CES 2008: Arctic Cooling Freezer Extreme CPU Cooler
Discussion in 'News' started by malware, Jan 10, 2008.
  1. malware New Member
    Nov 7, 2004
    5,476 (1.45/day)
    956
    Bulgaria
    Arctic Cooling has a new CPU cooler available called the Freezer Extreme that features 8 heat pipes, 226 fins and pre-applied MX-2 thermal paste. It also features a push pin installation which eliminates the need for screws. It is constructed out of aluminum, keeping the weight to a minimum and the heatpipes act as a stabilzer for the large number of fins on this beast. Arctic Cooling estimates a February launch and they are currently in production. Also on display was the Arctic RC active memory cooler that should be available in roughly two months.
    [​IMG] [​IMG] [​IMG]
    Source: Legit Reviews
  2. erocker
    Jul 19, 2006
    40,154 (12.77/day)
    14,680
    Ok, if the Extreme can mount on my s939 board with the fan blowing out the back, which by the looks of it, I think it can! Finally, a big heatsink by AC! I'm getting it the second I get word it's for sale.:D
  3. HookeyStreet
    HookeyStreet Eat, sleep, game!
    Aug 29, 2004
    7,135 (1.86/day)
    523
    Great Yarmouth, England
    one word, COOL! :D
  4. JC316
    JC316 Knows what makes you tick
    Jan 24, 2006
    9,364 (2.82/day)
    914
    Nice, depending on price and performance, I may get one of these when they come out, unless I get enough cash for a water cooler.
  5. btarunr
    29,288 (10.85/day)
    13,931
    You need a very roomy mobo for this one, I doubt if it matches up with the Thermalright Ultra 120.
  6. Wile E
    Wile E Power User
    Oct 1, 2006
    24,324 (7.92/day)
    3,778
    Maybe not, but it will come close, and probably be half the price to boot.
  7. xylomn
    xylomn New Member
    May 13, 2006
    661 (0.21/day)
    18
    Swindon, England, United Kingdom
    thats why i like arctic cooling, they may not have the best performance out there but their prices for what you get are fantastic
  8. [I.R.A]_FBi
    [I.R.A]_FBi New Member
    May 19, 2007
    7,664 (2.70/day)
    540
    c:\programs\kitteh.exe
    ac for ma munies ...
  9. trog100 New Member
    Dec 18, 2005
    4,420 (1.32/day)
    237
    i think it will run alongside the pro.. for those that want "extreme".. i dont but it seems a lot do..
    trog
  10. Co_Op
    Co_Op New Member
    Jan 3, 2008
    55 (0.02/day)
    10
    Cluj.RO
    These coolers are becoming ridiculous and a PITA to install.
    I say: F*ck th1s $h1t! :nutkick: Let's move to water :D
  11. Co_Op
    Co_Op New Member
    Jan 3, 2008
    55 (0.02/day)
    10
    Cluj.RO
    Well, the Scythe Infinity (1kg) with the push-pins slowly increased the temperature difference between the two cores to about 5-6 degrees (vs. 1-3 degrees which is normal). It was mounted with the mobo out of the case (because you couldn't push completely 2 pins with the mobo inside the case because of the fins and the I/O plate being in the way).
    After 2 months mounted with the push pins, I took it out when I had the parts for the bolts+springs diy mounting, and when I checked the thermal paste in-print I found out the cooler had been slowly sagging (it looked like a trapeze with the small base on the upper part of the IHS). So that's how well plastic push pins and big coolers work together :ohwell:.
  12. mas0n New Member
    May 1, 2007
    88 (0.03/day)
    9
    dallas
    Yes, because water is easy to install.
  13. WarEagleAU
    WarEagleAU Bird of Prey
    Jul 9, 2006
    10,809 (3.43/day)
    547
    Gurley, AL
    Id love to get one of these. And AC's cooling products are some of the top notch in the industry and damn good prices. They dont stupid price like Thermalright, Thermaltake (Big Typhoon anyone) Zalman and them. Best price performance cooler out there, period.
  14. trog100 New Member
    Dec 18, 2005
    4,420 (1.32/day)
    237
    two years ago when the artic pro first came out it was top notch.. its just others have gotten bigger.. this is artics reply.. get bigger too.. it aint their fault.. blame the reviewers and those that want "extreme"..
    basically u dont have to buy the "biggest".. thow some quite clearly think u do..
    the old freezer pro is still plenty good enough..
    trog
  15. LiNKiN
    LiNKiN Staff
    Jan 15, 2006
    1,760 (0.53/day)
    302
    I agree with you trog. For no bigger than my OCZ Vendetta cooler is, I am impressed by what it accomplishes. Bigger isn't always better, we will just have to see the price/performance.
Share This Page
