DESERT STORM - By Mathmodding
151 (0.03/day)
Hi to all,
After a mod (Shielding War TUF) based on the full armor and a Modified ANTEC LanBoy Air that you can find here http://www.techpowerup.com/gallery/3725.html this time the purpose and quite simple : grand tour case, watercooling CPU + SLI, sand camo paint all components, casing complete your alim three, all related to the Gulf War.
Sponsors:
SEASONIC, NOCTUA, KINGSTON, SASSANOU WATERMOD
config.
case: Xigmatek Elysium
Motherboard: asus sabertooth Z77
Cpu: Intel I7 3770K
ram: 16GO PC3-14900 Kingston HyperX cas9
SSD: 2 120go Kingston HyperX 3K on RAID0
Graphics card: SLI Asus GTX670 DCUII watercollé
Power supply: seasonic X-1050w
Fans: 100% Noctua NF-F12 PWM​
Cooling:
Pump: Laing DDC 1T+ 18w + top EK
Tank: Swiftek microres rev2.0
Waterblock CPU: EK LTX supremacy acetal/nikel
Waterblock VGA: X2 EK-FC670 GTX DCII
Radiators: 1 EK XT coolstream 240 + 1 XSPC 360 in Pull/Push
fansless: Full Noctua NF-F12 PWM​
Ok, back cover is
I have no use of having openings on the case back because I am full Watercool (SLI + CPU). So I shut up!
Less dust that enters and it also contains some noise. Of course, all will be painted
I present to you a sneak preview of the sleeve carbon of the new collection of [url]https://www.facebook.com/veday.shop [/ url]
Living next to each other it was easy to get in touch with him. I thank him very much for allowing me to use this marvel of carbon sleeve of a very high quality.
I use it on my PSU SATA cables
And as you do not stop in so good way, that is the upper plate fan cut
dremel thank you ^ ^
A super Aprem modding for me
[/URL]​
http://[URL]https://www.facebook.com/veday.shop
Well now the CM + CG rendering.
Varnish and past, the only downside and the backplate are not set for the simple reason that the waterblock uses screw locations for the backplate (random).
So now I'm looking a way to set the backplate (adhesive ect ...).
Thermal Armor up and Noctua 40mm fan positioned.
nice, now if i still had my In Win Desert Fox PSU it would totally fit the pattern and theme chosen :D
Interesting. So there ARE color schemes where Noctua's products will fit in well. Great execution so far :)
And now the long-awaited release Xigmatek case for "Desert Storm" MOD By Mathmodding
Much work remains to be done on the doors, front face, ect ...
This part will remain unchanged but many elements will come in camo
hello guys,
Laser cut plexi for my mod "desert storm". New front end, new door, supports SSD.
Now, towards the airbrush painting
Stay tuned
awesome keep it going!
Goodie chocolate chip dcu
Awesome, sub'd here too. No paint on the PSU? Cables are gorgeous.
Great Job!
