Antec Fusion Case Help
Discussion in 'System Builder's Advice' started by bettz, Oct 22, 2012.
  1. ron732
    ron732
    Jun 25, 2010
    232 (0.16/day)
    89
    Jersey Shore
    Hey bettz I don't think you have the wires in question connected correctly. The connector with red and black wires labelled M/B PWR GND has to connect to the mobo PWRSW header. The arrow in the picture points to the PWRSW header where you already have something connected. I assume that the black & white wires are from the cases on/off switch. The +5V/GND pins are part of the 4 pin header for the speaker so you shouldn't be connected there.
    [​IMG]
    The red & black wires connect to the PWRSW header on the mobo and the black & white wires get attached to a header on the back of the LCD display board. Should look something like this. If this doesn't help with powering on, using the mobo & case manuals I would re-check all of the connections you made hooking things up during the build. Also have you tried your PSU in your Dad's sytem?
    [​IMG]
    While not the ideal solution you can get away with using a 2 molex to 8 pin adapter as long as you connect the molex connectors to different 12V rails on the PSU. You should really be using a newer PSU that has an 8 pin EPS +12V connector.
  2. bettz New Member
    Jan 26, 2009
    193 (0.10/day)
    1
    The 3 wires that are connected via the header are labelled hdd led,pwr & reset. The two plugs that are confusing me Gnd & Mb/Pwr do these connect into the back of the LCD screen? Is that what you meant? I can't find any other place on the motherboard where they would go
    I've given uP with the psu it's been binned!! I've a be quiet one that I've ordered also had to buy a 3 pin to 4 pin molex as the antec psu had a 24 pin + 3 pin cable which I think powers the LCD screen hoping I can just use the 3 pin to 4 pin molex for that
    I've just found this thread http://www.avforums.com/forums/computer-systems/727089-antec-fusion-wires.html
  3. ron732
    ron732
    Jun 25, 2010
    232 (0.16/day)
    89
    Jersey Shore
    Where do the black & white wires that are already on the mobo 2 pin pwr header come from? The manual says that the black & red wires from your case should connect to the mobo pwr header. Just out of curiosity have you tried using the remote to turn on the system. I have read that early Fusion cases would only allow you to turn on by either the front button or the remote but not both. Maybe the black & white is for the remote and the red & black is for the front button.
  4. bettz New Member
    Jan 26, 2009
    193 (0.10/day)
    1
    I'll get back to you on that one when I get back home.
    I've seen this diagram
    [​IMG]
    Also this which confuses me is this loss the old version antec case?
    [​IMG]
  5. bettz New Member
    Jan 26, 2009
    193 (0.10/day)
    1
    Right the Black & White wires that are in the PWR.SW header on the mobo look like they come from the Power button on the front of the case.The red & Black go to the reset button on the front of the case so they both look ok? The 2 single pins MB/PWR & GND come from the lcd screen :confused::confused: along with the 3 pin that goes into the psu
Share This Page
