Are these parts compatible?
Discussion in 'System Builder's Advice' started by x_Stricken_x, Sep 18, 2012.
  1. eidairaman1
    Jul 2, 2007
    14,398 (4.58/day)
    2,133
    You mean the SATA Data Cables?
    SATA Data Cables normally come with hard drives/ Solid State Drives or Motherboards.
    SATA power cables come with the Power Supply.
    Molex to SATA Power adapters come with Motherboards Normally.
    UEFI is the "New BIOS" It is a Graphic User Interface to adjust settings of the motherboard
    x_Stricken_x says thanks.
  2. x_Stricken_x New Member
    Sep 18, 2012
    46 (0.04/day)
    8
    Yeah, I did mean the SATA data cables haha. So basically the setup is good to go, I just need to order the stuff and assemble? Like I don't need to buy any extra cables or anything?
  3. eidairaman1
    Jul 2, 2007
    14,398 (4.58/day)
    2,133
    Just to be on the safe side You may want to get another SATA Cable, most motherboards only come with 2 in the pack.
    OEM Optical and HDD/SSD dont normally come with Cables.
    Before you do let me see if i can get a pack list for that specific motherboard
  4. x_Stricken_x New Member
    Sep 18, 2012
    46 (0.04/day)
    8
    Alright :) Also, I updated the first post with everything I have right now if you wouldn't mind reviewing it :)
  5. eidairaman1
    Jul 2, 2007
    14,398 (4.58/day)
    2,133
  6. x_Stricken_x New Member
    Sep 18, 2012
    46 (0.04/day)
    8
    Alright, awesome! :D And I don't think I'll be adding more drives. I already have a 2TB external hard drive, so if I somehow start running out of room on the internal one I can just move some files :)
  7. eidairaman1
    Jul 2, 2007
    14,398 (4.58/day)
    2,133
    Well the machine looks good actually so fire away.
    keep us updated on this build too
    If you have issues just ask away.
  8. x_Stricken_x New Member
    Sep 18, 2012
    46 (0.04/day)
    8
    Awesome, thank you so much for the help! :) And I'll definitely be posting some pics and stuff of the build and such once it's done :)
    eidairaman1 says thanks.
  9. eidairaman1
    Jul 2, 2007
    14,398 (4.58/day)
    2,133
    :toast:
    Have fun with the build, take your time. That's what we are here for
  10. Jetster
    Jetster
    Jan 17, 2010
    7,331 (3.31/day)
    3,749
    Oregon
    That should be everything you need. Definitely take you time. Google and youtube are are there for you and or course we are also
  11. x_Stricken_x New Member
    Sep 18, 2012
    46 (0.04/day)
    8
    Thanks so much guys, glad I finally found a forum where I actually get a reply - and thorough help! I'll definitely be stopping back here if I need help, I'll also recommend the forums to others as well :) And I should be good with building it, I've seen NewEgg's how-to on it; but if you guys know of some good videos/articles, feel free to link me! Thanks again!!
  12. Jetster
    Jetster
    Jan 17, 2010
    7,331 (3.31/day)
    3,749
    Oregon
  13. CJCerny
    CJCerny
    Nov 25, 2008
    914 (0.35/day)
    276
    Akron, OH
    Have you thought about just getting an Ivy Bridge CPU, like the 3570k, and an inexpensive Z77 motherboard to go with it? Doing so would save you more than $500 over what you currently have selected and not make much difference when it comes to gaming.
  14. Jetster
    Jetster
    Jan 17, 2010
    7,331 (3.31/day)
    3,749
    Oregon
    Good suggestion. Going with a 1155 board would still give you the power you need for gaming.
  15. eidairaman1
    Jul 2, 2007
    14,398 (4.58/day)
    2,133
    Read this for a first time builders rule: (Happens to everyone- just preventive measure)
    http://www.computerhope.com/esd.htm#02
    (Do not touch contact leads/pads/pins)
    Some Rules of Computer building
    1. Read the motherboard and other manuals first
    2. Use Proper Screw Driver (stripped or over tightened screws bite)
    3. Use proper size screws for every component (Screws for Mobo, SDD/HDD, Optical drive, Video card, Power Supply, Case Panels are different)(Screws for Power Supply, Video card and Case Panels are normally the same)
    4. Before Powerup Reset the CMOS/BIOS/UEFI (ensures motherboard is at failsafe/default setting- helps with first boot)
    5. Get all Necessary latest drivers from hardware manufacturers (Device Dependent, Asus, Intel, AMD, Realtek)
    6. Update Bios/UEFI from board maker (Asus) before Windows install.
    7. Before OS is installed ensure you only have your SSD plugged in not both hdd, once OS is installed plug in the other HDD. (Windows likes to put critical files on both drives when both are plugged in during the OS Install which can cause boot issues if a drive fails later on)
  16. Jetster
    Jetster
    Jan 17, 2010
    7,331 (3.31/day)
    3,749
    Oregon
    Why 5. Its easier to update the bios from windows. Just curious I know we all have our own preferences
  17. x_Stricken_x New Member
    Sep 18, 2012
    46 (0.04/day)
    8
    If I wouldn't gain anything, I don't see the point in saving the $500. It could just be a noob-ish thing, though, I'm not sure. I'll consider it, though.
    Thanks for that :) I knew most of them
    From what I saw on NewEgg, it doesn't necessarily make a difference before/after
    Jetster says thanks.
  18. eidairaman1
    Jul 2, 2007
    14,398 (4.58/day)
    2,133
    Bios/Uefi Updates cant be interrupted outside of windows less a power failure occurs, normally bios updates fail within windows, primarily provides for a clean environment.
  19. x_Stricken_x New Member
    Sep 18, 2012
    46 (0.04/day)
    8
    Are you talking about this, eidair?
  20. eidairaman1
    Jul 2, 2007
    14,398 (4.58/day)
    2,133
    lmao i guess so, thats something new for me, (on a AsRock Machine I built last year for my bro)
    This almost looks like what I used to do in the AF to an extent
  21. MxPhenom 216
    MxPhenom 216 Corsair Fanboy
    Aug 31, 2010
    11,401 (5.74/day)
    3,247
    Seattle, WA
    Why do you want 4GB of vram. It just adds more memory latency so the memory is slower on the cards with 4GB. And it really does not yield much better performance at higher resolutions. so you can buy a GTX680 2GB for the price of a 4gb GTX670 and the 680 is the better card regardless.
    Yeah the 7950/7970 scale well when overclocked. the 670/680 not so much.
  22. eidairaman1
    Jul 2, 2007
    14,398 (4.58/day)
    2,133
    he has already decided on the build
  23. MxPhenom 216
    Aug 31, 2010
    11,401 (5.74/day)
    3,247
    Seattle, WA
    I know, I just read his post saying link me to a 4GB GTX680 at that price and then I read that he has a 1440x900 resolution monitor and that 4GB of ram would be worthless.
  24. popswala
    popswala New Member
    May 29, 2009
    2,289 (0.94/day)
    954
    Conway, AR
    sata power is already on the psu. Sata data cables come with the motherboard
  25. x_Stricken_x New Member
    Sep 18, 2012
    46 (0.04/day)
    8
    In the future I probably won't be on a 1440x900 resolution, that's my current monitor's resolution. I do eventually have plans to get a new monitor/monitors, it's just at the bottom of the list right now as I just want to get the system built and running right now :) Thanks for the input though, I appreciate it!
