connect 3d 6850 2gb wrong Flash. Need Help..
8 (0.00/day)
System Name .: CM STORM PC BY FEAR :.
Processor AMD FX 8370 4,73 GHZ 24/7 (5.0 GHZ MAX)
Motherboard GIGABYTE 990FXA-UD3 rev.3
Cooling CUSTOM FULL WATERCOOLING SOLUTION BY EK, RAIJNTEK TRITON CPU BLOCK
Memory 32 GB RAM KINGSTON HYPERX SAVAGE 2000+
Video Card(s) 2 X AMD RADEON HD7990 ( 4 GPUS ) OC TO 1200/1700 CUSTOM BIOS V3
Storage SAMSUNG 850 PRO
Display(s) SONY W650A 42'' + MONSTER 1000DEX HDMI CABLE
Case CM STORM STRYKER BY COOLERMASTER
Audio Device(s) EXTERNAL SOUNDBLASTER SOUND CARD
Power Supply OCZ PC POWER & COOLING SILENCER 1200W PLATINUM
Mouse ASUS ROG GX1000
Keyboard GIGABYTE AIVIA MECHANICAL
Software WIN 10 PRO
Benchmark Scores 3D MARK TIME SPY : SCORE: 7790
I have connect 3d 6850 2gb.. I flash the card to modify the bios but it was a failure..(blue screens..)
Now i flash the card with 1gb ram bios..(from powercolor 6850 1gb)
I want a bios of 2gb but i cant find it..... :(
If someone has connect 3d 6850 2gb bios or from other manufactor please sent me!!!
thanks guys!!!
4,665 (0.73/day)
Washington, US
System Name Rainbow
Processor Intel Core i7 8700k
Motherboard MSI MPG Z390M GAMING EDGE AC
Cooling Corsair H115i, 2x Noctua NF-A14 industrialPPC-3000 PWM
Memory G. Skill TridentZ RGB 4x8GB (F4-3600C16Q-32GTZR)
Video Card(s) ZOTAC GeForce RTX 3090 Trinity
Storage 2x Samsung 950 Pro 256GB | 2xHGST Deskstar 4TB 7.2K
Display(s) Samsung C27HG70
Case Xigmatek Aquila
Power Supply Seasonic 760W SS-760XP
Mouse Razer Deathadder 2013
Keyboard Corsair Vengeance K95
Benchmark Scores 4 trillion points in GmailMark, over 144 FPS 2K Facebook Scrolling (Extreme Quality preset)
I assume you didn't make a backup of your original bios before you flashed. Are you absolutely sure you have a 2GB card? Are you absolutely sure it's a 6850 and not a 6950?
If it's a Connect3D 6950 2GB, there's a stock BIOS in TPU's VGA Bios Database. If you have a 6850 1GB, the closest you'll get is either the Connect3D 6870 1GB bios or a 6850 1GB bios from a different manufacturer.
Edit: According to Connect3D's website, they don't make a 2GB 6850. For that matter, it doesn't look like anyone makes a 2GB 6850.
8 (0.00/day)
Software WIN 10 PRO
Thanks for your response my friend!! :) yes i have 6850 with 2gb ram.. i know that Connect3D's website dont have this model... thats the strange.. Maybe is a special model.. The problem is that i dont have a backup from the original bios... :(( Now only bios from club 3d & powercolor for 6850 1gb works for me now... 6870 doesent.. I think i have bad luck :p
8 (0.00/day)
Software WIN 10 PRO
If someone has my Card Bios please send me!!!
8 (0.00/day)
Software WIN 10 PRO
