CPU lag..help
Discussion in 'General Hardware' started by Zaspera, Jul 17, 2011.
  1. Zaspera New Member
    Jan 5, 2011
    500 (0.32/day)
    11
    Mapleville, RI
    Ok I changed the following:
    1) CPU/NB Frequency is now 2600mhz instead of auto
    2) My RAM Frequency is now 1333mhz instead of 1067mhz
    3) My RAM timing is now 7-8-7-24 40 2T (is 40 the Row Cycle Time)?
    Anything else to do now? CPU frequency or anything?
    EDIT: new cpu-z memory reading
    [​IMG]
    How do I change my CPU Frequency? It's set to auto at 3200mhz right now. I turned off auto and put in manual but I can't seem to find another option to change the frequency.
    fullinfusion says thanks.
  2. fullinfusion
    fullinfusion 1.21 Gigawatts
    Jan 11, 2008
    8,605 (3.23/day)
    2,383
    Every bios is different. Can you take a few photo's of the bios?
    That would be a big help.
    I'll show you mine in a few min so you can see what the settings do.
    How does the system feel now with tighter timings?
  3. fullinfusion
    Jan 11, 2008
    8,605 (3.23/day)
    2,383
    Here , an example.
    [​IMG]
    [​IMG]
    [​IMG]
    you can also raise the BUS speed, raising the bus speed clocks up the cpu frequency as well as raises the memory speed... but it also raises the HT and NB speed as well...
    Id recommend using the cpu multi and tinker with that before playing with other settings..just to get a handle on whats going on.
    Oh and your question on the auto cpu setting being @ 3200mhz? Just use the plus or minus key on the key board to change the option.
  4. Zaspera New Member
    Jan 5, 2011
    500 (0.32/day)
    11
    Mapleville, RI
    The system feels alot smoother right now. So to overclock the cpu, I adjust CPU ratio and bus speed? My bus speed is at 200 right now and says I can go anywhere from 1-600. What is a good number to put it at?
  5. Zaspera New Member
    Jan 5, 2011
    500 (0.32/day)
    11
    Mapleville, RI
    Just overclocked the CPU to 3.6ghz and ran Prime95 for 2 hours just fine. Do I need to increase the voltage or anything? What does that do exactly?
  6. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,516 (2.11/day)
    2,473
    S.E. Virginia
    no, if your system is running smooth, you don't need to increse any voltages
    Crunching for Team TPU
  7. BarbaricSoul
    BarbaricSoul
    Feb 21, 2008
    5,516 (2.11/day)
    2,473
    S.E. Virginia
    can you give us a CPU-Z pic of your current settings?
  8. fullinfusion
    Jan 11, 2008
    8,605 (3.23/day)
    2,383
    no leave the voltages alone.. increasing the voltage allows you to clock higher but not always a guaranty, voltages help to stabilize a clock but with more volts bring more heat. Make sure you stay below 62c
  9. Pestilence New Member
    Apr 5, 2011
    587 (0.40/day)
    67
    If you have Lag installing it's probably your hard drive. Also up the NB speed. My 1090T with the stock NB sucked
  10. Zaspera New Member
    Jan 5, 2011
    500 (0.32/day)
    11
    Mapleville, RI
    [​IMG]
    [​IMG]
    The cpu is running at about 38°C right now under medium load, which is all I ever run it at.
  11. Zaspera New Member
    Jan 5, 2011
    500 (0.32/day)
    11
    Mapleville, RI
    Bump
Share This Page
