- Feb 17, 2010
- 1,842 (0.33/day)
- Azalea City
System Name | Test Bench #3 |
Processor | Ryzen 5 8600G delidded, +200PBO -30CO |
Motherboard | B650M-HDV M.2 |
Cooling | Water, liquid metal |
Memory | TRIDENT Z5 @8400CL36 |
Video Card(s) | 760M @3300MHz |
Storage | Samsung PM981 |
Display(s) | MAG401QR |
Case | Open Frame |
Audio Device(s) | Logitech Z623 |
Power Supply | EVGA P5 |
Mouse | Cooler Master MM710 |
Keyboard | Huntsman Elite |
Software | 10 Pro |
Benchmark Scores | https://hwbot.org/user/luke |
Here I am testing various platform overclocks and how well they scale while using one of my favorite games, Far Cry 2. It has a nice suite of built-in benchmarks, and today I'll be using the busy "Action Scene" to see how well CPU, GPU, and RAM overclocks can affect performance.
Platform:
Athlon II x4 760K
Asrock Extreme 6+ (BIOS 2.4)
2x4GB G.Skill RipjawsX DDR3-2133CL10
Radeon HD 7850 2GB
Monitor 60Hz 1080p Vsynch OFF
All in game detail quality settings set to maximum with 8x AA
Each test looped 3 times with the average recorded.
CPU-Z
GPU-Z
ASUS Voltage Tweak
Exact frequencies may vary slightly due to various bugs.
First let's see a run with all stock settings:
CPU at default/auto BIOS settings (3.8GHz stock with up to 4.0GHz Turbo enabled)
RAM at JEDEC settings (DDR3-1600CL11)
GPU at AMD stock settings (860MHz Core/1200MHz VRAM)
Results:
Average FPS: 38.77
Minimum FPS: 32.88
Maximum FPS: 49.89
Next I apply only a GPU overclock and test again:
GPU at 1200MHz Core 1450MHz VRAM (~40%OC)
Results:
Average FPS: 38.45
Minimum FPS: 31.78
Maximum FPS: 48.78
Next I apply only a CPU overclock and test again:
CPU at 4500 MHz (~18%OC)
Results:
Average FPS: 42.38
Minimum FPS: 36.32
Maximum FPS: 54.61
Next I apply both a CPU and GPU overclock, but no system memory overclock:
CPU at 4500 MHz (~18% OC)
GPU at 1200MHz (~40%OC) Core 1450MHz VRAM
Results:
Average FPS: 42.28
Minimum FPS: 35.93
Maximum FPS: 53.89
For the final test, I apply a full platform overclock:
CPU at 4500 MHz
RAM at DDR3-2400CL10 (~50%OC) with NB at 2600MHz (~44%OC)
Results:
Average FPS: 49.79
Minimum FPS: 41.00
Maximum FPS: 62.91
Analysis: Despite a few bugs, it is obvious that the GPU was totally bottlenecked by CPU and RAM, as adjusting GPU frequency resulted in no gains, while CPU and RAM overclocking brought substantial gains. Contrary to popular opinion, facts here indicate that overclocking RAM and memory controller can alleviate substantial bottleneck on the FM2+ platform, much more than just overclocking CPU and/or GPU.
Platform:
Athlon II x4 760K
Radeon HD 7850 2GB
CPU-Z
GPU-Z
ASUS Voltage Tweak
Results:
Average FPS: 38.77
Minimum FPS: 32.88
Maximum FPS: 49.89
Results:
Average FPS: 38.45
Minimum FPS: 31.78
Maximum FPS: 48.78
Results:
Average FPS: 42.38
Minimum FPS: 36.32
Maximum FPS: 54.61
Results:
Average FPS: 42.28
Minimum FPS: 35.93
Maximum FPS: 53.89
CPU at 4500 MHz
Results:
Average FPS: 49.79
Minimum FPS: 41.00
Maximum FPS: 62.91
