cooling problem
Discussion in 'Overclocking & Cooling' started by o0lancerev0o, Nov 10, 2004.
  1. o0lancerev0o New Member
    Nov 7, 2004
    10 (0.00/day)
    0
    vga sliencer rev 3 problem on 9800pro, i get a really high temperature around 65c or so the atitool tells me, I dont get it, i got heat sinks on it too, isn't it suppose to be cooler?? I also touched it and its hot enough to shock/burn my hands a bit :eek:
  2. C&C Freak 2K New Member
    Oct 19, 2004
    205 (0.06/day)
    0
    Applegate, CA
    Since you don't have active cooling, you'd need more heat radiative area to maintain the same temperature.
  3. o0lancerev0o New Member
    Nov 7, 2004
    10 (0.00/day)
    0
    active cooling?
  4. C&C Freak 2K New Member
    Oct 19, 2004
    205 (0.06/day)
    0
    Applegate, CA
    Just a heatsink block is called passive cooling. There are no moving parts, heat just radiates off the fins. Active cooling is usually a fan, but by definition is a method of cooling that requires something to move or involves moving parts.
  5. YawAKooL New Member
    Oct 22, 2004
    24 (0.01/day)
    0
    I got a Artic Cooling VGA Silencer Rev 3 on my 9600 Pro EZ and it's keeping it really cool. (its active cooling)
    Maybe you forgot thermal paste or sumthing like dat.
  6. o0lancerev0o New Member
    Nov 7, 2004
    10 (0.00/day)
    0
    no i remeber putting on my thermal paste and it was hot so i re did it and same
Share This Page
