ASUS P8Z77-v pro/thunderbolt motherboard, BIOS problem. system wont start
Discussion in 'General Hardware' started by prestoopnik, Sep 18, 2012.
  1. prestoopnik New Member
    Sep 18, 2012
    4 (0.00/day)
    0
    so I'm building my first system and I got as far as the lights and fans turning on... when I turn the system on the fans and lights turn on(as previously stated) and the BOOT_DEVICE_LED turns on as solid red. As well as a single short beep which the manual says means the VGA is detected, quick boot is set to disable, no keyboard detected.
    my specs are:
    -ASUS P8Z77-v-pro/thunderbolt motherboard
    -cool master haf-x case
    -intel core i5-3570
    -MSI geforce 660 ti PE
    -cool master Silent Pro M 1000W
    -G.Skill trident X series 16gb(2x8gb) (placed in slots A2 and B2 as the manual suggested)
    -western digital 1TB caviar green
    -and i can't figure out exactly what my disc drive is
    I've looked up some possible solutions one being that my bios is outdated and doesn't support the chip I have set up in my motherboard. I tried doing a USB BIOS flashback but either it didn't work or I was doing it wrong which is very possible. However a lot of the other people who I saw who were having similar problems had the bios working when i turn my system on nothing comes up on the screen (which I have plugged into the DVI)
    On the ASUS website on their support page ( http://www.service.asus.com/#!Downloads/c1wax ) I looked at the BIOS updates and one says that it supports new CPUs. and if it is a new BIOS that I need how would I go about doing so?
  2. eidairaman1
    Jul 2, 2007
    14,167 (4.95/day)
    2,052
    normally when a chip is not supported out of the box, you normally have to use a older CPU actually to update the bios
    I hope no pins were damaged or burnt.
    I would honestly contact Asus and see what they have to say and maybe even put a review on newegg
Share This Page
