PuMA
I decided to re-format and partition my HDD and nothing changed.
My AMD motherboard has arrived, now I just have to wait for the CPU then do some bench comparisons and gaming comparisons.
I think my new CPU will piss all over the the current one considering the AMD64 X2 4800+ 939skt is somewhere aorund the levels of a decent PentiumD or so I've read.
If the games play around the same quality as my mates rig I'd be happy
Mates Rig:-
Pentium D 945 3.4Ghz Pressler
2X 1GB DDR667mhz Dual Channel
7600GT 256mb PCI-E
Some mid range Gigabyte SLi motherboard
My rig by next week:-
AMD64 X2 4800+ @2.4Ghz
2X 1GB DDR400 Dual Channel
X1950pro 512mb AGP
ABIT AV8 3rd-eye
yes that rig will run all the games fine+ u got ati card so GFX are awesome with it.
the performance gain that I had for reformatting was mainly because I hadn't formatted in awhile, so everything runs better with fresh format. Sorry that ur partioning didnt work, but with that proc u can run recent games probly with everything maxed(and with 512mb u can up the res aswell)
I'm waiting to get my 2x512 mem, I allready now that It helps with the games.
BTW: im on 939 just like u.
u can't really compare intel and AMD. Intel has higher clock frequency, but AMD's handle memory allocations much better+ some other advantages that i dont remember.
To put it this way: Pentium for running aps and AMD for gaming (tough the new core2 will perform better in games nowdays)
just a little Q: Am I able to run my mem in dual channel (2x512mb vm green and 2x512mb tranced ram)???? They are matching pairs
