Experienced OC'r needs help on Q6600. :)
Discussion in 'Overclocking & Cooling' started by Cowspoo, Feb 7, 2008.
  1. Cowspoo New Member
    Feb 7, 2008
    54 (0.02/day)
    0
    i don't have any option for SLI memory
  2. pepsi71ocean New Member
    Nov 7, 2007
    1,471 (0.52/day)
    125
    The Peoples Republic of New South Jersey
    In BIOS?
  3. FR@NK
    FR@NK
    Apr 30, 2006
    576 (0.17/day)
    94
    Hes using a crossfire board.
  4. Cowspoo New Member
    Feb 7, 2008
    54 (0.02/day)
    0
    yeah :( who cares about ATI anyways -,-
  5. asb2106
    asb2106 New Member
    Jan 8, 2008
    1,940 (0.70/day)
    149
    kTOwN WI!!
    what OS are you using? and is it 32 or 64bit?
  6. pepsi71ocean New Member
    Nov 7, 2007
    1,471 (0.52/day)
    125
    I was sleeping and i just woke up but under settings General is MODE set to CPU? Or is it RAM or CPU&RAM?
    Its says a memory error im not sure, but i think that that might be the reason.
  7. Cowspoo New Member
    Feb 7, 2008
    54 (0.02/day)
    0
    Ram and CPU, is it that important to run OCCT over Prime..
  8. pepsi71ocean New Member
    Nov 7, 2007
    1,471 (0.52/day)
    125
    Try just CPU and then try just ram, if it runs separately then you know that its the CPU and ram thats crashing the program. Strange I know that vista is still a little buggy, but the guy that build the program built it a while ago from what i know, all i know is it works and is harder than Prime95.
    Cowspoo says thanks.
  9. Paulieg
    Paulieg The Mad Moderator Staff Member
    Feb 19, 2007
    11,957 (3.87/day)
    3,034
    Wherever I can find the iron.
    OCCT tests stability in a very similar way as prime95. It's a good stability tool, but don't bother if it doesn't like your system. If you are prime stable for at least 3 hours, along with a successful run of superpi 32m, and 3dmark06, you are golden...as long as temps are acceptable.
Share This Page
