Fan power consumption question
Discussion in 'Overclocking & Cooling' started by Odin Eidolon, May 9, 2008.
  1. Odin Eidolon
    Odin Eidolon New Member
    Feb 12, 2008
    921 (0.35/day)
    156
    Rockclimbing somewhere in Italy
    Hi all. I'm gonna buy some new yateloon fans for my cm690 (2xD12SM; 1xD12SL; 2xD14SL; 2xD14SM; 2xD12SL BLUE LED). I have some questions:
    -Will i be able to put one D14SM (http://www.petrastechshop.com/14yalod1cafa1.html) (max 8.4W) fan controlled by a zalman MFC1 (7W per channel)? What happens if i do it?
    - why does 2xD12SL BLUE LED (http://www.petrastechshop.com/12yalod1blle.html) consume as only 1 D12SL NON LED (http://www.petrastechshop.com/12yalod1cafa.html)? They are only a bit slower!
    -why do D12SL and D12SM (http://www.petrastechshop.com/12yalod1cafa1.html) have the same power consumption, while the second has a lot more RPM?
    -last question: do you think that those are good fans? I have read some good reviews about them.
    thanks guys!
    p.s.: my shopping will be completed by:
    http://www.petrastechshop.com/5scsckbavesy.html
    http://www.petrastechshop.com/arcomxthco.html
    http://www.petrastechshop.com/80x15zaop.html
    http://www.petrastechshop.com/12plfanfibl.html
    tell me what you think!
  2. Odin Eidolon
    Feb 12, 2008
    921 (0.35/day)
    156
    friendly bump for myself
  3. Odin Eidolon
    Feb 12, 2008
    921 (0.35/day)
    156
    Bump...
  4. AsRock
    AsRock TPU addict
    Jun 23, 2007
    11,657 (4.08/day)
    2,007
    US
    Just by the info you put here they say NO as it's over there recommended watts.. You be able to do it but if that fan set to run full speed is were it probably go POP sooner or later.
    EDIT: I like the Rexus fans. Harly silent BUT dam they really move that air. i placed the 120mm on the table and it moved it self accross the dam table.. Catch ya finger in one you will surly know about it looool.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835705011
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835705004
    Odin Eidolon says thanks.
  5. Odin Eidolon
    Feb 12, 2008
    921 (0.35/day)
    156
    LOL. Yes you are right those fans are great, but i'm looking for something more silent, and it seems taht yates are the best for price/perf. anyway a great thank to you!!!
Share This Page
