does better cooling result in higher overclocking?
Reggie220
7 (0.00/day)
Processor AMD64 3200 Venice 2.0ghz @ 2.45ghz
Motherboard AsRock 939 Dual-SATAII
Cooling Thermaltake TR2TT A4014
Memory 2x1gb Mushkin PC-4000
Video Card(s) EVGA 7800gt w/Zalman VF700LED cooler
Storage Western Digital 80gb SATA, Samsung 160gb SATAII
Display(s) Acer AL1914smd 19" LCD
Case Powmax Dragon
Audio Device(s) Philips Alurium2 External
Power Supply Ultra x-connect 500W
Just want to know if better cooling results in a higher stable clock when overclocking a video card or does it just make for a safer overclock. I have a x800 gto2 that won't go past 500 core clock using ati tool and was wondering if its because of using the stock cooling. It gets up to about 70C which is hot, but I don't think dangerously hot.
its not dangerously hot, no, but i would definantly consider a better cooling solution if i were you.
the stock coolers on the gto2's are pretty good (at least from what i can gather, as i dont actually have one...). but a better cooling solution *can* quite possibly get you a higher overclock, but most importantly i would greatly help increase the lifespan of your card.
