- Jun 20, 2007
- 3,942 (0.64/day)
System Name | Widow |
Processor | Ryzen 7600x |
Motherboard | AsRock B650 HDVM.2 |
Cooling | CPU : Corsair Hydro XC7 }{ GPU: EK FC 1080 via Magicool 360 III PRO > Photon 170 (D5) |
Memory | 32GB Gskill Flare X5 |
Video Card(s) | GTX 1080 TI |
Storage | Samsung 9series NVM 2TB and Rust |
Display(s) | Predator X34P/Tempest X270OC @ 120hz / LG W3000h |
Case | Fractal Define S [Antec Skeleton hanging in hall of fame] |
Audio Device(s) | Asus Xonar Xense with AKG K612 cans on Monacor SA-100 |
Power Supply | Seasonic X-850 |
Mouse | Razer Naga 2014 |
Software | Windows 11 Pro |
Benchmark Scores | FFXIV ARR Benchmark 12,883 on i7 2600k 15,098 on AM5 7600x |
There's a tech team not far from where I live, setting up some dual monitor systems. They are not running 3d applications, rather a lot of text data in streaming/persistent scrolling format.
Currently they are using AMD X2 6400s, 4GiG DDr2 RAM and a Matrox GPU found here : http://www.dabs.com/productview.aspx?quicklinx=50R8
Originally the guys had been using an Nvidia GTS 512, and found that it couldn't keep up with the refreshing of the scrolling data across the 'second' screen. They then moved to the Matrox because they are designed for this type of thing; and by looking at their products I would have to agree.
However the guys are still facing the same slow response/chugging on the second monitor. They've switched physical monitors and nothing changed.
I've looked at the drivers, the rest of the components, the background services etc.
Nothing seems to be wrong. The CPU and RAM usage is fine during all of this.
I'm not really big on multiple monitor solutions.
What are some common/known variables that could cause such a response on the second screen?
