Basic Method For over clocking 2600k need info
GreenD
53 (0.01/day)
Australia, Rockhampton
Hey guys
I am very new to pc building in general, i know alot of the general information but im fairly limited when it comes to over clocking, my question is can anyone provide me with a fairly simple overview on how to OC a intel core i7 2600k to around 4.2 ghz stable, i Dont really want to push it and shorten the lifetime of my cpu
I will either be using a
Asus Sabertooth motherboard
ASRock Z77 Extreme6 Motherboard
Thermaltake tough power 775w
Enermax ETD-T60-TB CPU Cooler
or a cooler than you can recommend i have a height limitation of like 155mm for a cooler
Thanks
cadaveca
My name is Dave
17,232 (2.62/day)
Hey guys
Just set the multi. You could probably lower voltage, but you'll have to test for that. The motherboard will take care of the rest.
GreenD
53 (0.01/day)
What did you do for your OC, i want mine running at a fairly decent speed with not much damage, i dont really care about pushing it as far as it can go
2,894 (0.50/day)
South Carolina
System Name KILLER
Processor Intel Core i7 4790K
Motherboard MSI Z87 G45 Gaming
Cooling Water Cooling
Memory 2x8GB Gskill 2400mhz
Video Card(s) EVGA GTX 980
Storage SSD Samsung 500GB
Display(s) 24" Asus 144hz
Case Cooler Master HAF
Audio Device(s) X-Fi Platinum
Power Supply Antec 1200 Watt Modular
Software Windows 10 64 Bit
Benchmark Scores 3DMark Vantage 51342
Just go into bios and set your multi to 42.
Thats it.
818 (0.16/day)
Nairobi, Kenya
Processor Intel Core i7-14700K
Motherboard ASUS ROG STRIX Z790-H
Cooling DeepCool AK500 WH
Memory Crucial Pro 32GB Kit (2x16GB) DDR5-5600 (CP2K16G56C46U5)
Video Card(s) Intel ARC A770 Limited Edition
Storage Solidigm P44 Pro 2TB / Solidigm P44 Pro 2TB / PNY CS3140 2TB
Display(s) Philips 32M1N5800A
Case Lian Li O11 Air Mini (White)
Power Supply Seasonic Prime Fanless Titanium 600W
Keyboard Dell KM714 Wireless
Software Windows 11 Pro x64
GreenD
53 (0.01/day)
Was it supposed to be complicated?
I basically assumed lol, whenever i see others over-clocking their changing loads of settings in their BIOS
818 (0.16/day)
Nairobi, Kenya
It appears so,.. I haven't overclocked any of my Processors yet. Maybe I'll try soon when i decide to buy a decent cooler
9,795 (1.90/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
yeah, start from multiplier first
dont push it too far, try about 10% first then check the stability
then if you want try to raise little by little
if after you oc it theres something that run not right like fail start just reset your bios
GreenD
53 (0.01/day)
What software could i run to really push the tests and make sure that it wont crash even in the worst circumstances?
