Does increasing VDDQ voltage help or hurt ur vid card?
DopplersEffect
7 (0.00/day)
I have heard that raising the VDDQ voltage in your motherboard bios settings does NOT help overclock your video card. BUT, if you raise the VDDQ voltage it WILL HELP overclock your CPU
SO I wanted to ask, I have an X850PRO that I flashed to X850XTPE, will raising my VDDQ hurt the video card? And if so, how far can I raise it? I can set mine at 1.5-1.7 V. Increasing helps CPU overclocking
What does the VDDQ control, Vcore on the GPU? AGP bus? I'm clueless
8,253 (1.24/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
so what is the VDDQ voltage exactly.. my mobo has no such option..
i have a vcore option.. i know what that does.. it alters the cpu voltage
i have no mobo option that will increase the voltage to the gpu..
a lot of what u hear is bullshit by the way.. that kinda helps keep most folks clueless.. he he he
trog
DopplersEffect
7 (0.00/day)
I have an p4p800-e dlx motherboard. There IS an option to increase the "AGP VDDQ" voltage. I do not know if the VDDQ voltage is the VCore voltage on the GPU or not. Anyone run across this?
JC316
Knows what makes you tick
9,397 (1.42/day)
System Name Budget Gaming
Processor AMD FX6300
Motherboard Gigabyte 880GMA-USB3
Cooling Coolermaster Hyper 212+
Memory 8GB Ripjaws DDR3 1600
Video Card(s) HD7850 1GB
Storage 1TB Sata2
Display(s) Acer 24" LED
Case Generic black
Audio Device(s) Stock onboard
Power Supply FSP Aurum Gold 650W
Software Windows 7 Home Premium 64bit
On my X1800GTO MVDDQ is the voltage of the memory output buffers. I have found that it can add some stability.
8,253 (1.24/day)
i would 99% for certain say it isnt.. to the best of my knowledge nothing except the cards bios or with later cards the cards drivers will alter the gpu core voltage..
trog
