. Trying downloading cccp or these are pretty good, there are 64 bit versions of it I'd recommend trying to do this first.
  3. mizzl New Member
    Oct 25, 2009
    51 (0.02/day)
    0
    Thanks. Trying out now. What exactly is the problem with my codecs?
  4. r9
    r9
    Jul 28, 2008
    2,144 (0.78/day)
    284
    For a moment I said to my self this got to be some PIII system :D. Clean OS install with latest drivers would be nice too :D. Just to be sure I would do some hour of Prime with close watch on CPU temp and PSU voltages then some memtest. But as I said I would start with clean OS install if Kenshai solution wont help.
  5. mizzl New Member
    Oct 25, 2009
    51 (0.02/day)
    0
    The funny thing is, my comp withstands a 17h long Prime95 torture test, but can't play a video without stuttering. Ironic really.
    Also, I REALLY want to avoid reinstalling windows. That would suck :(
  6. Easy Rhino
    Easy Rhino Linux Advocate
    Nov 13, 2006
    14,079 (4.17/day)
    3,901
    like someone else mentioned, you most likely need new updated codecs. also, if you aren't already, use vlc.
  7. mizzl New Member
    Oct 25, 2009
    51 (0.02/day)
    0
    I ONLY use VLC, so that's no prob. What's the prob with the codecs and stuff though?
    (3mins left till download finished)
  8. Easy Rhino
    Nov 13, 2006
    14,079 (4.17/day)
    3,901
    what kind of media file is it? x264?
  9. mizzl New Member
    Oct 25, 2009
    51 (0.02/day)
    0
    WTF?
  10. DaveK
    DaveK
    Oct 7, 2008
    1,889 (0.71/day)
    145
  11. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.32/day)
    573
    New York
    How long ago did you install the OS...did you install the mobo drivers?
  12. mizzl New Member
    Oct 25, 2009
    51 (0.02/day)
    0
    I installed it a month ago and i downloaded and installed all the latest chipset drivers. This really seems to be a driver-oriented problem, doesn't it?
  13. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.32/day)
    573
    New York
    did you optimise any windows settings?.......
  14. mizzl New Member
    Oct 25, 2009
    51 (0.02/day)
    0
    Does not compute :confused:
  15. DRDNA
    DRDNA
    Feb 19, 2006
    4,805 (1.32/day)
    573
    New York
    That probably means no....what is the extention of the video files? example video.avi
    the .avi is the extention.
  16. mizzl New Member
    Oct 25, 2009
    51 (0.02/day)
    0
    Well it depends. Sure I play avi's but i also play other types. And it also happens in games and in listening to music
  17. Solaris17
    Solaris17 Creator Solaris Utility DVD
    Aug 16, 2005
    18,049 (4.72/day)
    4,304
    Florida
    when you listen to music is it the music that stutters? or the visualization?
    make sure your vid card drivers are upto date.
    10 Year Member at TPU 2 Million points folded for TPU
  18. DirectorC
    DirectorC New Member
    Nov 4, 2009
    1,624 (0.71/day)
    268
    Florizy
    VLC is aged and featureless, and not as compatible with Win7 as MPC Homecinema.
  19. human_error
    human_error
    Nov 10, 2008
    1,847 (0.70/day)
    603
    VLC works perfectly in windows 7, i've not seen any compatability issues.
    OP have you run a defrag on your hard drive to make sure it's not really fragmented as that could cause some random pauses (also make sure your power setting doesn't allow turning hdds off after a certain time of inactivity as that could be causing problems if it stutters if you leave it alone for a few mins then try to do something).
  20. DirectorC
    Nov 4, 2009
    1,624 (0.71/day)
    268
    Florizy
    By not as compatible I mean it doesn't use the Vista/7 rendering system as well as MPC[HC] does, not that there are problems.
  21. Boyfriend New Member
    Nov 30, 2008
    160 (0.06/day)
    34
    1. Disable DXVA in ATI drivers and then see if it makes difference.
    2. Uninstall all codec packs and then try to play some H.264, WMV or AVI file.
    3. In WMP reset all setting, or use default program from control panel.
    4. Uninstall graphic card drivers and reinstall up to date driver. Also check out any optional Windows Update for your hardware. Rate your computer performance (WEI).
    5. Try different media players.
    6. Reinstall OS (Best and last option)
  22. mizzl New Member
    Oct 25, 2009
    51 (0.02/day)
    0
    Ok. So I've noticed the stuttering only happens a few hours after I started up my computer. I also tweaked the settings in the BIOS and it stutters alot less now. Suggestions, anyone?
  23. Solaris17
    Aug 16, 2005
    18,049 (4.72/day)
    4,304
    Florida
    you havent answered any of our questions?
  24. mizzl New Member
    Oct 25, 2009
    51 (0.02/day)
    0
    Well, you guys are all focusing on codecs, but you *seem* to forget that it also happens while gaming. Amirite?
  25. temp02 New Member
    Mar 18, 2009
    493 (0.20/day)
    166
    So you mean that the computers stutters when it's CPU is stressed (demanding application running)?
    Then why did you start the topic talking about video problems?
    Anyway, the most probable cause will be the CPU overheating and start to throttle.
    Check you system operating temperatures by using some of the programs on the TPU SysInfo downloads section.
