*Clean* pc works after blowing with compressed air - what could be the problem?
9,019 (1.46/day)
System Name Black Panther
Processor i9 9900k
Motherboard Gigabyte Z390 AORUS PRO Wifi 1.0
Cooling NZXT Kraken X72 360mm
Memory 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz
Video Card(s) Palit RTX2080 Ti Dual 11GB DDR6
Storage Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm
Display(s) 32'' Gigabyte G32QC 2560x1440 165Hz
Case NZXT H710i Black
Audio Device(s) Razer Electra V2 & Z5500 Speakers
Power Supply Seasonic Focus GX-850 Gold 80+
Mouse Some Corsair lost the box forgot the model
Keyboard Motospeed
It's one of the work pc's, a bit old like 6 or 7 years. We're soon going to get a replacement for it, but I am still curious as to the cause of this problem:
Like once a week, it freezes. It just freezes, I mean the monitor still shows the desktop or the accounts program. It doesn't BSOD. Mouse pointer doesn't move, ctrl-alt-del doesn't work.
Then if you switch it off and on again, it doesn't boot. No beeps, no post, monitor remains on standby, and on the case both green and red leds remain on (normally only the green one remains on, the red one works during hdd activity).
The solution is to open up the side and give it a good blow with compressed air.
Now the pc is very clean inside (I use the compressed air on it like once a week) so it's not a dirt problem.
Any idea what could be happening and why the compressed air makes it work again?
Any clue as to failing hardware?
According to speedfan the CPU idles at 56 degrees... it's an Athlon XP 2600+
However I doubt that this problem is directly related to CPU overheating because even if I leave the pc unpowered for an hour or more and it cools down, it still doesn't boot unless I blow it with the compressed air.
:confused:
Thanks for any help.
T
thraxed
Still trying to get over the fact of having windows installed for 6 to 7 years w/o having to reinstall...
Deleted member 24505
Maybe its sussed out its the only way its ever going to get a blow job;)
Weird thing though,could it be some loose connection or something,that the blast of air wiggles?
1,398 (0.23/day)
Hyderabad,India
System Name MSI apache ge62 2qd
Processor intel i7 5700HQ
Memory 12 Gb
Video Card(s) GTX960m
Storage 1TB
Display(s) Dell 24'
Looks like its the HDD.
Tried changing it?
If you don't have a replacement try a live CD after removing the HDD.
SpookyWillow
378 (0.06/day)
UK
Processor 3570-K @ 4.4
Motherboard Gigabyte Z77-DH3
Cooling cosair H100
Memory 8gb samsung green
Video Card(s) Inno3d 580GTX
Storage 240gb Vertex 3 +500gb samsung F1 + 640gb samsung F(something)
Display(s) BenQ G2220HD
Case CoolerMaster CMStacker
Power Supply Corsair TX750w
Software Windows 7
yeah just check all connections
xu^
1,098 (0.18/day)
Lancs,UK
System Name Mr_average ( hoping 1 day to upgrade to Mr_above_average )
Processor AMD Ryzen 7 5700x @3.4ghz/4.6ghz
Motherboard MSI B450 Tomahawk Max
Cooling Deepcool AS-500 Plus - White | 6 Lian Li ST120mm case fans - White
Memory 32gb Corsair Vengeance RGB PRO SL 4x 8GB 3600MHz DDR4 - White
Video Card(s) Asus Dual GeForce RTX 4070 12GB OC
Storage 512gb Sabrent Nvme | 4tb Samsung SSD | 2tb WD Blue SSD| 1tb Crucial P3 Nvme| 1tb WD Blue HDD = 8.5tb
Display(s) D1: LG Ultragear GL850-B 27" 1440p 144hz | D2: Asus Tuf - VG249 24" 1080p 144hz
Case Lian Li Lancool 2 Mesh RGB - White
Audio Device(s) Creative Gigaworks T20 Series II | Steelseries Arctis 3 Headset - White
Power Supply Corsair TX650M Semi Modular 80+ Gold
Mouse Red Dragon M991 - White
Keyboard Razer Huntsman V2
don't forget compressed air is pretty damn cold ,maybe it lowers the temps enough for it to boot ?
9,019 (1.46/day)
Processor i9 9900k
Keyboard Motospeed
I've checked the connections endless times. Everything seems okay.
Hmm that makes sense...
1,037 (0.18/day)
London, England
System Name Le Don
Processor Core i 5 2500K Unlocked 3.3GHz HD Graphics 3000
Motherboard Asus P8P67 Pro B3 Revision Rev 3.1
Cooling Arctic Freezer Pro 7 Rev.2
Memory 8Gb Corsair DDR3 (CMZ8GX3M2B1600C9), 1600MHz, 1.5V, 9-9-9-24
Video Card(s) EVGA Signature 2 Super Clocked GTX680 2GB
Storage Total 6 TB storage
Display(s) LG 23" D2342P and LG 42" 42LF65 LCD (Wall mounted)
Case Antec P180 Silver
Audio Device(s) Audigy 2 ZS Platinum Pro
Power Supply Corsair 850HX
Software Windows 7 Ultimate 64-bit,
put a desk fan blowing on the side of the opened case, see if that does anything
8,191 (1.36/day)
Mouse Logitech G604s
Its either because of the CPU temp, hdd is going, or the windows install is FUBAR.
2,452 (0.41/day)
System Name PC
Processor i7 9700KF
Motherboard MSI Z390 A PRO
Cooling Noctua NH-U14S
Memory 32GB Corsair Vengeance DDR4 3000mhz
Video Card(s) PALIT RTX 4070 Dual 12Gb
Storage 2X Crucial MX500 2TB SSD, Samsung 850 pro 512gb SSD
Display(s) DELL C34H89x 34" Ultrawide
Case Corsair Obsidian 550D
Audio Device(s) Audioengine A5+ Speakers
Power Supply Corsair RM750
Mouse Logitech G403
Software Windows 10 64bit
I say its probably a faulty PSU...
I had a rig which would randomly lock up becuase of an old dodgy oem psu..
Its not the HDD or it would boot up and just tell you that it cant find the disc after a lockup.
Its also not going to be CPU temp becuase as you say its incredibly clean and realtemp has it clocked ok
2,573 (0.40/day)
N.Ireland
Processor Core I5 4440 / 4430
Motherboard Asus z87-k / Gigabyte ga h97- d3h
Cooling Arctic freezer / Generic
Memory 8 gb Mushkin / Various
Video Card(s) Radeon 7850 cf / Gtx 690
Storage Samsung 850 EVO 250 gb / 2x1 terabyte hdds Wd 256 gb nvme
Display(s) Technika 32" / Asus 24` ips
Case Corsair
Audio Device(s) X-fi Titanium
Power Supply Corsair 850 w
Might be something to do with opening the case. This is like Clue sort of..
TheMailMan78
Big Member
22,599 (3.67/day)
'Merica. The Great SOUTH!
I always work better after a good blow.
43,586 (6.73/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
The cpu temps are normal for that chip. I'm guessing it's the PSU as well. However, you could have some sort of miniscule foriegn object shorting something out that the compressed air alleviates when you use it. First I would suggest doing a complete teardown/cleaning/rebuild. You may have some greasy dust or something built up around some hidden component.
hat
Enthusiast
21,731 (3.42/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
re-seat the heatsink? after 6 or 7 years I could imagine all the TIM being pretty crusty and dry
