DIY Self contained water cooling
Discussion in 'General Hardware' started by james888, May 29, 2012.
  1. james888
    james888
    Jun 27, 2011
    5,458 (3.22/day)
    2,828
    Do do it yourself self contained watercooling exist. I seen pictures of modded self contained coolers. I am just curious. Searching my google mystic ball didn't bring any results.
  2. MT Alex
    MT Alex
    Aug 2, 2009
    3,980 (1.67/day)
    1,790
    I'm not sure what you mean. All custom water cooling loops are self contained. If they weren't all of your components would get wet.
  3. Kantastic
    Kantastic
    May 12, 2009
    5,180 (2.10/day)
    997
    Set up a water loop and seal it up with rubber cement?
  4. boogerlad
    Jun 29, 2006
    226 (0.06/day)
    12
    premade components are much better than diy stuff anyways, unless you happen to have very expensive cnc machinery.
  5. james888
    james888
    Jun 27, 2011
    5,458 (3.22/day)
    2,828
    YOur right. I meant like the pump and water block being the same thing like the self contained ones. I could of been a lot more clear.
    I do know regular water cooling is a lot better and is DIY. As I said. Just curious. Since lepa now has their cooling loop thing I just was thinking what other products and diy projects were out there. I have seen the h60 modded to connect to a gpu.
  6. Kantastic
    Kantastic
    May 12, 2009
    5,180 (2.10/day)
    997
    Swiftech used to make one called the Apogee Drive, not sure why they discontinued it.
    james888 says thanks.
  7. Frag Maniac
    Frag Maniac
    Nov 9, 2010
    3,873 (2.01/day)
    1,097
    Funny how when you said DIY I thought you meant making everything from scratch, and here it seems you just meant modding a factory sealed unit vs picking out parts of a piece together loop.
    Yeah, the kind you're referring to do exist, but I've seen a few truly custom made ones where they bury copper pipes under ground and run hoses through the house. Now THAT'S DIY.
  8. cadaveca
    cadaveca My name is Dave
    Apr 10, 2006
    15,044 (4.18/day)
    8,553
    Beaumont, Alberta
    New one is for sale NAOW.
    http://www.swiftech.com/apogeedrive2.aspx
    Also available without MCP35X integrated.
  9. Yukikaze
    Yukikaze
    Sep 24, 2008
    2,323 (0.86/day)
    492
    cadaveca says thanks.
  10. Bo$$
    Bo$$ Lab Extraordinaire
    May 7, 2009
    5,578 (2.25/day)
    945
    London, UK
    Thermaltake used to make one, bigwater series?
  11. Yukikaze
    Yukikaze
    Sep 24, 2008
    2,323 (0.86/day)
    492
    That's not really what he meant, though. The TT BigWater was (is?) a low quality WC loop, not a compact loop with the pump/res integrated into the rad and/or block.
  12. james888
    james888
    Jun 27, 2011
    5,458 (3.22/day)
    2,828
    I was just wondering if some company made that. Thanks for being able to read through my half asleep typing.
  13. JrRacinFan
    JrRacinFan Served 5k and counting ...
    Mar 17, 2007
    19,482 (5.98/day)
    4,522
    Youngstown, OH
    Doesn't swiftech also make a rad with res/pump integrated? Is this what you mean james?
  14. Yukikaze
    Yukikaze
    Sep 24, 2008
    2,323 (0.86/day)
    492
    That ^^ :D Well, that's a kit, but it contains the rad+pump combo in it.
    JrRacinFan says thanks.
  15. brandonwh64
    brandonwh64 Addicted to Bacon and StarCrunches!!!
    Sep 6, 2009
    19,229 (8.18/day)
    6,681
    Chatsworth, GA
    If it was WIY then it would not be self contained correct?
    Crunching for Team TPU
  16. JrRacinFan
    Mar 17, 2007
    19,482 (5.98/day)
    4,522
    Youngstown, OH
    All WCing is self contained. All WCing is custom if it's not a prebuilt AIO. Again, unsure what james is asking.
    Yup .. and it was posted above
    http://www.sidewindercomputers.com/swmire2bmowp.html
    Just correcting myself LOL
    EDIT:
    Wow it's pretty bad when you can reply to AND quote yourself.
    Yukikaze says thanks.
  17. brandonwh64
    Sep 6, 2009
    19,229 (8.18/day)
    6,681
    Chatsworth, GA
    Not always true. you still need to have additives and to clean your loop out regularly due to build up. The AIO kits are made to install and never deal with again.
  18. JrRacinFan
    Mar 17, 2007
    19,482 (5.98/day)
    4,522
    Youngstown, OH
    I would love to know what they put in them then. LOL
  19. brandonwh64
    Sep 6, 2009
    19,229 (8.18/day)
    6,681
    Chatsworth, GA
    TBH I wouldn't want to know what they look like inside after a couple of years :roll: :laugh:
  20. james888
    james888
    Jun 27, 2011
    5,458 (3.22/day)
    2,828
    I was wondering if there existed a block+pump. Like the apogee. All the AIO self contained units use these. Thats where I got the self contained units. Not that I am or should, but could make your own much more expensive unit similar to the AIO's. I was just curious if that existed. In my mind I was stuck on self contained units having it, and should of just asked if there was a block+pump combo.
    My curiosity has been fed.
  21. brandonwh64
    Sep 6, 2009
    19,229 (8.18/day)
    6,681
    Chatsworth, GA
    If you have the money a XSPC rasa kit is very nice! A friend had one and it cools great!
  22. JrRacinFan
    Mar 17, 2007
    19,482 (5.98/day)
    4,522
    Youngstown, OH
    Was just thinking. A good alternate to the corsair h100 :)
  23. cadaveca
    Apr 10, 2006
    15,044 (4.18/day)
    8,553
    Beaumont, Alberta
    Glycol. Hence the low maintainece needed, as coolers like the H100 and Antec 690 aren't actually "watercoolers"...they are actually "glycolcoolers". I knwo for a fact the Corsair coolers are Propylene Glycol, says so in the manual.
    And becuase they use glycol, camparing them to other water loops is kinda silly...unless you plan on filling that lopp with glycol as well! Kinda completely different coolants!
  24. HossHuge
    HossHuge
    Jun 26, 2008
    2,242 (0.80/day)
    723
    EDM, AB, CAN
  25. james888
    james888
    Jun 27, 2011
    5,458 (3.22/day)
    2,828
    Really. I was just curious. Thank you all for feeding my curiosity. If I had waited just another day I would of seen the tpu article about the apogee II and would not of started this thread. I don't have plans to start water cooling soon. My cpu never goes past 65C, while overclocked, and all the while being silent with my gelid tranquillo. If anything I want a quieter gpu and have been considering an asus 670 top if I had the money for it.
