Cleaning a motherboard (and other components) with de-mineralised water. Problems?
Discussion in 'General Hardware' started by Tommygunn, Oct 14, 2011.
  1. Tommygunn
    Tommygunn
    Feb 11, 2007
    249 (0.08/day)
    6
    Emilia Romagna, Italy
    I've just acquired a second hand motherboard that needs a good clean. Apart from the usual vacuum cleaner and make-up brush routine would it be okay to give it a bath in de-mineralised water to shift the dirt?
    Tom.
  2. erixx
    erixx
    Mar 24, 2010
    3,886 (1.81/day)
    637
    I wouldn't! Take cotton sticks (for ear cleaning) wet in (pure) alcohol and clean as you like!
  3. sneekypeet
    Apr 12, 2006
    22,837 (6.35/day)
    7,399
    you can throw it in the dishwasher without soap, so I don't see why you would have issues. Just give it more than ample drying time as not to destroy with a short what you just cleaned!
  4. Tommygunn
    Tommygunn
    Feb 11, 2007
    249 (0.08/day)
    6
    Erixx,
    Why wouldn't you?
    Sneeky,
    The dishwasher method sounds very dodgy and does not allow any control at all. You know that dishwashers are loaded with salt to aid in the wash, at least ours is.
    Tom.
  5. Fourstaff
    Fourstaff Moderator Staff Member
    Nov 29, 2009
    9,304 (4.11/day)
    2,051
    Home
    It will be fine, but make sure you drain the caps and remove the battery first. You absolutely must dry it completely first though, otherwise your flat will smell of nice crispy chips smell.
    stinger608 says thanks.
  6. Completely Bonkers New Member
    Feb 6, 2007
    2,579 (0.78/day)
    516
    I've cleaned keyboard and mainboards using a regular bathtub. Half filled with warm water using a small amount of mild detergent. Immerse for 10 minutes to soak. Then agitate underwater to wash out all dust. Stubborn marks, like dirt stuck to keycaps, use an old rag or cloth to wipe while item still immersed underwater.
    If you didnt use too much detergent, no need to even rinse. But you can just use the shower head to rinse off.
    Important, is to reasonably quickly dry it. Dont let the wet sit there for days. I SHAKE off excess water. Then let the thing sit at an angle on a warm radiator so the warm air circulates and dries. One day later it is usually dry.
    A hair drier on cool is another option.
    SHAKE AGAIN to make sure no water reappears from under connectors or behind keys.
    I've done this many times. Regular tap water, regular bathroom in various countries across Europe. Note that the water is considered drinking water, and not that nasty stuff you sometimes get in the states out of the faucet!
    Mainboards and keyboards are quite robust. Make sure no batteries of course! And remove fans and their motors.
    WARNING: dont do this to your HDD! LOL :pimp:
  7. sneekypeet
    Apr 12, 2006
    22,837 (6.35/day)
    7,399
    Was more of a generalization to make you feel more at ease of your attempt with de-mineralised water.
    http://www.google.com/#q=cleaning+a....,cf.osb&fp=1e4bc34154dc3a50&biw=1066&bih=562
    lots of videos, some with soap even;)
  8. Tommygunn
    Tommygunn
    Feb 11, 2007
    249 (0.08/day)
    6
    Here in Italy we've still got some half decent sun left over from the summer. Would it be okay to prop the board up on the patio and dry it by that method without any risk of warping or other weirdness?
    Thoughts.
    Tom.
  9. sneekypeet
    Apr 12, 2006
    22,837 (6.35/day)
    7,399
    lay it flat and you will be fine. It would have to get really hot to warp in my opinion.
  10. Tommygunn
    Tommygunn
    Feb 11, 2007
    249 (0.08/day)
    6
    Cool.
    I think what I'll do first is blow the loose crud off with my compressor and then run a function test. Then I'll soak the board in some detergent and warm water, for twenty minutes or so, rinse with tap water and then give it a final bath/swill in de-mineralised water.
    Lastly, I'll blast off any remaining water and stick it outside to dry thoroughly.
    Tom.
  11. stinger608
    stinger608 Dedicated TPU Cruncher & Folder
    Nov 11, 2008
    8,307 (3.13/day)
    5,853
    Wyoming
    Yep I have done it many, many times! I take distilled water and put it in a stainless steel pot and warm it up on the stove and then pour it into the sink. I have an old paint brush that I use in this scenario to help clean in between the caps and mosfits as well. Once I am done I usually will set the motherboard upside down for 24 hours to insure that everything is dry.
    The biggie here is to make sure you pull the onboard battery! I usually pull the battery and let it set for around 5 minutes or so before submersing in the distilled water. That is usually how long it takes for the water to warm up on the stove and me to pour it into the sink LOL.
    Crunching for Team TPU
  12. hat
    hat Enthusiast
    Nov 20, 2006
    17,703 (5.25/day)
    2,518
    Ohio
    I put my keyboard through the dishwasher once, when I still had one. I'm typing on it now.
    dustyshiv says thanks.
  13. sneekypeet
    Apr 12, 2006
    22,837 (6.35/day)
    7,399
    I agree, but OP referenced salt in his DW water. I cant recommend it knowing he would be using salted water, that just can't be good!
  14. Wrigleyvillain
    Wrigleyvillain PTFO or GTFO
    Oct 13, 2007
    7,703 (2.53/day)
    1,791
    Chicago
    Yeah those times I accidentally dump water all over my cards or board when working on my loop I just chalk it up to a nice de-dusting and find something else to do for a couple days. :)
  15. erixx
    erixx
    Mar 24, 2010
    3,886 (1.81/day)
    637
    thanks to all that opened my eyes. Yet... it's like a taboo.
    Any why not a HDD? They are sealed! :)
  16. n-ster
    Jan 11, 2009
    8,979 (3.47/day)
    1,445
    You crazy bastards! :p
    idk if I'm overcautious, but any electronics I clean with Isopropyl alcohol @ 91% or higher. Definitively a safer method IMO, not costly, and less chances of damaging your mobo
  17. Derek12
    Jan 12, 2010
    1,115 (0.50/day)
    164
    Don't use a (standard) vacuum cleaner as it produces lots of ESD and can damage the components. If your vacuum cleaner is battery powered then it's fine. I usually use canned air to get the dust out. I also use 90ยบ alcohol or 0 residue contact cleaner that dry faster and they are fine.
  18. Fourstaff
    Nov 29, 2009
    9,304 (4.11/day)
    2,051
    Home
    You are not fit to have your pair of balls, give them to someone who deserves them more :laugh:
    Really, this is a bit like overclocking, the first time it would be like "omg its going to kill my computer, isn't it?", second will be "well, first one went fine, so lets do this again" and then some time later "there is a f**king speck of dust in my rig, washing time!"
  19. Jetster
    Jetster
    Jan 17, 2010
    7,342 (3.31/day)
    3,766
    Oregon
  20. (FIH) The Don
    (FIH) The Don
    Aug 11, 2009
    6,823 (2.87/day)
    2,910
    Viking Land
  21. Peter1986C
    Peter1986C
    Sep 3, 2010
    3,423 (1.72/day)
    1,650
    NL, Europe
    I have put that in my signature. :)
    Yes I know that water "works", yet I have always thought more towards the tap.
  22. Derek12
    Jan 12, 2010
    1,115 (0.50/day)
    164
  23. Jetster
    Jetster
    Jan 17, 2010
    7,342 (3.31/day)
    3,766
    Oregon
    Duh........ its window cleaner good catch. you knew what I was thinking though :)
  24. Derek12
    Jan 12, 2010
    1,115 (0.50/day)
    164
    It's screen and case cleaner. Read the description. Not for clean motherboards and circuits. The product I linked is a PCB cleaner. Suitable for motherboard and any PCB circuit as far I know.
  25. Jetster
    Jetster
    Jan 17, 2010
    7,342 (3.31/day)
    3,766
    Oregon
    I was referring to the ingredient "Ammonia" aka window cleaner
    And bty I was admitting to my mistake
