Decent fans + fan controller? help!
Discussion in 'General Hardware' started by kyle2020, Jan 11, 2009.
  1. kyle2020 Guest
    Right I need some serious recommendations on some decent fans and a fan controller*
    The fans need to have decent CFM whilst maintaining a low decibel rating, as two will be used on my radiator to replace these unbearable yate loons (noisy as hell, not air noise its a rumbling noise, I assume they are both knackered) and 4 others to be used inside my case.
    So far its a toss up between these fans
    Contender #1
    Contender #2
    As for the fan controller, at this point Im open to any suggestions!
    Thanks!
    *However if better fans at a higher decibel rating are found, then i also need recommendations on a decent fan controller - must be black, and have more than 4 fan connectors
  2. trickson
    trickson OH, I have such a headache
    Dec 5, 2004
    6,494 (1.83/day)
    956
    Planet Earth.
  3. kyle2020 Guest
    Wow, how expensive is that fan controller?! :laugh:
    I have found this one on ebuyer - not the prettiest / most well known, but im buying it anyway.
    Im going to get those XLF's I think, just 2 at the minute, then get another 4 down the line.
  4. trickson
    Dec 5, 2004
    6,494 (1.83/day)
    956
    Planet Earth.
    Well god dude you could have done it yourself then . I did the leg work and you :nutkick:
  5. oli_ramsay
    oli_ramsay
    Sep 22, 2007
    3,476 (1.37/day)
    569
    UK
    i have that fan controller and it's awesome (esp. for the price). It's basically a rip of off the Sunbeam Rheobus Extreme but 1/4 of it's price :p
    It's LEDs are extremely bright though!
    http://www.ebuyer.com/product/149248 These fans seem OK, they're silent at 19db but only 50CFM.
  6. King Wookie
    King Wookie New Member
    Jan 1, 2008
    1,197 (0.49/day)
    277
    Johannesburg, South Africa
    If you are buying fans, this is worth a look:
    file:///C:/Documents%20and%20Settings/Wayne/Desktop/Bits%20etc/fan%20review%20links.htm
    Saying which, I've seen some very experienced builders using the Xigs, so they can't be all that bad.
    Otherwise on a budget the Zalmans are good buys.
  7. fenurch
    fenurch
    Feb 4, 2008
    667 (0.28/day)
    70
    I would strongly recommend not buying stuff from cclonline.com, had major problems, tried to get a refund after about 3 days of arrival (hadn't even used them) and they refused to receive them back and give me a different pair. More like - didn't care not refused.
  8. King Wookie
    Jan 1, 2008
    1,197 (0.49/day)
    277
    Whoops! Didn't realise I put up a bad link. Here's the right one:
    http://forums.techpowerup.com/showpost.php?p=1099122&postcount=625
  9. MoonPig
    MoonPig
    Aug 7, 2008
    5,729 (2.59/day)
    886
    Wakefield, UK
    I have 4 x 120 Akasas (push alot of air) and a xilence fan controller for sale.
  10. kyle2020 Guest
    old thread is old. lol. Dont worry moon, I got some Xigmatek XLF's and a fan controller of ebuyer ages ago - this thread should be gone by now haha.
  11. MoonPig
    MoonPig
    Aug 7, 2008
    5,729 (2.59/day)
    886
    Wakefield, UK
    haha, i didn't look at the dates. Just saw "last post" and that it was like 5mins ago... lol. Sorry.
  12. fenurch
    fenurch
    Feb 4, 2008
    667 (0.28/day)
    70
    LOL so did I ;D I just necro-posted
    *smacks himself*
  13. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (3.11/day)
    862
    Dorset, UK
    I always try and update the OP once the solution is sorted so people know they dont need to help anymore.
Share This Page
