Any way to manually change CPU fan speed?
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Processor FX-6300 @ 4.43GHz (1.35v)
Motherboard Gigabyte GA-970A-DS3 rev 1.0 (F6)
Cooling Cooler Master T2 + x2 case fans
Memory 2x4Gb Crucial Ballistix Sport DDR3-1600 (Stock)
Video Card(s) Gigabyte GTX650 Ti OC 2Gb @ 1110/1500
Storage Corsair 240Gb SSD / Seagate 500Gb HDD + old skool IDE HDD's x 3
Display(s) Acer 23'' LED
Case Billy Basic
Audio Device(s) Onboard 8.1 HD
Power Supply Corsair CX600
Benchmark Scores Smenchmarks
I like doing the odd good deed! :rolleyes:
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
yeah for alcapone you saved casheti now what a nice person :D
and im alcpone not alcapone, that names already been taken al capone lol
cdawall
where the hell are my stars
27,680 (4.29/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
In the post tomorrow, no worries at all! :toast:
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
Casheti
4,421 (0.68/day)
Oh you'd be surprised at the amount of binge drinking, chain smoking, sleeping-around hoes you get around here....there's roughly 200...and they're mostly 15 :D HOES!!
Quote girl in math class
Me - "If you had ÂŁ1000 what would you spend it on"?
Girl - "Fags and booze"
THAT ACTUALLY HAPPENED IN MATH CLASS!! Then she said she would do lesbian porno for ÂŁ1000 so I got talking about that for a long time...
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
Well atleast you wont catch anything, you wont damage your internals and you can save the money you do get for components etc!
Well im gonna watch goldplated and have a ciggy (im 26 so im aloud)
:cool:
Casheti
4,421 (0.68/day)
I will never drink or smoke, EVER!! And yeah, okay, go watch goldplated and have your "ciggy" :D Thanks again dude...
Casheti
4,421 (0.68/day)
Tried those cables you sent :D Works very well with the case fans. How can I get one to work with my CPU fan?
Deleted member 24505
i just got this alloy cased fan and it has a widget for adjusting the speed.
Casheti
4,421 (0.68/day)
Looked all over eBay for something to split my 4 pin CPU fan into a molex...looks like it's gonna be a manual job. What have I got to do?
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
Plug it in lol remember on your cpu connection it has to groves on the white bit on the end, they have to line up with the groves on the adaptor, remember the blue wire will remain unconnected, that is just for varying the speed, which you wont be doing because you want it running flat out!
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
Woah woah woah hold up...so all this time I could have just cut the freakin' blue wire...:twitch:
:laugh: suppose now you say that you probs could of, well atleast this way if you ever sell your cpu for a upgrade you can sell it with intact hsf that has'nt been fucked with!
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
Eeee you know what it is some people are never happy, try and do someone a favour :rolleyes:
Casheti
4,421 (0.68/day)
lol? Still idle's roughly 46*C with side on...time for a tank cut in the side panel and fit in a 120mm right in front of the CPU fan followed by some AS5. Then I have to work on getting these stupid GPU temps down :D
2,341 (0.37/day)
Tyne & Wear, UK
System Name AMD '13
Case Billy Basic
I would love to hear how loud your rig is now lol, with another 120mm running flat out will make it that little bit louder again!
Just get some as5 now and make sure you clean all the crap off first then you will see the temps drop gradually over 200 hours maybe get another 5*c off!
Anyway im off to my girlfriends so happy temp cooling you postwhore lol
:rockout:
7,195 (1.12/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
@casheti
take it easy on your cooling stress! OMG. A CPU is very very happy to idle at 40-50C and it will do you no harm. Once the thing begins to really do some work, it will get hotter, and the auto fan will kick in. ITS REALLY NO PROBLEM.
Water cooling is to keep the maximum temperature down to do some overclocking. Although people like quoting their "idle" temps... it really is irrelevant.
REMEMBER THIS: A 30C CPU at 3GHz is NO FASTER than a 40C CPU at 3GHz.
Relax with all this cooling melarky!
REMEMBER THIS POINT #2: An air cooled CPU can never be cooler than the air cooling it! That means you don't need to worry about your CPU idle temps, but you CASE idle temps. And that's why your idle temp is going up with the case on. So make sure you have a decent PSU that sucks air out... and DRILL SOME HOLES in the bottom of the case to let more air be drawn in from the bottom.
You can also have a fan at the back, near the CPU also drawing air out. Make sure the CPU fan is working WITH and NOT AGAINST the case fan!!!! (So many people dont even check this).
There is no need to put fans in the side of the case. It's like getting a sledgehammer to open a screw. Its the wrong tool in the wrong place.
