Case, Fan, Cooler Combo - Help Please!
Discussion in 'General Hardware' started by alexp999, Apr 6, 2008.
  1. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
    Okay, atm i have the case in my avatar. I noticed that when I was messing about with the side off, my CPU temp drops about 4-5*C. :eek: .
    What I'm thinking is that cus my cooler has the same fan orientation as the stock cooler, it needs a nice air supply directly inline with it on the side of the case.
    I am a bit worried cus when orthos had been running for 3hrs the cores were hitting 65*C. Now I know that it is 20*C away from cut off, but it is too high for my liking. So what I wanted to ask was, if I get this case:
    [​IMG]
    Is it better to leave the side panel with no fans and let the CPU cooler supply itself, or is it better to put a 120mm fan directly in line with the CPU fan. I read a thread the other day asking whether two fans inline are better than one, and it was agreed that the fans would be out of sync and do worse than a single fan.
    So i though that what I would do, would be to get the above case, and just have a 120mm front fan and a 120mm exhaust fan.
    What do you think??
    Cheers.
  2. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
    Just left it idle with the side off, and cpu temp went from 22*C (side on) to 14*C, side off!!! :eek:
    My NB temps have dropped too, I'm guessing that this case has eally bad airflow :(
  3. HTC
    HTC
    Apr 1, 2008
    2,238 (0.96/day)
    303
    If you're looking for air flow, you could try this one:
    http://www.techpowerup.com/reviews/Apluscase/TwinEngine/
    Be advised, however: Tuniq tower 120, Thermalright Ultra 120, Noctua NH-UP12 and other big CPU coolers won't fit unless you leave the door open.
    Take a look @ my system specs: Both the case and the coolers haven't arrived, yet, but you'll get an idea of what it will look like.
    Ofc, it all depends on your case and / or cooler(s) budget.
  4. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
    Thanks, but too expensive, I'm prob gonna order the one I said, just trying to work out if it works better with a fan on the side or not.
  5. HTC
    HTC
    Apr 1, 2008
    2,238 (0.96/day)
    303
    Both A+CASE X-Clio II
    http://www.aplus-case.de/pages/products/xclio2/Aplus_Xclio2_UK_mini.pdf
    and
    A+Case 188 AF
    (couldn't find a PDF for this model on their site)
    cost less then 60 euros (less then half of the Twin Engine) and both have a 25 cm side fan, and that's from A+Case only: there are many more manufacturers.
    You should take the time to make a search: there are hundreds of cases that can match your budget / specs.
    As for if it works better with a fan on the side, it should: just try to clear the cables as much as possible because it will improve the air flow.
  6. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
    Yeah but I dont have that much still. A 60 euro case would be £50 in this country and I dont have the money to spend that much on a case. I might just get this one and try it with a cheap 120mm fan on the side and compare the temps, then post back if anyone lese has the same question.
    My problem is not about the case, it is about the affect of ventilation for the CPU cooler, whether a fan blowing at it or just a vent inline with it is better.
  7. trog100 New Member
    Dec 18, 2005
    4,420 (1.40/day)
    237
    alexp999 says thanks.
  8. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
    Looks nice but I need 2x 3.5 external bays. :(
    The one I have chosen is an Icute. I have bought the one in my OP now.
    With your case do you have a fan on the side window. Do you have any pics?
  9. oli_ramsay
    oli_ramsay
    Sep 22, 2007
    3,476 (1.38/day)
    569
    UK
    What I do to further improve airflow is remove the pci slot covers, and just put a 120mm intake fan there, fits perfectly and blows straight on to my graphics card :)
  10. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
    Not enough space with the position of the gfx card. prob only fit a 80mm in there. And when I go Xfire there will be no space! lol
  11. intel igent
    intel igent New Member
    Jun 5, 2005
    4,641 (1.38/day)
    434
    Toronto, Canada
    why not mod your current case?
  12. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
    Its too small. i wanted a new case anyway, HDD's are too close to the GFX card, and the PSu is resting on my CPu cooler, worried its gonna warp the board.
  13. trog100 New Member
    Dec 18, 2005
    4,420 (1.40/day)
    237
    the case i linked to has the big 140 in the front.. i have a floppy plugged in behind the front door that opens up.. its just sat in one of the bigger bays..
    i have one 120 blowing in on the side and one blowing out at the back.. the case comes with an intake funnel thing that lines up with the cpu if u use a stock type blow down cooler..
    the big front fan is the secret.. if the hardrives are kept above and below it the air just blows straight in at the mobo unobstructed..
    the chinese icute site is a good place to look..
    http://icute.com.tw/english/AllProduct.html
    trog
  14. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
  15. philbrown23
    philbrown23 New Member
    Dec 22, 2007
    1,231 (0.51/day)
    147
    vermont
    dude that case is friggin small! you say that the ones they posted were to small, the one you ordered is dinky small! congats you just wasted some money!lol.
  16. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
    Its the same size as trog100's one.
    my dad has a similar I-cute, and it is the perfect size. How big is your case then??
    And I didn't say the ones anyones poster were too small. I said my current one is too small!
  17. trog100 New Member
    Dec 18, 2005
    4,420 (1.40/day)
    237
    where did u order it from.. ??
    icute often come under many names and can be hard to find.. it will be plenty big enough.. it looks nicer than the one i have..
    trog
  18. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
  19. trog100 New Member
    Dec 18, 2005
    4,420 (1.40/day)
    237
    thats a sweet price.. u might need to buy some more 120 fans assuming u havnt already .. mine came with 80 ones.. "optional"..
    trog
  20. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
    I got too of these for it:
    http://www.ebuyer.com/product/124810
    One for the front, one for the back.
    I hate how noisy this PC is ATM.
    That was the whole point in this thread, lol! I was trying to work out if I needed to order more than too.
    Have you got ur rig in the case gallery?
  21. theonetruewill New Member
    Nov 12, 2006
    2,996 (1.06/day)
    240
    London - Close your eyes and you'll see me
    Temps cannot be that good realistically at idle under air cooling with the kind of overclock you have. Please try Core Temp.
  22. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
    This house is damn cold, and it snowed this morning, so... I can believe that is the right temp.
    Also I have C1E on in the bios so it is only running at 2Ghz idle.
  23. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
    Check this out:
    [​IMG]
    Bit warmer in here since this morning but you can still see the temp difference. The top reading on Speedfan is CPU temp, I checked it against the bios.
  24. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.12/day)
    862
    Dorset, UK
    Dropped a little bit more while I was doing last post, lol!
    [​IMG]
  25. AsRock
    AsRock TPU addict
    Jun 23, 2007
    10,844 (4.15/day)
    1,658
    US
    Get a Dremel and make a hole at the top of the case for a fan.
    Is there any fans in the front of that ?. Maybe get one of those cases that MKMods customized lately or even see if you can order one to your needs :p..
Share This Page
