- May 24, 2023
- 732 (1.94/day)
I think it would be practical to have threads for manufacturers to visit and see the ideas of customers in one place.
I noticed, that these fittings: EK-Quantum Torque 6-Pack STC 12/16 - Nickel, Product EAN: 3831109824375
have extremely sharp flanges inside, which do cut into the hoses. I am not sure if the term flange is correct, I am talking about this protrusion:
I do not think that cutting and disrupting the hoses is a good thing, depending on the material the cut could have a tendency to spread...
It was very difficult to remove the hose from this fitting, and when I finally managed to do that, the hose had often shaven off bits inside. The disrupted surface could seal worse, you need to remove the hose completely to wash the bits from the hose and then preferably cut the affected parts away.
I do not know if this sharp edge was a result of a manufacturing error, but if it was a design decision, it was a very bad decision...
EK-Quantum Torque 6-Pack STC 12/16 is a fitting multipack containing six EK-Torque STC fittings. These are EK's premium 12/16mm (ID/OD) soft-tube compression fittings designed for use with various flexible soft tubing types such as PVC, EPDM, Norprene, silicone or any other type of compatible...
www.ekwb.com
