Errr..about the same temps idle and load on e8400 ?
Discussion in 'Overclocking & Cooling' started by zalmanor, Sep 3, 2009.
  1. zalmanor New Member
    Sep 3, 2009
    2 (0.00/day)
    0
    Hi, may someone explain this ? :
    thank you
  2. rickss69
    Aug 23, 2009
    2,454 (1.04/day)
    618
    Rockvale TN (Not Australia)
    Take a screen during peak load.
  3. 95Viper
    95Viper
    Oct 12, 2008
    5,071 (1.90/day)
    2,153
    στο άλφα έως ωμέγα
    Sorry, can't help on that one. Look's like sensors are working, but they are not being read when tested...
    Welcome to TPU. You should have probably posted this in the Realtemp forum, here:http://forums.techpowerup.com/forumdisplay.php?f=65
    Edit: Like rickss69 said.
    Run Prime95 and take a screen shoot of real temp at load.
  4. erocker
    Jul 19, 2006
    41,051 (11.76/day)
    16,153
    The sensor movement test is reporting 0 movement. Stuck sensors.
  5. DanishDevil
    DanishDevil
    Oct 6, 2005
    10,237 (2.71/day)
    2,149
    Granite Bay, CA
    ^ Agreed. Get yourself a fan and temperature controller and put a probe on the CPU's IHS to get an idea of what the temps are at. You won't get the temperature of the cores themselves, so add a few degrees (maybe 5C or more?) to get a temperature close to the CPU cores.
    10 Year Member at TPU
  6. erocker
    Jul 19, 2006
    41,051 (11.76/day)
    16,153
    Really you could just go by the CPU socket temp. This temp is reported in your bios. I believe SpeedFan reports this temp as well.
    DanishDevil says thanks.
  7. DanishDevil
    DanishDevil
    Oct 6, 2005
    10,237 (2.71/day)
    2,149
    Granite Bay, CA
    ^ Better solution :)
  8. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    22,164 (5.94/day)
    8,068
    If they are stuck at 33/34°C I wouldn't worry about it. They will go up if your temps ever get above that, and 33/34°C is nothing to worry about.
    10 Year Member at TPU Crunching for Team TPU More than 25k PPD
  9. zalmanor New Member
    Sep 3, 2009
    2 (0.00/day)
    0
    re: e8400 idle, load
    Many thanks for reply,first i must say i'm trying a new rig wich looks like this :
    Asus Maximus formula 2
    core 2 duo e8400 step E0@3.6 Ghz (9*400)
    WD Velociraptor 150 GB
    OCZ Reaper 8500 2*2 GB
    Zalman cnps 10 extreme
    Zalman Gs1000 high tower(added two fans bottom and above)
    Sapphire HD4850 a bit OCed Zalman cooled
    Room temp about 20 degrees
    core temps were the same @ stock, idle and under load,varying only for 1 or 2 degrees..@3.6 Ghz 33/34 idle and about 37/37 under load.
    socket sensor shows 19 degrees idle and 30 degrees full under speedfan
    Pls take a look at the pic,any explanation is welcome,thank you !
  10. WSP
    WSP New Member
    Aug 26, 2009
    101 (0.04/day)
    6
    Indonesia
    just like erocker said...stuck sensor
    but you can try another temp software like speedfan, everest, core temp etc
