EK Debuts Water Blocks for EVGA Classified SR-X and MSI R7970 Lightning
Discussion in 'News' started by Cristian_25H, Aug 2, 2012.
  1. Cristian_25H
    Cristian_25H News Poster
    Dec 6, 2011
    4,731 (3.10/day)
    1,183
    Still on the East Side
    EK Water Blocks, premium water cooling gear provider, has released two new water blocks - the EK-FB KIT SR-X for EVGA Classified SR-X motherboard and the EK-FC7970 Lightning for MSI's premium R7970 Lightning graphics card.
    EK-FB KIT SR-X full-board water block kit is a complete liquid cooling solution for EVGA Classified SR-X (270-SE-W888) motherboard. The water blocks directly cools Intel C606 southbridge (PCH), PLX PEX8784 PCIe lane splitter controller and power regulation (VRM / MOSFETs) module of both CPUs. Please note this water block cools exactly as much heat generating components as EVGA factory cooling solution. It is medium-high to high flow water block that can be easily used with systems using weaker water pumps. It is available in two variants - Nickel and Acetal+Nickel.
    [​IMG] [​IMG] [​IMG]
    EK-FC7970 Lightning (abbrevated as 'LTG') is a high performance full-cover water block for engineered specifically for MSI Radeon HD 7970 Lightning series graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
    This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC7970 Lightning water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps. The angled connection terminal EK-FC Link is already bundled with each water block and allows for up to four cards to be connected via EK-FC Bridge & Link CSQ system. The bridges are available for separate purchase through EK Webshop. The water block is available only in Acetal+Nickel variant.
    Both products are readily available for purchase through EK Webshop.
  2. m1dg3t
    m1dg3t
    May 22, 2010
    2,255 (1.08/day)
    518
    Canada
    I think Eddy's been watching to many crop circle vidz :laugh:
  3. MasterInvader
    MasterInvader
    Sep 16, 2011
    278 (0.17/day)
    61
    Portugal
    WTF circles again... :confused:
    I´am starting to move away from EK
  4. Phusius
    Phusius New Member
    Mar 23, 2012
    1,317 (0.93/day)
    380
    that would be one beast of a machine... 7970 lightnings in CF both on waterblocks... OC'ed massively... but at the point you might as well just buy 2 gtx 690's in sli. lol
  5. the54thvoid
    the54thvoid
    Dec 14, 2009
    4,564 (2.03/day)
    3,113
    The Lightning is absolutely borked by lack of DVI-D. Otherwise I'd buy one and put one of these blocks on. Silly people at MSI.
  6. Frick
    Frick Fishfaced Nincompoop
    Feb 27, 2006
    12,201 (3.36/day)
    3,434
    Wait is the SR-X out yet?
  7. Jizzler
    Jizzler
    Aug 10, 2007
    3,735 (1.20/day)
    786
    Geneva, FL, USA
  8. LAN_deRf_HA
    LAN_deRf_HA
    Apr 4, 2008
    4,613 (1.61/day)
    977
    Threw me seeing EVGA and 7970 in the title.
  9. theonedub
    theonedub habe fidem
    Apr 30, 2009
    7,640 (3.09/day)
    4,706
    the54thvoid says thanks.
    Crunching for Team TPU
  10. rpsgc
    rpsgc
    Feb 9, 2007
    705 (0.21/day)
    133
    Portugal
    Yeah... no thanks.
  11. johnnyfiive
    johnnyfiive
    Apr 17, 2008
    3,892 (1.36/day)
    876
    Tucson, AZ
    Also, no thanks to the SR-X since you can't overclock AT ALL.
  12. radrok
    radrok
    Oct 26, 2011
    3,098 (1.98/day)
    850
    Agreed. ;)
    Also those circles ewww.
  13. pantherx12
    pantherx12 New Member
    Jan 2, 2009
    9,714 (3.74/day)
    1,699
    ENGLAND-LAND-LAND
    + one to circle hate.
    A plain block would look much nicer, and these would just add to production costs and time ( not a lot I imagine but still, it adds up)
  14. urza26
    urza26
    Dec 9, 2011
    238 (0.16/day)
    28
    The Netherlands
    I seem to be missing something here... why not use displayport instead then, seeing it supports resolutions beyond 1920x1080 while single-link DVI does not?
  15. PopcornMachine
    PopcornMachine
    Aug 17, 2009
    1,565 (0.66/day)
    459
    Los Angeles/Orange County CA
    If the card had the standard 7970 ports, it could be single slot with this block on it.
  16. Dr. Nick
    Dr. Nick New Member
    Jan 21, 2011
    22 (0.01/day)
    4
    I miss the days when high-end GPUs were single slot.
  17. Frick
    Feb 27, 2006
    12,201 (3.36/day)
    3,434
    You mean hot and loud? I don't. :(
  18. radrok
    radrok
    Oct 26, 2011
    3,098 (1.98/day)
    850
    I think they should have used the same output configuration as the HD6990 (single slot capable)
    4miniDP and 1 dual link DVI
    eyefinity 5x1 is the best configuration over 3 monitors for gaming.
  19. Morgoth
    Morgoth
    Aug 4, 2007
    3,804 (1.22/day)
    253
    Netherlands
    tec/water cooling? single slot solution?
  20. Dr. Nick
    Dr. Nick New Member
    Jan 21, 2011
    22 (0.01/day)
    4
    No, I mean when the waterblock and the backplate connectors all fit within the space of a single expansion slot.
    I'd like to see an all DisplayPort GPU with a waterblock.
  21. matar
    matar
    Jul 1, 2011
    86 (0.05/day)
    10
    Superb but only 6 SATA ports only...will never buy it if i was planning to buy a dual LGA 2011... atleast 10 SATAs is enough...
