Battery issue
Discussion in 'General Hardware' started by @RaXxaa@, Aug 15, 2009.
  1. @RaXxaa@ New Member
    Jun 29, 2009
    473 (0.21/day)
    20
    Pakistan & US
    Hello everyone, this is my post in a lng tym.... anyway i have noticed my battery in de laptop is fully chrgd to 98% nvr 100 arnd a week ago till nw... i dnt knw why but i think i need to recalibrate... its an asus g71, well bios had an option but it so slow and doesnt have a progress bar sumthng makes me impatient so i nvr tried it after 2 tyms b4 where i shut it dwn in the process, any help, guide wud be appriciated frm u all...
  2. erocker
    Jul 19, 2006
    40,705 (12.32/day)
    15,562
    Completely drain the battery, run the laptop on battery power untill it powers down, then charge the battery.
  3. @RaXxaa@ New Member
    Jun 29, 2009
    473 (0.21/day)
    20
    Pakistan & US
    Its Li-on battery and many sites say u shudnt apply tht method to li-ion batteries as it also shorten lifespan on de battery.... so i dunno cnt find anythng else?
  4. twicksisted
    twicksisted
    Oct 4, 2007
    2,438 (0.85/day)
    350
    a battery will degrade over time... sh*t happens
    but yeah your best bet would be to fully discharge the battery a couple of times with a solid recharge... and hopefully it will make it last longer for the mean time.
  5. Bundy
    Bundy
    Oct 27, 2007
    1,123 (0.40/day)
    157
    You should try the full discharge and recharge as suggested and if that doesn't work, then re calibrate.
    Do not leave it at 98%, otherwise you will damage the battery because you are overcharging.
Share This Page
