Cooling/Case Modding Update..Fan Help needed!
Discussion in 'Cases, Modding & Electronics' started by bpgt64, May 17, 2009.
  1. bpgt64
    bpgt64
    Oct 5, 2008
    1,559 (0.65/day)
    223
    ATL, GA
    Ok, so if you check my system specs I run a fairly low profile Antec 300, which I forever now swear by as being the sturdiest thing in the world, but beside the point. I am having some odd cooling issues. I attribute this mainly to the fact that I just removed my Okegear PCI Slot blower and never replaced it after it died...and I am now seeing that I need to. My HD 4870 X2 generates A LOT of heat and needs that blower to live. Which brings me to my point. I want to install a side fan, and replace the crappy 120 mm fans I put in the front of my case with newer(LED if possible but not a major issue) based fans. I also would like to have a fan control on the front of the case so when if I am watching TV I can have my computer go into silent mode. However while gaming noise isn't an issue, I used Sennheiser HD 280 Pro's and the block pretty much everything.
    TLDR; I need 3x120mm fans, preferably Blue LED, the more power the better(ignore and noise problems), I also need a fan control to stick in my Second CD drive bay and a PCI Slot blower. What I have in mind is this;
    3 x
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811998121
    1 x
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811999704
    1 x
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811999171
    Thoughts? Suggestions?
    Going to post some pics soon...need to do some major cable management when I install the fans as well..
  2. BumbleBee
    BumbleBee
    Mar 6, 2009
    5,143 (2.30/day)
    1,544
    Cybertron aka Canada
    get three Yate Loon 120mm Blue LED and a Sunbeam Rheobus overall better quality and cheaper. forget the PCI exhaust fan it is a waste of money what you should be focusing on is cooling your 4870 X2 probably not the greatest idea to mount it in a mid tower and with the left over money I just saved you plus a little saving you could buy a new heatsink or heatsinks for it. take all your expansion slot covers off and when you install everything set your two front intakes on channel 1 at 7v, set your side intake on channel 2 at 7-12v, set your rear exhaust on channel 3 at 5v and set your top exhaust on channel 4 at 5v. what I like to do is take some whiteout and a ruler (can use masking tape) to draw hash marks on my controller so I know where the voltages are.
    bpgt64 says thanks.
  3. bpgt64
    bpgt64
    Oct 5, 2008
    1,559 (0.65/day)
    223
    ATL, GA
    I appreciate the response, like the alternatives but I'd prefer to order from NewEgg.com, I live and die by there customer service.
  4. BumbleBee
    BumbleBee
    Mar 6, 2009
    5,143 (2.30/day)
    1,544
    Jab-Tech, Petras and P&PC has really good customer service. I think it's silly you rather pay more for lesser quality. first of all the Zalman is a nice controller has good build quality and a beautiful finish however the control knobs don't have much retention, is incompatible with some fans and non fans and has some power loss issues with fans that do work. Apevia LED Fan I don't even like their cases and according to newegg customer comments (at least the intelligent life) it doesn't have the greatest build quality the fans click when undervolted, vibrate, the led are cheap and a lot of customers say they are loud now this comes down to the individual customer however I like to exercise caution and say Apevia exaggerates the specs which a lot of companies do overall that is too much for the price point. you can go to directron and get a Scythe S-Flex for $11-12 which are legendary and so are Yate Loons because of their price to performance ratio.
  5. bpgt64
    bpgt64
    Oct 5, 2008
    1,559 (0.65/day)
    223
    ATL, GA
    I wound up going with 3 new Apevia Blue LED fans.. one of the more reviewed and better rated fans on newegg.com and kinda killed the idea of getting a fan controller...not that big a deal for me right now...I'll probably wind up using one in my next build but for now this setup works just fine. I'll throw a pic up sometime about the updates...if I can find my camera around here...
Share This Page
