Are there Fans with more than 7.7 in H2O?
Discussion in 'Overclocking & Cooling' started by RCoon, Jun 13, 2013.
  1. m1dg3t
    m1dg3t
    May 22, 2010
    2,255 (1.01/day)
    518
    Canada
    Didn't check the link but, yes. A 40mm shaft with 8mm thread = 48mm total length. This may be to "long" for your application so i'd pay close attention when/if installing
  2. cdawall
    cdawall where the hell are my stars
    Jul 23, 2006
    22,674 (6.25/day)
    4,153
    Houston
  3. RCoon
    Apr 19, 2012
    10,869 (7.10/day)
    8,650
    Gypsyland, UK
    As 43mm (hell even 45mm) screws are insanely difficult to get hold of, I'll need 6-32 screws with a 2" length, and just use washers to fill the gap discrepancy. Anyone else got advice on screws to use?
  4. cdawall
    Jul 23, 2006
    22,674 (6.25/day)
    4,153
    Houston
    They do not have corners run a short screw through just the side that attaches to the radiator and use standard grill screws for the grill side.
  5. RCoon
    Apr 19, 2012
    10,869 (7.10/day)
    8,650
    Gypsyland, UK
    What doesnt have corners? There are no screw holes in the corners of the nidecs?
    In that case what length 6/32 screws will i need to penetrate through the plastic and fit snugly against the radiator?
    EDIT: Ordered 2 fans and 2 pwm connectors. Just need the right 6/32 screws.
  6. cdawall
    Jul 23, 2006
    22,674 (6.25/day)
    4,153
    Houston
    Here is a picture the red boxed area is what I mean by an open corner fan.
    [​IMG]
    You would only use one side of the corner to mount the fans and put the screwdriver through the hole above the screw. I use I want to say 6mm long screws to do this.
    RCoon says thanks.
  7. RCoon
    Apr 19, 2012
    10,869 (7.10/day)
    8,650
    Gypsyland, UK
    Cheers, 6mm 6/32 it is.
    Which just so happen to be standard case screw size?!
  8. niko084
    niko084
    Dec 5, 2006
    7,637 (2.19/day)
    729
    Reason push/pull isn't an option?
  9. Law-II
    Law-II
    May 9, 2011
    1,854 (0.99/day)
    861
    Mainland Britain
  10. douglatins
    douglatins
    May 15, 2008
    2,869 (0.97/day)
    273
    Brasil
    ou havent hear deltas at full blast then.
    Are you def? Then i would understand that statement
  11. Assimilator
    Assimilator
    Feb 18, 2005
    873 (0.21/day)
    274
    South Africa
    Agreed. I'd suggest OP watch some YouTube vids on the Deltas so he can hear exactly how loud they are, before purchasing.
    10 Year Member at TPU
  12. RCoon
    Apr 19, 2012
    10,869 (7.10/day)
    8,650
    Gypsyland, UK
    So my fans arrived, stripped them, wired the 4 pin pwm connectors on according to an image on google, the image was wrong, and i messed up the connectors.
    SO! ordered 2 more sets of PWM connectors, can someone give me an image of pwm wiring with black/blue/red/yellow wires please?
  13. m1dg3t
    m1dg3t
    May 22, 2010
    2,255 (1.01/day)
    518
    Canada
    Black is ground -
    Red is +
    Blue *should* be PWM
    Yellow Vsense
    I think... Cooking a last bowl b4 crashing out... :eek:
    Do you have the stock HSF fan? Could use that no?
  14. FordGT90Concept
    FordGT90Concept "I go fast!1!11!1!"
    Oct 13, 2008
    17,986 (6.39/day)
    7,261
    IA, USA
    http://www.formfactors.org/developer\specs\REV1_2_Public.pdf
    Page 17:
    Pin Function Wire Color
    1 1 GND Black
    2 2 12 V Yellow
    3 3 Sense Green
    4 4 Control Blue
    I'd look at either Vantec Tornadoes or Deltas. The two key features to high pressure are fixed blades guiding the intake air in and a high amperage motor pushing it away.
    Crunching for Team TPU
  15. m1dg3t
    m1dg3t
    May 22, 2010
    2,255 (1.01/day)
    518
    Canada
    That is PWM spec pinout, the Delta fan he is modding is what is confuzzing... I think... Join the 2... Make cents?
  16. AsRock
    AsRock TPU addict
    Jun 23, 2007
    13,891 (4.22/day)
    3,428
    US
    HAHA, yeah those Pana fans can be dangerous to you and them selves.
    If i want make sure some thing gets cooled the Delta fan and the PANAflo should get the job done.
    Might want to look in to 120x120x38mm size as they push even more air if you have the space that is..
    The panaflo i had was the Rexus NMB-MAT and due to human error ( yes me lol ) it stripped 3 blades off and it had previously cut my finger in the past..
    EDIT:
    Best make sure you don't have it in reverse either or you be dog meat.
  17. de.das.dude
    de.das.dude Pro Indian Modder
    Jun 13, 2010
    8,091 (3.67/day)
    2,210
    Pune
    delta/other industrial fans should do the trick. i got some panaflow fans for cheeeeeeeap.
  18. RCoon
    Apr 19, 2012
    10,869 (7.10/day)
    8,650
    Gypsyland, UK
    I could do with an actual picture, which way around do you have the female PWM plastic facing when you wire the cables in? flat facing up or down?
    [​IMG]
    [​IMG]
    This is the image i followed, is it right? Other images are different.
    [​IMG]
  19. FordGT90Concept
    Oct 13, 2008
    17,986 (6.39/day)
    7,261
    IA, USA
    [​IMG]
    Pin 4 is the one that is added on (PWM). Pin 1-3 correspond with the guide for the 3-pin connector (12V, GND, and speed/tach).
    The pic you got is backwards (guides are on the wrong side and just wrong).
    RCoon says thanks.
  20. ne6togadno
    ne6togadno
    Mar 15, 2013
    2,266 (1.89/day)
    1,528
    GMT +2
  21. de.das.dude
    Jun 13, 2010
    8,091 (3.67/day)
    2,210
    Pune
    this ^
    also if you follow the wires to the fans centre, you will see that its been labled there as well.
    with plus minus etc.
  22. RCoon
    Apr 19, 2012
    10,869 (7.10/day)
    8,650
    Gypsyland, UK
    Cant see the wires to the fan's centre because the plastic guides are glued on to the rear of the fan where the PCB is.
  23. de.das.dude
    Jun 13, 2010
    8,091 (3.67/day)
    2,210
    Pune
    yes, the sticker is there right? it should be there on the sticker.
    here s the pic
    [​IMG]
    [​IMG]
    and the label.
    usually the color scheme is the one as the top picture.
    note that the positive wire is on the outside on the fan, but on the inside on a 3pin jan jack.
  24. RCoon
    Apr 19, 2012
    10,869 (7.10/day)
    8,650
    Gypsyland, UK
    Nope.
    [​IMG]
  25. FordGT90Concept
    Oct 13, 2008
    17,986 (6.39/day)
    7,261
    IA, USA
    If you haven't figured it out yet, a fan only really needs red and black. Stick a 9V battery on them and see what happens. XD
