Cooler Master TPC 612 and V8 GTS CPU Coolers, and JetFlo 120 Fans Pictured
Discussion in 'News' started by btarunr, Mar 8, 2013.
  1. btarunr
    31,317 (10.27/day)
    15,523
    Cooler Master showed off a trio of air-cooling solutions at CeBIT, which includes the TPC 612 and V8 GTS CPU coolers, and JetFlo 120 case fans. The TPC 612 is a compacted version of the TPC 812. It retains the design concept of its older sibling, that of a heatpipe-fed aluminum fin stack that also uses a vapor-chamber tube for more efficient heat transfer; while using just four heat pipes, and a more compact vapor-chamber tube. Measuring 145 x 97 x 161.6 mm (WxDxH, including the fan), it weighs about 640 g. It uses a single 120 mm PWM fan that spins in the range of 600 to 2,000 RPM, pushing 24.9 to an impressive 82.9 CFM of air. The TPC 612 is compatible with all modern CPU socket types.
    Moving on, the V8 GTS is Cooler Master's latest monstrosity, one that is designed to take on pre-assembled closed-loop liquid CPU coolers. It uses a triple independent aluminum fin stack design, which is ventilated by a pair of 140 mm fans. An unknown (we're guessing six) number of 6 mm-thick nickel plated copper heat pipes convey heat from the base through the three fin stacks. Measuring a whopping 154 x 149 x 160 mm, it weighs 1,140 g. Each of its two 140 mm fans uses a 4-pin PWM connection, spins at 600 to 1,600 RPM, pushing 28 to 82 CFM of air. Lastly, Cooler Master showed off its JetFlo 120, a neat little 120 mm spinner featuring PWM, 800 to 2,000 RPM speed range, and up to 85 CFM air-flow.
    [​IMG] [​IMG] [​IMG]
    Source: Guru3D
  2. LAN_deRf_HA
    LAN_deRf_HA
    Apr 4, 2008
    4,613 (1.61/day)
    977
    Nice to see heatpipe caps showing up more.
  3. t77snapshot
    t77snapshot
    Nov 26, 2008
    4,216 (1.60/day)
    2,774
    S.Cali
    Their V8 coolers are getting more and more ridiculous with the cosmetics :rolleyes:
    Still, I would have to admit that this new V8 would looks sick in a Dark Knight mod of some kind :p
    Crunching for Team TPU
  4. Dj-ElectriC
    Dj-ElectriC
    Aug 13, 2010
    2,424 (1.21/day)
    943
    Hate the stupid plastic cosmetics on the V-series coolers from CM. I'ts just more junk on the cooler itself.
    de.das.dude and EzioAs say thanks.
  5. de.das.dude
    de.das.dude Pro Indian Modder
    Jun 13, 2010
    8,065 (3.89/day)
    2,185
    Pune
    v8 looks too nerdy... these bits of cosmetic plastic only makes it heavier.
  6. badtaylorx
    badtaylorx
    Aug 19, 2011
    496 (0.30/day)
    162
    sorry guys, being from the US any thing with a V-8 attached to it appeals to me!!!
    with that being said, surprise, surprise
    I kinda like it........if it performs.....ill even buy it
  7. tastegw
    tastegw
    Jan 28, 2009
    320 (0.12/day)
    141
    It's huge! 2 140mm fans on a cpu cooler, wow that's big.
  8. Jorge
    Jan 5, 2013
    895 (0.79/day)
    115
    Their coolers historically have not been particularly efficient, effective coolers.
  9. OneCool
    OneCool
    Nov 27, 2005
    850 (0.23/day)
    68
    Look behind you!!
    [​IMG]
    WTF! :eek:
    Looks like a Trane heatpump :rolleyes:
    10 Year Member at TPU
  10. tokyoduong
    Jan 22, 2013
    478 (0.43/day)
    119
    I think coolers are just going for looks these days. There's only so many ways you can build an efficient cooler. After that, it's all aesthetics.
  11. rickss69
    Aug 23, 2009
    2,454 (1.04/day)
    618
    Rockvale TN (Not Australia)
    How will these stack up against a Phanteks?
  12. silkstone
    silkstone
    Nov 1, 2008
    3,131 (1.18/day)
    617
    Vietnam
    Jesus! Don't bump your case with that thing attached.
  13. NeoXF
    Sep 19, 2012
    615 (0.50/day)
    80
    IMHO... those vapor-chamber or whatnot heatsinks looked pretty sweet... in some reviews... I hope they weren't just nonsense bought-out reviews. But either way, doesn't anyone rember the Atomic Radeon HD 4890 single-slot? That was pretty amazing... why isn't the CPU cooling market taking notce... or is it patented or something? Or a fluke?
  14. t77snapshot
    t77snapshot
    Nov 26, 2008
    4,216 (1.60/day)
    2,774
    S.Cali
    You don't have to apologize for liking the cooler, everyone has their own opinion and we should all respect that. :cool:
  15. Widjaja
    Widjaja
    Jun 12, 2007
    4,819 (1.52/day)
    640
    Wangas, New Zealand
    The average consumer digs the plastic on the coolers and the fact it somewhat resembles a car engine rather than most of us tech heads who would rather go for something which cools our processors first with aesthetics being a bonus.
  16. tacosRcool
    tacosRcool
    May 14, 2012
    866 (0.63/day)
    71
    putting some style to cpu coolers!
