Case, fan controller, and cooler: help me choose
Discussion in 'System Builder's Advice' started by entropy13, May 23, 2012.
  1. entropy13
    entropy13
    Mar 2, 2009
    5,034 (1.98/day)
    1,272
  2. MT Alex
    MT Alex
    Aug 2, 2009
    3,980 (1.67/day)
    1,790
    I have a Rheobus-Extreme, I bought it because it had a higher watt per than most which made it good for my pumps. I've had it for damn near three years. It feels kind of cheap, the knobs get stiffer, almost sticky, after more use instead of looser, and the LEDs go out. Also, with all channels turned up it's really damn bright. That being said, it was pretty cheap (because it's cheaply made) and it regulates watts as it should.
  3. FreedomEclipse
    FreedomEclipse ~Technological Technocrat~
    Apr 20, 2007
    15,189 (4.72/day)
    3,284
    London, UK
    Sentry mix is a good one, I bought one and i never looked back.
    It is a little 'plasticky' though but that doesnt really matter as you cant see it once its mounted in the case.
    50watts per channel, what more can you ask for???
  4. nleksan
    Mar 26, 2012
    239 (0.17/day)
    36
    Ohio
    I have heard nothing but good about the sentry, and I am strongly considering it for my own build (if I can figure out how to mount pump, res, fan controller, and ODD in Switch 810 with a 360 or 30mm 420 rad).
