Current Project: AMD 64 x2 6400BE / 8800GTX x2 / Air-Water Cooling Status:Final Tweak
Discussion in 'Project Logs' started by PyroX1040, Dec 23, 2007.
  1. PyroX1040 New Member
    Dec 17, 2007
    283 (0.09/day)
    13
    Chicago, IL
    Current Project Rig:
    CPU:
    AMD Athlon X2 64 6400+ Black Edition - 3.2Ghz Stock - 3.6Ghz [OC]
    Thermal Paste: Arctic Silver 5 Thermal Compound
    GPU1:
    nVidia EVGA 8800GTX 768MB 384Mbit - 576/1800 Stock - 666/2000 [OC]
    GPU2:
    Hard Drive(s):
    Sata 1: Western Digital Raptor X 150GB 10,000RPM
    Sata 2: Western Digital Raptor X 150GB 10,000RPM
    Motherboard:
    ASUS M2N32-SLI Deluxe Wireless Edition
    Ram:
    Ram Stick 1: Kingston HyperX 1GB 800Mhz
    Ram Stick 2: Kingston HyperX 1GB 800Mhz
    Ram Stick 3: Kingston HyperX 1GB 800Mhz
    Ram Stick 4: Kingston HyperX 1GB 800Mhz
    Sound Card:
    Creative Sound Blaster X-Fi Fatal1ty Series
    Computer Case:
    NZXT Full Tower ATX Computer Case
    Cooling For CPU:
    ZALMAN CNPS9700 LED 110mm 2 Ball CPU Cooler
    Case Cooling:
    4 Side Mounted 2,500RPM Fans 120mm [Intake] - Stock NZXT
    2 Back Mounted 3,200RPM Fans 120mm [Out-Take] - After Market Scythe
    1 Front Mounted 3,200RPM Fan 120mm [Intake] - After Market Scythe
    1 Bottem Mounted 2,000RPM Fan 80mm [Intake - After Market Scythe
    1 Top Mounted 2,000RPM Fan 80mm [Out-Take] - After Market Scythe
    2 Internal Hard 2,000RPM Fan 80mm [Out-Take] - After Market Scythe
    1 Internal Fan > VGA 2,500RPM Fan 92mm [Intake] - After Market Scythe
    2 Internal Memory 1,500RPM Fan 60mm [Out-Take] - After Market OCZ
    Fan Controller:
    ZALMAN MFC1 Plus-B Black 6 Channel Multi Fan Controller
    Power Supply Unit:
    Silver Stone Strider ST1000 1000W Modular Power Supply
    Operation System:
    Windows XP 64-Bit 2003 Professional
    Over Clock Settings:
    Video Cards: 666/2000 GPU1 | 666/2000 GPU2
    CPU 1: 3.6Ghz 1.55V
    CPU 2: 3.6Ghz 1.55V
    Benchmarks:
    3D Mark 06' - 11500 - Stock Settings
    Current Status
    Disassembled and being cleaned and un-dusted and waiting on arrival on replacement 8800GTX
    GPU-Z Validation:
    http://www.techpowerup.com/gpuz/4hnm2/
    CPU-Z Validation:
    http://valid.x86-secret.com/show_oc.php?id=290486
    ***Updated Sunday, January 20th, 2008 10:00AM CST***
  2. PyroX1040 New Member
    Dec 17, 2007
    283 (0.09/day)
    13
    Chicago, IL
    **Updated**
  3. jds21
    jds21 New Member
    Jan 12, 2008
    178 (0.06/day)
    2
    Melbourne, Australia
    I want that system!!!... other than the AMD CPU, give me Intel any day...
    PyroX1040 says thanks.
  4. ShadowFold
    ShadowFold New Member
    Dec 23, 2007
    16,921 (5.69/day)
    1,642
    Omaha, NE
    lucky you! Nice set up there.
  5. pbmaster
    pbmaster New Member
    Aug 6, 2006
    2,590 (0.74/day)
    292
    Savannah, GA
    That's a nice rig you have there.
  6. jds21
    jds21 New Member
    Jan 12, 2008
    178 (0.06/day)
    2
    How mcuh did all of that cost you??? That is by no means an inexpensive system... I wish I had the money to build a system like that
  7. PyroX1040 New Member
    Dec 17, 2007
    283 (0.09/day)
    13
    Chicago, IL
    This system is by far the best AMD system out there with the 2 8800GTX's pumping out amazing scores and everything else HOW EVER I recently had 1 of the 2 8800GTX short circuit due to... god noes why.... either way the new one should be here late this week I'm testing it right now with a Sapphire ATI Radeon X1650 running 600/1400 and might be getting a second one just to screw with it ^.^ I love this little card actually not as good as the 8800 but i just love it cause it cost 50 n is amazing ^.^
    As far as the price goes it's been about $1850 with everything except if you add on shipping which is about another $250 for all the parts and another $40 for new wiring, tape, glue, thermal paste... soooo either way It's about $2000USD and I can't say anything bad about it it's amazing!
  8. PyroX1040 New Member
    Dec 17, 2007
    283 (0.09/day)
    13
    Chicago, IL
    ***Updated***
  9. philbrown23
    philbrown23 New Member
    Dec 22, 2007
    1,231 (0.41/day)
    147
    vermont
    um you cpu-z validation says 3.2ghz not 3.6ghz you may want to update that. just a thought ;)
  10. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,482 (5.98/day)
    4,523
    Youngstown, OH
    No offense to you Pyro, but I thought you would have went with dual GT's not GTX's. Meh, still a kickin rig anyway you put it.
    I mean c'mon raptors in raid really can't get much better unless you purchase some really kickass SSD's.
  11. PyroX1040 New Member
    Dec 17, 2007
    283 (0.09/day)
    13
    Chicago, IL
    Neva!
  12. PyroX1040 New Member
    Dec 17, 2007
    283 (0.09/day)
    13
    Chicago, IL
    I know but currently It's apart and being cleaned aswell as waiting on the newest 8800GTX so I'll be fixing that later tonight, also I prefer the GTX not the GT I was thinking about 2 8800GTS G92
  13. jds21
    jds21 New Member
    Jan 12, 2008
    178 (0.06/day)
    2
    I personally would have gone for the GTS but that's for the reason of money...
    but when it comes to SLI (as much as I am no fan of ATI) I have to admit that Crossfire appears to be much better than SLI but Nvidia seems better in single card setup.... just my opinion
  14. PyroX1040 New Member
    Dec 17, 2007
    283 (0.09/day)
    13
    Chicago, IL
    Updated: Currently still waiting for newegg to send my 8800 back to me seeing as it went boom >.< the conductors on the back of the card well one of them overheated some how and caused the card to discharge static and literly melted one of the conductors no idea HOW that happened >.> but it did, go go warrenty!
    Either way I will be doing some work and completely disassembling the PC today and I shall post pictures of my latest task which inculdes:
    -Re-Painting the exterior to the case
    -Painting the interior of the frame to the case
    -Painting some of the wires straight black to allow them to be hidden / tucked away.
  15. jds21
    jds21 New Member
    Jan 12, 2008
    178 (0.06/day)
    2
    sounds like a plan
  16. PyroX1040 New Member
    Dec 17, 2007
    283 (0.09/day)
    13
    Chicago, IL
    I'd agree with that statement except for the fact being that ATI cards can preform alot better if ATI decided to go for it and get smart on their single/crossfire GPU cards >.> other wise I"m an Nvidia Fan Boi :(
  17. vexen
    vexen
    Oct 13, 2005
    192 (0.05/day)
    12
    oh i tough the same thing until..... today LOL.
    Lost hope on AMD, i mean, i want to overclock, and 150MHz is not overclock (i'm talking about the Phenoms)
    nice rig.
    I'm not a Kingston/Asus Fan tho.
    10 Year Member at TPU
