EVGA 9800GTX+ Thermaltake powerexpress 250watt vga power supply
Discussion in 'NVIDIA' started by jtbond008, May 10, 2009.
  1. jtbond008 New Member
    Jun 4, 2008
    32 (0.01/day)
    4
    I Have A Question.... I'm A Getting A Evga 9800+ I Was Wondering Will Running Ok On My Thermaltake Powerexpress 250watt... I'm Currently Running A 8800gts 320...
  2. BazookaJoe
    BazookaJoe
    Sep 4, 2008
    874 (0.32/day)
    240
    jtbond008 says thanks.
  3. ShadowFold
    ShadowFold New Member
    Dec 23, 2007
    16,921 (5.70/day)
    1,642
    Omaha, NE
    BazookaJoe and jtbond008 say thanks.
  4. newtekie1
    newtekie1 Semi-Retired Folder
    Nov 22, 2005
    22,157 (5.94/day)
    8,062
    Yes, the 9800GTX+ should actually use a little less power than the 8800GTS 312MB.
    Look at it like this:
    Each 6-pin connector is rated for a maximum of 75w, and the PCI-E slot is rated to deliver another 75w. Depending on the version of the 9800GTX+, you might get one with two 6-pin power connectors, or one 6-pin. If you get a 9800GTX+ with two 6-pin, that card is going to use somewhere over 150w at peak, but below 225w. On top of this, the card will ever only pull 150w max from the PowerExpress power supply, as that is the maximum two 6-pin connectors are rated to provide, and that is all the PowerExpress power supply is connected to. The other 75w will be provided by the standard power supply through the motherboard.
    10 Year Member at TPU Crunching for Team TPU More than 25k PPD
  5. jtbond008 New Member
    Jun 4, 2008
    32 (0.01/day)
    4
    thanks dude i really appreciate it.. i was hoping it would run.. i know i need another power really can't afford it.......
    thanks for you help i really appreciate it..
    thanks......
  6. N4cot1c New Member
    Apr 2, 2009
    133 (0.05/day)
    11
    I have a 450 watt psu I used to run my 4870 on. It can be yous for 25$ shipped if you are interested.
  7. jtbond008 New Member
    Jun 4, 2008
    32 (0.01/day)
    4
    no thanks dude my main system has a 450watt installed.... lol price is good
  8. N4cot1c New Member
    Apr 2, 2009
    133 (0.05/day)
    11
    Ok. Just trying to help.
  9. jtbond008 New Member
    Jun 4, 2008
    32 (0.01/day)
    4
    thanks
  10. BazookaJoe
    BazookaJoe
    Sep 4, 2008
    874 (0.32/day)
    240
    OH ffs yes :\
    I got caught out (Honestly, I thought that was very high - But it was also very late)
    WAs going to double check today - thought maybe it was an X2 (And even then that's a bit high)
  11. jtbond008 New Member
    Jun 4, 2008
    32 (0.01/day)
    4
    no i'm running the single gpu core....my 8800gts run about 26amps the 9800gtx about 28amps.. i'm trying figure this power express runs 21amps per rail or all together thew box says 25amps at peak and 75% efficiency.. so hooking up both pci express connector the my power express should be enough power i think.. my main 450 watt single rail going to get it's already juiced out. with my x2 4800+ overclocked to 3.3ghz plus it only maxes out at 422watts.. full load i know i need other power supply my funds are low.... tell me what do you think about that?
  12. BazookaJoe
    BazookaJoe
    Sep 4, 2008
    874 (0.32/day)
    240
    Yeah - No sorry - My bad to begin with.
    Yer vPSU for a single 9800 is perfectly fine :) - It was late and I clearly needed more sleep than I thought.
  13. jtbond008 New Member
    Jun 4, 2008
    32 (0.01/day)
    4
    thanks good looking out
  14. Lethalrise750
    Lethalrise750 New Member
    Mar 5, 2009
    123 (0.05/day)
    19
    Orlando, FL
  15. jtbond008 New Member
    Jun 4, 2008
    32 (0.01/day)
    4
    thanks dude... i really appreciate it......input is very important
