CM 690 Side Fan Noise Issue
Discussion in 'Cases, Modding & Electronics' started by welly321, May 18, 2009.
  1. welly321
    welly321 New Member
    Mar 27, 2009
    96 (0.04/day)
    5
    Pittsfield, Massachusetts
    Hey All,
    I've had this case for a while now and the side fan has always been extremely loud. Its almost like a whirring sound coming out of it. Ive heard this is a well known problem and I was wondering if anyone knew the easiest way to fix it, short of removing the fan. If you have any ideas please post here!! Thanks a lot
    -welly
  2. Sir_Real
    Sir_Real New Member
    Feb 24, 2009
    706 (0.28/day)
    94
    Lincoln England
    Spray WD40 inside it.
  3. WhiteLotus
    WhiteLotus
    Jul 30, 2007
    6,570 (2.11/day)
    865
    See if it is catching on anything. Take the fan off the case and hold it in your hand and then power it up. I had one problem where the holes in the case were not sanded back down causing a bitch of a noise. Once i realised that it was the case and not the fan, a quick rub down, job done.
  4. kyle2020 Guest
    You know the front 12cm fan mount plate thing that has screws in it? I cant mount a fan to it because it hold the fan too close to the metal and makes a whirring noise too. Its damn annoying, but basically im assuming your side panel is doing the same - only suggestion I can make is either slow the fan down or buy a slow rpm fan like a noctua.
    That or if your handy with a dremel remove the honeycomb mesh to stop the whirring. But dont do that until you have tried lubricating the fans bearings first, that may solve it, if not, then its probably what ive said.
    10 Year Member at TPU
  5. Studabaker
    Studabaker New Member
    Mar 25, 2009
    1,116 (0.44/day)
    73
    Somewhere in the underground
    I had that problem. With my case I had a 120MM ThermalTake SmartFan and since it was so expensive (I pay 19$ locally at CompUSA) I decided to get a rear fan but I went with a $10 Masscool fan. After I replaced the stock CPU cooler I could hear it's high pitched whirring so clearly that I went out and got me another TT SmartFan. I'm a happy camper. So, yes, you have to remove it to really get rid of the sound, and get a better one, like kyle said a slow mover (with the SmartFan I control the speed myself, so I get to fine-tune the sound level of the system to my preference).
  6. WhiteLotus
    WhiteLotus
    Jul 30, 2007
    6,570 (2.11/day)
    865
    or do a 7V mod like i did.
  7. kyle2020 Guest
    or use your motherboards fan header and dial it down? ;)
  8. WhiteLotus
    WhiteLotus
    Jul 30, 2007
    6,570 (2.11/day)
    865
    na - not ghetto enough
  9. will
    will
    Oct 20, 2006
    455 (0.13/day)
    41
    Hereford, England
    With mine it wasnt the fan that was making the noise so spraying with WD40 wouldn't help. The noise was caused by the fan rotation vibrating the whole side panel. I couldn't fix it so I just moved the fan inside (the top or bottom I think). IMO side fans aren't that great, they disrupt the airflow from front to back.
