Can you split the 4 pin 12vATX to 2x2 pin 12vATX connectors? ( 6950/Power supply )
Discussion in 'Cases, Modding & Electronics' started by Saakki, Sep 20, 2011.
  1. Saakki
    Saakki New Member
    Mar 3, 2008
    301 (0.10/day)
    24
    Finland
    Okay so the problem is that my Antech Earthwatts 500w has only 2x 6 pin PCIE 12V connectors and 6950 DirectCU 2 need 6 pin AND 8 pin and bright people from ASUS did only give a 2 x molex to 6 pin converter with the card so I cannot plug in my new graphics card. And yes the 500w antec should be enough I have checked.
    So I have one 4 pin 12vATX connector like this: [​IMG]
    ,and I'm thinking about splitting it to two 2 pin 12vATX so I can fill the two holes that are left empty after connecting both 6 pin connectors to the graphics card.
    I couldn't find a answer anywhere that is this safe to do? Thanks! :pimp:
  2. cdawall
    cdawall where the hell are my stars
    Jul 23, 2006
    21,706 (6.22/day)
    3,562
    Houston
    no. they sell 6 pin to 8 pin converters look at one of those. be careful pulling that much juice off of one set of molex's .
    Saakki says thanks.
  3. Saakki
    Saakki New Member
    Mar 3, 2008
    301 (0.10/day)
    24
    Finland
    Can you tell me why it is not possible? ( Thanks anyways )
  4. HossHuge
    HossHuge
    Jun 26, 2008
    2,242 (0.81/day)
    723
    EDM, AB, CAN
    How about using something like this?
    [​IMG]
    Saakki says thanks.
  5. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,482 (5.99/day)
    4,522
    Youngstown, OH
    FYI; Those extra 2 pins in the 8 pin PCIe power connections are both Ground. Not a 12v + Ground.
    Saakki says thanks.
  6. Saakki
    Saakki New Member
    Mar 3, 2008
    301 (0.10/day)
    24
    Finland
    Ummph so the hell why does not the 6 plus 6 setup only work? Could it? ( And yeah I know those connectors exist but just wanted to know if that 4 pin could be utilized ..but apparently no.. :/ )
  7. JrRacinFan
    Mar 17, 2007
    19,482 (5.99/day)
    4,522
    Youngstown, OH
    That maybe a question as to possibly needing more current being pulled acrossed more connections.
    Get the couple 6 to 8 adapters and you will be set. :)
    Saakki says thanks.
  8. Saakki
    Saakki New Member
    Mar 3, 2008
    301 (0.10/day)
    24
    Finland
    Yeah Its only 2 euros so ordering one now. Thanks fellas!
  9. cdawall
    Jul 23, 2006
    21,706 (6.22/day)
    3,562
    Houston
    Like was said they are -12v's not +12v's not to mention pulling power off of you cpu's VRM's is a terrible idea even if they were +12v's. With your board pulling off of the EPS 8 pin that 4 pin pulls from the same location and is not designed to pull that kind of load.
    Saakki says thanks.
  10. Saakki
    Saakki New Member
    Mar 3, 2008
    301 (0.10/day)
    24
    Finland
    Yeah thanks for clearing those out..not gonna go "evil genious" on my PSU then. Will see if I get a new PSU or the converted because 500 antec is on the edge with overclocked 6950.
  11. cdawall
    Jul 23, 2006
    21,706 (6.22/day)
    3,562
    Houston
    no more so than what I run.
    Xeon X3440@4ghz
    2x2GB DDR3
    GB Mini ITX
    GTX 470 oc'd
    H70+ultra kaze
    450w SFX silverstone
  12. JrRacinFan
    Mar 17, 2007
    19,482 (5.99/day)
    4,522
    Youngstown, OH
    Doesnt the GTX470 consume even more power than the HD6950?
  13. FordGT90Concept
    FordGT90Concept "I go fast!1!11!1!"
    Oct 13, 2008
    17,086 (6.38/day)
    6,403
    IA, USA
  14. cdawall
    Jul 23, 2006
    21,706 (6.22/day)
    3,562
    Houston
    yup by a good smidge IIRC :laugh: however his Q6600 probably consumes more juice in every way shape and form than my little bitty chip.
  15. Arctucas
    Arctucas
    Jul 14, 2006
    1,834 (0.52/day)
    327
    The extra two conductors in the eight-pin are grounds, and in the case of the 6-pin to eight-pin adapter are connected to two of the existing three grounds. The do not supply any more ampacity, and, if I am not mistaken, simply are 'sense' connections.
    JrRacinFan says thanks.
