choose a best water cooling
Discussion in 'Overclocking & Cooling' started by BALADU, Jul 22, 2014.
  1. BALADU
    BALADU
    Jun 5, 2014
    41 (0.07/day)
    1
    my pc specifications
    cpu: intel i5 4670k
    motherboard: msi z97 gaming 5
    ram: kingston 4gx2
    hd: wd 2Tx5
    i never use water cooling,
    PLZ prefer a best water cooling for me,
    thx~
  2. Hellfire
    May 3, 2010
    566 (0.27/day)
    122
    Essex, England
    Rather than a custom loop you may be better off with a AIO cooler. Look at Corsair H series etc.
  3. arbiter
    Jun 13, 2012
    714 (0.53/day)
    146
    Yea AIO loop would be best idea for you, when you look at them you should look at space in your computer case to make sure you have space needed to install one.
  4. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,913 (2.03/day)
    2,906
    S.E. Virginia
    Honestly, reliability wise, you are better off with a high-end air cooler. Water pumps go bad, my H60 didn't last much more than a year. Replaced it with a Noctua NH-D14 and my temps actually went down a few degrees.
    RCoon says thanks.
    Crunching for Team TPU
  5. RCoon
    Apr 19, 2012
    10,520 (7.53/day)
    7,913
    Gypsyland, UK
    Pretty much the best CPU cooler bar the Cryorig R1
  6. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,913 (2.03/day)
    2,906
    S.E. Virginia
    It used to be, but now the Deep Cool Gamer Storm Assassin heat sink(which I have on my 3930k) is better, so is the PH TC14PE and Dark Rock 3, as well as several others.
  7. RCoon
    Apr 19, 2012
    10,520 (7.53/day)
    7,913
    Gypsyland, UK
    And I will never buy that, because of such a ridiculous juvenile name :laugh: Phanteks cooler is pretty good from what I recall, the Cryorig was a bonus because it didn't encroach on any RAM.
    the54thvoid says thanks.
  8. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,913 (2.03/day)
    2,906
    S.E. Virginia
    Yeah, the name is kinda hilarious, but considering it keeps my 3930k OC'ed to 4.3ghz under 70'c at full-load for weeks on end, I'm ok with that. Reason why I choose it was because it's design is very similar to the NH D14, but with 8 heat pipes instead of the 6 the D14 has. Definitely got to use LP RAM with the D14 and the Assassin
    RCoon says thanks.
  9. Durvelle27
    Durvelle27
    Jul 10, 2012
    2,722 (2.07/day)
    671
    Memphis, TN
    What about the Cooler Master Glacier 240
  10. Potatoking
    Potatoking
    Jan 8, 2014
    105 (0.14/day)
    44
    Prague CZ
    When asking for water-cooling help, PC case should be mentioned, true custom water-cooling needs lots of space. If you really want to go this route, you should read some basic articles first. once you have general idea what you want, people will help you.
    Durvelle27 says thanks.
  11. the54thvoid
    the54thvoid
    Dec 14, 2009
    4,580 (2.03/day)
    3,133
    lol, pretty much what I thought.
    Water cooling is a hobby first, a practicality second. Plenty of air coolers are big enough to handle the dissipation of even a moderately overclocked chip. I'd recommend custom WC every time but only if that person actually wants to invest in the 'adventure'.
    But, with all that said, gaming with a 3930k at 4.4Ghz on 1.38-1.4v and a 780ti Classified at 1215Mhz at 1.21v with fans at no more than 700-900 rpm after 2 hours on BF4 is audio bliss. Air can't touch good water but my WC set up cost as much as my gfx card. o_O
    RCoon says thanks.
  12. BALADU
    BALADU
    Jun 5, 2014
    41 (0.07/day)
    1
    so...air coolers are big enough?
    but... i already get the Cooler Master Glacier 240 yesterday...:fear:
  13. Norton
    Norton WCG-TPU Team Captain
    Dec 21, 2011
    10,739 (7.08/day)
    28,963
    The Glacer 240 is a fine cooler as long as it fits in your case.
    What case do you have?
  14. BALADU
    BALADU
    Jun 5, 2014
    41 (0.07/day)
    1
    BitFenix BFC-CLS-500-KKWR1-RP Black Steel
  15. Norton
    Dec 21, 2011
    10,739 (7.08/day)
    28,963
    Looks like you might have an issue with the board that supports the USB, etc ports on top. Test fit the cooler for clearance carefully.
