Dvd drive problem, Please help :)
Discussion in 'General Hardware' started by Waterer, Oct 10, 2006.
  1. Waterer New Member
    Oct 10, 2006
    5 (0.00/day)
    0
    Hello, I have a problem which I am hoping that with your help I will be able to sort out :)
    Recently, prior to formatting my hard-drive I backed up my music, photos, coursework etc. onto DVDs, I burnt them all fine and after formatting the hdd i reinstalled windows and attempted to retrieve my backed up data, which I found out I could not
    I have tried two different drives a Lite-On DVDRW SHW-16H5S and a Philips DVD8631 HH 16X DVD+/-RW both of which return a 'F:\ is not accessible, Incorrect Function' error, I have tried flashing both drives to the latest firmware and also deleting the upperfilters and lowerfilters from the registry.
    My data was backed up onto DVD-R media which I know to be of a high quality, and the discs read fine in an identical machine with the same Lite-On drive, so ruling them out of the possible problems.
    The Lite-On drive is currently in my machine and if possible it is the one I would much rather sort out and use.
    I do not have any CD-DVD burning software on my machine, although I did try the Nero 6 Suite that came with the Lite-On drive, which solved nothing.
    Any help you can give would be greatly appreciated :)
    Cheers
    Sam
    (I've included my DxDiag infomation aswell, just incase it is any use..)
    System Information
    Time of this report: 10/10/2006, 21:35:06
    Machine name: DELL---XPS
    Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
    Language: English (Regional Setting: English)
    System Manufacturer: Dell Inc.
    System Model: Dimension XPS
    BIOS: Phoenix ROM BIOS PLUS Version 1.10 A07
    Processor: Intel(R) Pentium(R) 4 CPU 3.20GHz (2 CPUs)
    Memory: 1022MB RAM
    Page File: 323MB used, 2136MB available
    Windows Dir: D:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
    DxDiag Version: 5.03.2600.2180 32bit Unicode
    DxDiag Notes
    DirectX Files Tab: No problems found.
    Display Tab 1: No problems found.
    Sound Tab 1: No problems found.
    Music Tab: No problems found.
    Input Tab: No problems found.
    Network Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (n/a)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (n/a)
    DirectMusic: 0/5 (n/a)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: RADEON X800GT
    Manufacturer: ATI Technologies Inc.
    Chip type: RADEON X800 GT (0x554B)
    DAC type: Internal DAC(400MHz)
    Device Key: Enum\PCI\VEN_1002&DEV_554B&SUBSYS_03021002&REV_00
    Display Memory: 128.0 MB
    Current Mode: 1152 x 864 (32 bit) (100Hz)
    Monitor: Plug and Play Monitor
    Monitor Max Res: 1600,1200
    Driver Name: ati2dvag.dll
    Driver Version: 6.14.0010.6635 (English)
    DDI Version: 9 (or higher)
    Driver Attributes: Final Retail
    Driver Date/Size: 8/23/2006 02:53:30, 260096 bytes
    WHQL Logo'd: Yes
    WHQL Date Stamp: n/a
    VDD: n/a
    Mini VDD: ati2mtag.sys
    Mini VDD Date: 8/23/2006 02:53:14, 1723904 bytes
    Device Identifier: {D7B71EE2-160B-11CF-596A-0823A1C2CB35}
    Vendor ID: 0x1002
    Device ID: 0x554B
    SubSys ID: 0x03021002
    Revision ID: 0x0000
    Revision ID: 0x0000
    Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
    Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
    {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
    Registry: OK
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Enabled
    DDraw Test Result: Not run
    D3D7 Test Result: Not run
    D3D8 Test Result: Not run
    D3D9 Test Result: Not run
    Sound Devices
    Description: SB Audigy 2 Audio [C8C0]
    Default Sound Playback: Yes
    Default Voice Playback: Yes
    Hardware ID: PCI\VEN_1102&DEV_0004&SUBSYS_10031102&REV_04
    Manufacturer ID: 1
    Product ID: 100
    Type: WDM
    Driver Name: ctaud2k.sys
    Driver Version: 5.12.0001.1164 (English)
    WHQL Logo'd: Yes
    Date and Size: 12/8/2005 11:55:46, 439296 bytes
    Other Files:
    Driver Provider: Creative
    HW Accel Level: Full
    Cap Flags: 0xF5F
    Min/Max Sample Rate: 4000, 192000
    Static/Strm HW Mix Bufs: 64, 62
    Static/Strm HW 3D Bufs: 64, 62
    HW Memory: 0
    Voice Management: Yes
    EAX(tm) 2.0 Listen/Src: Yes, Yes
    I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Registry: OK
    Sound Test Result: Not run
    Sound Capture Devices
    Default Sound Capture: Yes
    Default Voice Capture: Yes
    Cap Flags: 0x41
    Format Flags: 0xFFF
    Description: USB Audio Device
    Default Sound Capture: No
    Default Voice Capture: No
    Driver Name: usbaudio.sys
    Driver Version: 5.01.2600.2180 (English)
    Date and Size: 8/4/2004 00:07:56, 59264 bytes
    Cap Flags: 0x41
    Format Flags: 0x4
    DirectMusic
    DLS Path: D:\WINDOWS\SYSTEM32\drivers\GM.DLS
    DLS Version: 1.00.0016.0002
    Acceleration: Enabled
    Ports: SB Audigy 2 DirectMusic Synthesizer [C8C0], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
    SB Audigy 2 Audio [C8C0], Software (Kernel Mode), Output, DLS, Internal
    Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
    SB Audigy 2 Synth A [C8C0] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
    SB Audigy 2 Sw Synth [C8C0] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
    SB Audigy 2 Synth B [C8C0] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
    Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
    Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
    Registry: OK
    DirectInput Devices
    Device Name: Mouse
    Attached: 1
    Controller ID: n/a
    Vendor/Product ID: n/a
    FF Driver: n/a
    Device Name: Keyboard
    Attached: 1
    Controller ID: n/a
    FF Driver: n/a
    Poll w/ Interrupt: No
    Registry: OK
    USB Devices
    + USB Root Hub
    | Vendor/Product ID: 0x8086, 0x265B
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
    | Driver: usbd.sys, 8/12/2004 14:31:49, 4736 bytes
    +-+ USB Human Interface Device
    | | Vendor/Product ID: 0x046D, 0xC01E
    | | Matching Device ID: usb\class_03&subclass_01
    | | Service: HidUsb
    | | Driver: hidclass.sys, 8/12/2004 14:19:35, 36224 bytes
    | | Driver: hidparse.sys, 8/12/2004 14:19:35, 24960 bytes
    | | Driver: hid.dll, 8/12/2004 14:29:28, 20992 bytes
    | | Driver: hidusb.sys, 8/12/2004 14:19:36, 9600 bytes
    | +-+ HID-compliant mouse
    | | | Matching Device ID: hid_device_system_mouse
    | | | Service: mouhid
    | | | Driver: mouclass.sys, 8/12/2004 14:29:28, 23040 bytes
    | | | Driver: mouhid.sys, 8/12/2004 14:18:51, 12160 bytes
    Gameport Devices
    PS/2 Devices
    + Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
    | Matching Device ID: *pnp0303
    | Service: i8042prt
    | Driver: i8042prt.sys, 8/12/2004 14:19:46, 52736 bytes
    | Driver: kbdclass.sys, 8/12/2004 14:20:28, 24576 bytes
    + Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    | Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
    + Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    DirectPlay Service Providers
    DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
    IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
    Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
    Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
    DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
    DirectPlay Test Result: Not run
    Registry: OK
    DirectPlay Adapters
    DirectPlay8 Modem Service Provider: Intel(R) 537EP V9x DF PCI Modem
    DirectPlay8 Serial Service Provider: COM1
    DirectPlay8 Serial Service Provider: COM3
    DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
    DirectPlay Voice Codecs
    Voxware VR12 1.4kbit/s
    Voxware SC06 6.4kbit/s
    Voxware SC03 3.2kbit/s
    MS-PCM 64 kbit/s
    MS-ADPCM 32.8 kbit/s
    Microsoft GSM 6.10 13 kbit/s
    TrueSpeech(TM) 8.6 kbit/s
    DirectPlay Lobbyable Apps
    Disk & DVD/CD-ROM Drives
    Drive: C:
    Free Space: 3.9 GB
    Total Space: 25.0 GB
    File System: NTFS
    Model: WDC WD2500JD-75HBB0
    Drive: D:
    Free Space: 187.3 GB
    Total Space: 213.4 GB
    File System: NTFS
    Drive: E:
    Model: HL-DT-ST CD-RW GCE-8483B
    Driver: d:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/12/2004 14:17:38, 49536 bytes
    Drive: F:
    Model: LITE-ON DVDRW SHW-16H5S
    System Devices
    Name: Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
    Device ID: PCI\VEN_8086&DEV_266F&SUBSYS_01761028&REV_03\3&172E68DD&0&F9
    Driver: D:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 13:51:52, 3328 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:42, 25088 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
    Name: Intel(R) 82801FB/FBM SMBus Controller - 266A
    Device ID: PCI\VEN_8086&DEV_266A&SUBSYS_01761028&REV_03\3&172E68DD&0&FB
    Driver: n/a
    Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2662
    Device ID: PCI\VEN_8086&DEV_2662&SUBSYS_00000000&REV_03\3&172E68DD&0&E1
    Driver: D:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 23:07:48, 68224 bytes
    Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2660
    Device ID: PCI\VEN_8086&DEV_2660&SUBSYS_00000000&REV_03\3&172E68DD&0&E0
    Name: Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
    Device ID: PCI\VEN_8086&DEV_265C&SUBSYS_01761028&REV_03\3&172E68DD&0&EF
    Driver: D:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
    Driver: D:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
    Driver: D:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
    Driver: D:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
    Driver: D:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/12/2004 14:19:32, 7168 bytes
    Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
    Device ID: PCI\VEN_8086&DEV_265B&SUBSYS_01761028&REV_03\3&172E68DD&0&EB
    Driver: D:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 20480 bytes
    Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
    Device ID: PCI\VEN_8086&DEV_265A&SUBSYS_01761028&REV_03\3&172E68DD&0&EA
    Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
    Device ID: PCI\VEN_8086&DEV_2659&SUBSYS_01761028&REV_03\3&172E68DD&0&E9
    Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
    Device ID: PCI\VEN_8086&DEV_2658&SUBSYS_01761028&REV_03\3&172E68DD&0&E8
    Name: Intel(R) 82801FR SATA AHCI Controller
    Device ID: PCI\VEN_8086&DEV_2652&SUBSYS_01761028&REV_03\3&172E68DD&0&FA
    Driver: D:\WINDOWS\system32\DRIVERS\iaStor.sys, 4.05.0000.6515 (English), 6/29/2004 11:17:16, 477952 bytes
    Name: Intel(R) 82801FB LPC Interface Controller - 2640
    Device ID: PCI\VEN_8086&DEV_2640&SUBSYS_00000000&REV_03\3&172E68DD&0&F8
    Driver: D:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytes
    Name: Intel(R) 925X/XE PCI Express Root Port - 2585
    Device ID: PCI\VEN_8086&DEV_2585&SUBSYS_00000000&REV_04\3&172E68DD&0&08
    Name: Intel(R) 925X/XE Memory Controller Hub - 2584
    Device ID: PCI\VEN_8086&DEV_2584&SUBSYS_00000000&REV_04\3&172E68DD&0&00
    Driver: n/a
    Name: Intel(R) 82801 PCI Bridge - 244E
    Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_D3\3&172E68DD&0&F0
    Name: Intel(R) 537EP V9x DF PCI Modem
    Device ID: PCI\VEN_8086&DEV_1080&SUBSYS_10001028&REV_04\4&10416D21&0&08F0
    Driver: D:\WINDOWS\system32\DRIVERS\IntelC51.sys, 2.15.0036.0000 (English), 3/5/2004 22:14:42, 1233525 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\IntelC52.sys, 4.58.0005.0000 (English), 3/5/2004 22:15:34, 647929 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\IntelC53.sys, 2.15.0036.0000 (English), 3/5/2004 22:13:52, 60949 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\mohfilt.sys, 7.11.0000.0000 (English), 3/5/2004 22:13:38, 37048 bytes
    Driver: D:\WINDOWS\system32\intelmoh.dll, 1.00.0000.0000 (English), 3/5/2004 22:13:26, 172032 bytes
    Driver: D:\WINDOWS\system32\mhwt.dll, 1.00.0000.0000 (English), 3/5/2004 22:13:12, 53248 bytes
    Driver: D:\WINDOWS\system32\IntelCci.dll, 5.00.0000.0000 (English), 3/5/2004 22:12:56, 34293 bytes
    Name: Broadcom NetXtreme 57xx Gigabit Controller
    Device ID: PCI\VEN_14E4&DEV_1677&SUBSYS_01761028&REV_01\4&1D7EFF9E&0&00E0
    Driver: D:\WINDOWS\system32\DRIVERS\b57xp32.sys, 7.86.0000.0000 (English), 8/23/2004 14:49:30, 121472 bytes
    Name: OHCI Compliant IEEE 1394 Host Controller
    Device ID: PCI\VEN_1102&DEV_4001&SUBSYS_00101102&REV_04\4&10416D21&0&12F0
    Driver: D:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/12/2004 14:25:40, 61056 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/12/2004 14:17:15, 53248 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/12/2004 14:29:28, 61824 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/12/2004 14:29:28, 60800 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 14:46:40, 6400 bytes
    Name: Creative SB Audigy 2 (WDM)
    Device ID: PCI\VEN_1102&DEV_0004&SUBSYS_10031102&REV_04\4&10416D21&0&10F0
    Driver: D:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 00:56:44, 4096 bytes
    Driver: D:\WINDOWS\system32\ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 00:56:58, 130048 bytes
    Driver: D:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.2180 (English), 8/3/2004 23:15:22, 140928 bytes
    Driver: D:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:00, 60288 bytes
    Driver: D:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.2180 (English), 8/3/2004 23:15:50, 145792 bytes
    Driver: D:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (English), 8/3/2004 23:08:04, 48640 bytes
    Driver: D:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/12/2004 14:29:28, 23552 bytes
    Driver: D:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.1164 (English), 12/8/2005 11:54:32, 501760 bytes
    Driver: D:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:55:46, 439296 bytes
    Driver: D:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:54:52, 114688 bytes
    Driver: D:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:55:48, 7168 bytes
    Driver: D:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:54:42, 142336 bytes
    Driver: D:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:54:40, 77824 bytes
    Driver: D:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:55:02, 754176 bytes
    Driver: D:\WINDOWS\system32\drivers\haP16v2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:55:04, 154112 bytes
    Driver: D:\WINDOWS\system32\drivers\haP17v2k.sys, 5.12.0001.1164 (English), 12/8/2005 11:55:08, 179712 bytes
    Driver: D:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0012 (English), 12/8/2005 12:20:14, 8192 bytes
    Driver: D:\WINDOWS\system32\ctdlang.dat, 12/8/2005 11:59:34, 293747 bytes
    Driver: D:\WINDOWS\system32\ctstatic.dat, 12/8/2005 11:52:12, 313207 bytes
    Driver: D:\WINDOWS\system32\ctdaught.dat, 12/8/2005 11:52:12, 53932 bytes
    Driver: D:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English), 12/8/2005 12:17:46, 33792 bytes
    Driver: D:\WINDOWS\system32\commonfx.dll, 5.12.0001.1164 (English), 12/8/2005 11:58:10, 87552 bytes
    Driver: D:\WINDOWS\system32\ctaudfx.dll, 5.12.0001.1164 (English), 12/8/2005 11:58:14, 536576 bytes
    Driver: D:\WINDOWS\system32\ctsblfx.dll, 5.12.0001.1164 (English), 12/8/2005 11:58:38, 548352 bytes
    Driver: D:\WINDOWS\system32\cteapsfx.dll, 5.12.0001.1164 (English), 12/8/2005 11:58:30, 157696 bytes
    Driver: D:\WINDOWS\system32\ctemupia.dll, 5.12.0001.1164 (English), 12/8/2005 11:58:58, 106496 bytes
    Driver: D:\WINDOWS\system32\piaproxy.dll, 5.12.0001.1164 (English), 12/8/2005 11:54:34, 73728 bytes
    Driver: D:\WINDOWS\system32\ctdproxy.dll, 5.12.0001.1164 (English), 12/8/2005 11:55:34, 71168 bytes
    Driver: D:\WINDOWS\system32\sfman32.dll, 5.12.0001.0130 (English), 12/8/2005 11:54:46, 21504 bytes
    Driver: D:\WINDOWS\system32\ctbas2w.dat, 12/8/2005 11:54:20, 140643 bytes
    Driver: D:\WINDOWS\system32\ctsbas2w.dat, 12/8/2005 11:52:38, 265066 bytes
    Driver: D:\WINDOWS\system32\SBAudigy.ico, 8/17/2001 12:42:28, 7406 bytes
    Driver: D:\WINDOWS\system32\Audigy.bmp, 11/13/2001 09:48:20, 1912 bytes
    Driver: D:\WINDOWS\system32\ctcoinst.dll, 3.00.0002.0011 (English), 12/8/2005 12:23:16, 81920 bytes
    Driver: D:\WINDOWS\system32\ctdvinst.dll, 0.03.0000.0031 (English), 12/8/2005 12:23:16, 146432 bytes
    Driver: D:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0467 (English), 11/10/2005 17:06:04, 340704 bytes
    Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
    Device ID: PCI\VEN_104C&DEV_8024&SUBSYS_01761028&REV_00\4&10416D21&0&38F0
    Name: RADEON X800GT Secondary
    Device ID: PCI\VEN_1002&DEV_556B&SUBSYS_03031002&REV_00\4&16EC1A1&0&0108
    Driver: D:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6635 (English), 8/23/2006 02:53:14, 1723904 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0008 (English), 8/23/2006 02:43:21, 45056 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 8/23/2006 03:14:37, 35056 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\ativckxx.vp, 7/17/2006 14:52:46, 58560 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 7/19/2006 16:08:04, 929 bytes
    Driver: D:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 7/19/2006 16:08:04, 917986 bytes
    Driver: D:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6635 (English), 8/23/2006 02:53:30, 260096 bytes
    Driver: D:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0319 (English), 8/23/2006 02:14:39, 290816 bytes
    Driver: D:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 8/23/2006 02:46:47, 26112 bytes
    Driver: D:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0431 (English), 8/23/2006 02:38:44, 2401984 bytes
    Driver: D:\WINDOWS\system32\ativvaxx.dll, 6.14.0001.0117 (English), 8/23/2006 02:33:45, 2510752 bytes
    Driver: D:\WINDOWS\system32\atiicdxx.dat, 8/16/2006 18:52:54, 133583 bytes
    Driver: D:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0008 (English), 8/23/2006 02:44:37, 53248 bytes
    Driver: D:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 8/23/2006 02:19:52, 17408 bytes
    Driver: D:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 16:01:04, 24064 bytes
    Driver: D:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4142 (English), 8/23/2006 02:45:13, 413696 bytes
    Driver: D:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4142 (English), 8/23/2006 02:46:29, 86016 bytes
    Driver: D:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2506 (English), 8/23/2006 02:47:13, 114688 bytes
    Driver: D:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0016 (English), 8/23/2006 02:46:55, 77824 bytes
    Driver: D:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2504 (English), 8/23/2006 02:46:41, 41984 bytes
    Driver: D:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0041 (English), 8/23/2006 02:21:15, 221184 bytes
    Driver: D:\WINDOWS\system32\ATIDEMGR.dll, 1.02.2425.37013 (English), 8/23/2006 02:33:47, 303104 bytes
    Driver: D:\WINDOWS\system32\atifglpf.xml, 6/22/2006 14:02:05, 6126 bytes
    Driver: D:\WINDOWS\system32\atioglxx.dll, 6.14.0010.6067 (English), 8/23/2006 02:24:58, 5140480 bytes
    Driver: D:\WINDOWS\system32\atioglx1.dll, 6.14.0010.1091 (English), 8/23/2006 02:27:07, 6684672 bytes
    Driver: D:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4004 (English), 8/23/2006 03:11:46, 307200 bytes
    Device ID: PCI\VEN_1002&DEV_554B&SUBSYS_03021002&REV_00\4&16EC1A1&0&0008
    DirectX Components
    ddraw.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:32 266240 bytes
    ddrawex.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:32 27136 bytes
    dxapi.sys: 5.01.2600.0000 English Final Retail 8/12/2004 14:18:57 10496 bytes
    d3d8.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:29 1179648 bytes
    d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:29 8192 bytes
    d3d9.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:29 1689088 bytes
    d3dim.dll: 5.01.2600.0000 English Final Retail 8/12/2004 14:18:29 436224 bytes
    d3dim700.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:29 825344 bytes
    d3dramp.dll: 5.01.2600.0000 English Final Retail 8/12/2004 14:18:30 590336 bytes
    d3drm.dll: 5.01.2600.0000 English Final Retail 8/12/2004 14:18:30 350208 bytes
    d3dxof.dll: 5.01.2600.0000 English Final Retail 8/12/2004 14:18:30 47616 bytes
    d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/12/2004 14:18:29 34816 bytes
    dplay.dll: 5.00.2134.0001 English Final Retail 8/12/2004 14:18:44 33040 bytes
    dplayx.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:44 229888 bytes
    dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:44 23552 bytes
    dpwsock.dll: 5.00.2134.0001 English Final Retail 8/12/2004 14:18:45 42768 bytes
    dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:46 57344 bytes
    dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:44 30208 bytes
    dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:45 18432 bytes
    dpnet.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:44 375296 bytes
    dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:45 3584 bytes
    dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:44 3584 bytes
    dpvoice.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:45 212480 bytes
    dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:45 83456 bytes
    dpvvox.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:45 116736 bytes
    dpvacm.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:45 21504 bytes
    dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:44 35328 bytes
    dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:44 60928 bytes
    dpserial.dll: 5.00.2134.0001 English Final Retail 8/12/2004 14:18:45 53520 bytes
    dinput.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:38 159232 bytes
    dinput8.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:38 181760 bytes
    dimap.dll: 5.01.2600.0000 English Final Retail 8/12/2004 14:18:38 44032 bytes
    diactfrm.dll: 5.01.2600.0000 English Final Retail 8/12/2004 14:18:36 394240 bytes
    joy.cpl: 5.03.2600.2180 English Final Retail 8/12/2004 14:20:24 68608 bytes
    gcdef.dll: 5.01.2600.0000 English Final Retail 8/12/2004 14:19:21 76800 bytes
    pid.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:29:28 35328 bytes
    dsound.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:54 367616 bytes
    dsound3d.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:55 1294336 bytes
    dswave.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:56 19456 bytes
    dsdmo.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:53 181760 bytes
    dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:53 71680 bytes
    dmusic.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:42 104448 bytes
    dmband.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:40 28672 bytes
    dmcompos.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:41 61440 bytes
    dmime.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:41 181248 bytes
    dmloader.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:41 35840 bytes
    dmstyle.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:42 105984 bytes
    dmsynth.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:42 103424 bytes
    dmscript.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:42 82432 bytes
    system.dll: 1.01.4322.0573 English Final Retail 10/8/2006 19:11:33 1216512 bytes
    Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 10/9/2006 21:09:00 473600 bytes
    Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 10/9/2006 21:08:58 2676224 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 10/9/2006 21:08:58 2846720 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 10/9/2006 21:08:58 563712 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 10/9/2006 21:08:59 567296 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 10/9/2006 21:08:59 576000 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 10/9/2006 21:08:59 577024 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 10/9/2006 21:08:59 577536 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 10/9/2006 21:08:59 577536 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 10/9/2006 21:08:59 578560 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 10/9/2006 21:09:00 578560 bytes
    Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 10/9/2006 21:09:00 145920 bytes
    Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 10/9/2006 21:09:00 159232 bytes
    Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 10/9/2006 21:09:00 364544 bytes
    Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 10/9/2006 21:09:00 178176 bytes
    Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 10/9/2006 21:09:00 53248 bytes
    Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 10/9/2006 21:09:00 12800 bytes
    Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 10/9/2006 21:09:00 223232 bytes
    dx7vb.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:57 619008 bytes
    dx8vb.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:57 1227264 bytes
    dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:18:57 2113536 bytes
    mfc40.dll: 4.01.0000.6140 English Final Retail 8/12/2004 14:21:58 924432 bytes
    mfc42.dll: 6.02.4131.0000 English Final Retail 8/12/2004 14:21:58 1028096 bytes
    wsock32.dll: 5.01.2600.2180 English Final Retail 8/12/2004 14:34:47 22528 bytes
    amstream.dll: 6.05.2600.2180 English Final Retail 8/12/2004 14:17:21 70656 bytes
    devenum.dll: 6.05.2600.2180 English Final Retail 8/12/2004 14:18:33 59904 bytes
    dxmasf.dll: 6.04.0009.1125 English Final Retail 8/12/2004 14:18:58 498205 bytes
    mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/12/2004 14:21:25 35328 bytes
    mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/12/2004 14:22:23 148992 bytes
    msdmo.dll: 6.05.2600.2180 English Final Retail 8/12/2004 14:23:04 14336 bytes
    encapi.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:19:00 20480 bytes
    qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 13:44:28 221184 bytes
    qcap.dll: 6.05.2600.2180 English Final Retail 8/12/2004 14:26:45 192512 bytes
    qdv.dll: 6.05.2600.2180 English Final Retail 8/12/2004 14:26:45 279040 bytes
    qdvd.dll: 6.05.2600.2180 English Final Retail 8/12/2004 14:26:46 385024 bytes
    qedit.dll: 6.05.2600.2180 English Final Retail 8/12/2004 14:26:46 562176 bytes
    qedwipes.dll: 6.05.2600.2180 English Final Retail 8/12/2004 14:26:46 733696 bytes
    quartz.dll: 6.05.2600.2749 English Final Retail 8/30/2005 04:54:26 1287168 bytes
    strmdll.dll: 4.01.0000.3928 English Final Retail 8/12/2004 14:30:16 246302 bytes
    iac25_32.ax: 2.00.0005.0053 English Final Retail 8/12/2004 14:19:46 199680 bytes
    ir41_32.ax: 4.51.0016.0003 English Final Retail 8/12/2004 14:20:16 848384 bytes
    ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/12/2004 14:20:16 120320 bytes
    ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/12/2004 14:20:16 338432 bytes
    ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/12/2004 14:20:16 755200 bytes
    ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/12/2004 14:20:16 200192 bytes
    ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/12/2004 14:20:16 183808 bytes
    ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/12/2004 14:20:21 154624 bytes
    mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/12/2004 14:23:53 204288 bytes
    ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928 bytes
    ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
    ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
    stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640 bytes
    mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:58:40 5376 bytes
    mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 23:58:42 4992 bytes
    mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:58:42 7552 bytes
    swenum.sys: 5.03.2600.2180 English Final Retail 8/12/2004 14:29:28 4352 bytes
    mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/12/2004 14:22:23 118272 bytes
    msvidctl.dll: 6.05.2600.2180 English Final Retail 8/12/2004 14:23:52 1428480 bytes
    vbisurf.ax: 5.03.2600.2180 English Final Retail 8/12/2004 14:32:05 30720 bytes
    msyuv.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:29:28 17408 bytes
    wstdecod.dll: 5.03.2600.2180 English Final Retail 8/12/2004 14:34:47 50688 bytes
    DirectShow Filters
    DirectShow Filters:
    WMAudio Decoder DMO,0x00800800,1,1,,
    WMAPro over S/PDIF DMO,0x00600800,1,1,,
    WMSpeech Decoder DMO,0x00600800,1,1,,
    WMVideo Advanced Decoder DMO,0x00800001,1,1,,
    Mpeg4s Decoder DMO,0x00800001,1,1,,
    WMV Screen decoder DMO,0x00800001,1,1,,
    WMVideo Decoder DMO,0x00800001,1,1,,
    Mpeg43 Decoder DMO,0x00800001,1,1,,
    Mpeg4 Decoder DMO,0x00800001,1,1,,
    WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
    Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
    DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
    Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
    WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802
    Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
    AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
    WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
    Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
    Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
    WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
    WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
    Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
    WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
    Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
    MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
    ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
    File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
    WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
    DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
    Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2749
    Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
    WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
    ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
    ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
    NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
    ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
    Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
    Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
    Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
    Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
    Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
    WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
    Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
    WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3802
    WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
    Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
    File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
    WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
    DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
    Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
    AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
    .RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
    WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
    DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
    Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
    Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
    ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
    ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
    ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
    ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
    ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
    ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
    ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
    9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
    Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
    Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
    WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
    WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
    Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
    Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
    AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
    Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
    QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
    Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
    MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
    Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
    File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
    XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
    AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
    File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
    File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
    WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
    QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
    Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
    Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
    WDM Streaming Data Transforms:
    Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
    Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
    Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
    Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
    Video Compressors:
    MSScreen encoder DMO,0x00600800,1,1,,
    WMVideo9 Encoder DMO,0x00600800,1,1,,
    WMVideo Advanced Encoder DMO,0x00600800,1,1,,
    MSScreen 9 encoder DMO,0x00600800,1,1,,
    DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
    Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
    Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Audio Compressors:
    WM Speech Encoder DMO,0x00600800,1,1,,
    WMAudio Encoder DMO,0x00600800,1,1,,
    IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
    IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
    Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
    ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
    DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
    Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
    Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
    GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
    MSN Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2749
    Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
    CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
    CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
    MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
    Audio Capture Sources:
    SB Audigy 2 Audio [C8C0],0x00200000,0,0,qcap.dll,6.05.2600.2180
    USB Audio Device,0x00200000,0,0,qcap.dll,6.05.2600.2180
    Midi Renderers:
    Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
    Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
    SB Audigy 2 Sw Synth [C8C0],0x00200000,1,0,quartz.dll,6.05.2600.2749
    SB Audigy 2 Synth A [C8C0],0x00200000,1,0,quartz.dll,6.05.2600.2749
    SB Audigy 2 Synth B [C8C0],0x00200000,1,0,quartz.dll,6.05.2600.2749
    WDM Streaming Capture Devices:
    SB Audigy 2 Audio [C8C0],0x00200000,3,2,,5.03.2600.2180
    USB Audio Device,0x00200000,1,1,,5.03.2600.2180
    WDM Streaming Rendering Devices:
    SB Audigy 2 DirectMusic Synthesizer [C8C0],0x00200000,1,1,,5.03.2600.2180
    SB Audigy 2 Sw Synth [C8C0],0x00200000,1,1,,5.03.2600.2180
    SB Audigy 2 Synth A [C8C0],0x00200000,1,1,,5.03.2600.2180
    SB Audigy 2 Synth B [C8C0],0x00200000,1,1,,5.03.2600.2180
    WDM Streaming Mixer Devices:
    Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
    BDA CP/CA Filters:
    Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
    Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
    XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
    Audio Renderers:
    SB Audigy 2 Audio [C8C0],0x00200000,1,0,quartz.dll,6.05.2600.2749
    Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
    Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
    DirectSound: SB Audigy 2 Audio [C8C0],0x00200000,1,0,quartz.dll,6.05.2600.2749
    WDM Streaming System Devices:
    SB Audigy 2 Synth A [C8C0],0x00200000,10,2,,5.03.2600.2180
    SB Audigy 2 Audio [C8C0],0x00200000,12,2,,5.03.2600.2180
  2. DR.Death
    DR.Death New Member
    Jul 10, 2005
    1,757 (0.49/day)
    64
    Canada
    it sounds to be a driver problem try uinstaling them and let it find them agian
  3. Waterer New Member
    Oct 10, 2006
    5 (0.00/day)
    0
    I have also tried the drive under Vista RC2, which it used to work fine under, I get the same problem, I have also tried uninstalling the drivers, I've tried everything logical that I can think of, it seems a bit strange that nothing has sorted it :banghead:
  4. DanTheBanjoman Señor Moderator
    May 20, 2004
    10,553 (2.62/day)
    1,383
    Do other disks read fine? If not it is probably a drive problem.
  5. Nitro-Max
    Nitro-Max New Member
    Sep 9, 2006
    2,476 (0.78/day)
    239
    Great Yarmouth, United Kingdom.{East Anglian Coast
    Normally if drives arent installed right u loose the auto play feature and ive known drives to not read cirtain files when this happens may need to reinstal the drivers or system again and are u positive the burning went to plan? it could be a empty disk?.
  6. Zedicus
    Sep 30, 2004
    490 (0.13/day)
    41
    he said he tried the disk in a different computer and it worked fine so rule disk out.
    he said hes tried reloads and driver reinstalls so rule that out.
    like dan said try other disks in the drive and see what happens...
    things to check. the IDE cable may be bad, broken pins on the drive or board. try moving the drive to a different cable and different header if possible. make sure the master/slave jumper is set correct. and try a different drive in that computer and see if it reads and detects o.k...
    also, does bios list the drive?
  7. Waterer New Member
    Oct 10, 2006
    5 (0.00/day)
    0
    Disks which I have purchased work fine ie Oblivion and Half Life 2, it's burnt disks which are not working.
    Both my CD and DVD drive are on the same IDE cable, and both are set to 'allow cable to select', with a different IDE cable I get the same problem, but the CD drive works fine, I have tried two different drives in there and they both have the same problem.
    The drive is listed in the bios and also under windows, if I right click on the drive and change the settings to 'Enable CD recording on this drive' when I put the disc in its is recognised and autoplays, but is displayed as a blank disc and I cannot get any files off of it...
    The burn on the disc is fine, in another XPS that we own with an identical drive it reads fine.
    Also, I cannot burn anything with the drive it just errors :(
    Cheers
    Sam
  8. Zedicus
    Sep 30, 2004
    490 (0.13/day)
    41
    sounds like bad drive. i would still try setting the jumpers to one master and one slave. ive never had good luck with cable select.
  9. DanTheBanjoman Señor Moderator
    May 20, 2004
    10,553 (2.62/day)
    1,383
    Do a read performance test on working disks. RIP a DVD< use neros tool or whatever. If scores are low odds are that it's still a crap drive.
  10. Waterer New Member
    Oct 10, 2006
    5 (0.00/day)
    0
    But I have the same problem with another drive which I know for a fact has been working fine for the last 6-7 months, I have seen no signs of the drive deteriorating...
    I shall do a read performance test using Nero, cheers for that idea.
    Cheers
    Sam
  11. Waterer New Member
    Oct 10, 2006
    5 (0.00/day)
    0
    Ok, Nero says that the drive is reading the Oblivion disc absolutly fine, I think I will have to buy another IDE cable and try that, because the spare I used is of unknown quality..
    Any other ideas?....:)
Share This Page
